Island City - Starry Night
3,550
83
12
This is a project I started more than 6 month ago (not much spare time in my house ;-) ). We needed something for the bedroom, which would light up automatically, and not too bright, enough to find your way into bed, and not wake the other one up, which is most of the times my wife ;-)
Have seen online a lot of solutions for a starry night ceiling and paintings. Gathered all those ideas, took the best ones and put them into this one.
As soon as I discovered the potential of blacklight painting doing this painting, I knew I will probably never do a painting without it. Have a lot to learn on how to mix colors to get the nicest effects, and it really looks good in the dark (way better than all pictures I shoot with my camera).
From all the solutions for the stars I chose the fully programable rgb leds, since I wanted to be able to program some of the starts to go bright randonmly from time to time.
Supplies:
Step 1: Prepare the Base
The base and frame I made out of wood, screws and a hdf board. I knew I will opt for some kind of led strings and not the usual strips, so I needed some space behind the painting.
In the attached images you can find my construction design. I made it about 120 x 80 cm. But this depends only on how big you want your painting.
Also I tested before if i can paint on the hdf board with my acrylic paints.
Step 2: Painting or Poster
In this step you have two options:
The first option: you paint your own painting. I decided to paint my own, since I need to improve my skills a lot. Besides that I'm pretty picky, and this way I get what I like ;-) I'm not going into how to paint it, since I am still learning myself and don't have the best tipps for you here.
Or the second option you take a poster and glue it on the base. How about "Starry Night" from Van Gogh? That should look cool in the end. You can still do all the following steps, and get a great result.
Step 3: UV (blacklight) Layer
In my last blacklight painting I explained in detail how I have done it. Basically I have done the same thing.
Using blacklight paints I covered the finished painting in the areas which would normally be lighted up by the moon behind the big tree. In daylight you can hardly see the blacklight painting although I didn't use the invisible blacklight paint described in my other post.
One thing I discovered new by chance and used it right away: Before starting I wanted to paint also a city of some sort, with houses, and the windows which I would cut out of the wood, and light them up with leds also. But then I got lazy I guess and didn't want all that work ;-) Then when painting with blacklight I saw that a little thick point of blacklight paint would glow a lot. That was my solution for all the windows and doors in the city (village). I like it how it turned out...
Step 4: Adding Stars
OK, this part was by far the most hurtfull thing of the entire process: putting holes in my painting :-)
For the stars I decided to go for theese led strings. I could not find any fully adressable WS2812b controlled leds smaller than that. If someone knows some, I am veeeeery interested.
Now for those leds, 12 mm holes were needed in my painting ... 25 of them ... I said no way. I settled for 8 mm holes and glued only the tip of the leds in the holes, like in the image above. I was lucky I opted for that big wooden frame, because the leds take now a lot of space behind the painting.
Step 5: Electronics
Now for the special effects ;-)
I used the following components:
  • an Arduino Nano for controlling the whole "magic" (code is attached)
  • 12V power source
  • blacklight led strip, 12V
  • 7805 voltage regulator to create 5V for the arduino
  • WS2812B, fully adressable RGB led string, 25 leds, 5V
  • TIP122 transistor to control the blacklight leds from the arduino
  • motion sensor
  • light sensor
  • 3x switches
Attached you find also the electronic schematics. It works like this: when the room is dark (light sensor), and it detects someone approaching (motion sensor), then the blacklights leds go on, the stars go on (RGB leds) and 10 of them shine randomly, and after that everything goes dark again. The switches can be used to: disable the RGB leds, disable the light sensor or disable the motion sensor.
Step 6: Finale
Here you can see the result. Hope you enjoyed it.
Look forward on your comments and suggestions on improvements...
More on: http://www.familie-fratila.de
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    12 Discussions
    Build_it_Bob
    1 year ago
    I am enjoying looking at all your artistic creations and your Instructables.
    Keep up the great work and I hope this is something that you can make money off of. I think there are many out there that would be willing to pay for this caliber and unique artwork.
    Bravo!
    Build_it_Bob
    AllDayDaddyO
    3 years ago
    Very cool. The glowing of the night painting is amazing.
    I agree with Scotticus that fiber optics produce a finer star with a smaller hole. That's what I used here: https://m.instructables.com/id/NEW-DAD-TAKES-A-STAR-CEILING-TO-A-NEW-LEVEL/
    But the whole image is stilk extraordinary.
    Scotticus
    4 years ago
    Nice idea, good project and painting skill. I thought that if you were to use fibre optic strands to transmit the light you'd be able to get much finer resolution, and many more stars with any Led of your choice.
    fcfelixScotticus
    Reply 4 years ago
    Thanks, yes, thought of that. But then I wouldn't get single randomly glowing stars but only one brightness level for all stars at a time. But a combination of those two ideas is definitely better. I settled for little blacklight paint dots as little stars for now. Maybe I will enhance it in the future...
    jditterline
    4 years ago
    This turned out so awesome! As a painter, I never thought to use uv paint like that. Super cool.
    Ben Finio
    4 years ago on Step 5
    Awesome project! One minor correction - I believe your Fritzing diagram shows an infrareddistance sensor, like this:
    https://www.sparkfun.com/products/242
    while what you actually used is a passive infrared (PIR) motion sensor, like this:
    https://www.sparkfun.com/products/8630
    judging by the second photo above. You should be able to find one of those in the Fritzing library if you search for "PIR".
    Just don't want anyone to get confused if they're trying to do this project and buy the wrong sensor!
    fcfelixBen Finio
    Reply 4 years ago on Introduction
    Thanks for the suggestion. I've been searching for "pir" before as well, but didn't have it in my collections. Therefore the note that said "motion sensor" :-). But I imported a part more suitable now.
