Jim's Rising Chair
36,597
444
38
About: I'm a health care professional, amateur astronomer, author and occasional car and motorcycle mechanic.
First off, I'd like to make clear that the design of the Rising Chair is not mine. It was the product of the genius of Robert van Embricqs, who won the RedDot Design Award in 2011 in the Netherlands for this design.
There is a propensity in the furniture design and manufacturing business to poach ideas without apparent liability. Le Corbusier's Chaise Lounge and the Eames Chair have been copied by so many manufacturers for so many decades with impunity, supported by a buying public who are happy to have scored a deal. Even though the Rising Chair is a relatively young design, I'm aware of at least one American designer who has shamelessly copied the design and marketed it as his own under the moniker of The Arania Seat. Yet counterfeit Gucci or Hermes bag are prosecuted with vigour.
Step 1: What Is a "Rising Chair"?
The Rising Chair doubles as a piece of static art as well as a truly functional chair that can be folded flat and conveniently stored as a thin sheet of wood. Originally constructed in teak or ash, I wanted to make one out of something that would withstand the harsh Canadian climate and allow year round outdoor usage. And to see if I could reverse engineer the design as well!
Step 2: Materials
37 one inch square tube aluminum, 60 inches in length
148 white plastic ends caps to fit aluminum tube
37 3/4" high hinges
148 #4 machine screws
2 four foot length of 3/8" diameter metal threaded rod and nuts
scrap lumber to construct jigs
Step 3:
The chair is made of 18 pairs of aluminum square tube with one central lone tube making a total of 37.
Each five foot length of tube must be cut once, precisely according to the chart and all ends cleaned up and finished with a white plastic end cap. A 3/8" hole is drilled through two sides of each square tube (the two tubes resulting from each cut) and a simple jig was fabricated to ensure the hole is drilled exactly in the same spot for each tube. The tubes are arranged in mirror fashion, #1 through #18, then #19, and then #18 through to #1.
The two halves of each square tube are attached on the surface that has does not have the 3/8" hole drilled with the 3/4" hinges by tapping and screwing in #4 sized machine screws, again facilitated by the construction of a simple jig to keep the pieces perfectly aligned.
Hopefully you will have read this Instructable completely before starting construction because I discovered these hinges are not strong enough to sustain the weight of a human adult. One inch high hinges are too wide since they will rub against neighbouring aluminum tubes and interfere with the easy opening of the chair. Luckily Metric sized hinges are available, and 25 mm high backflap hinges work perfectly, they are slightly smaller than the width of the aluminum tube. The head of the hinge pin does need to be ground flat to keep the total width less than that of the aluminum tubes and larger #6 machine screws are needed.
Step 4:
With all 37 tubes lined up, they are attached together by running the 3/8" diameter threaded rod through both ends. Then by standing the slab of aluminum tubes vertically upright, the chair can be opened into its deployed, sitting configuration.
Total cost of the chair will be about $500 with many materials bought in bulk on eBay.
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Jewelry Challenge
    Jewelry Challenge
38 Discussions
Blondy65
2 years ago
Amazing! and Beautiful!
badgardener
2 years ago
It's so beautiful, and thank you for posting this. But I have to say, I don't think anyone's butt is going to be comfortable sitting on that for longer than a photo shoot.
java-jimbadgardener
Reply 2 years ago
I can imagine the chair being pretty comfortabel. Especially if you like to put in a cushion if you like it more cosy. I'd also like to build this one out of hardwood. Maybe it adds a bit to being cosy. Anyway, great design and implementation!
jim_chung
2 years ago
Well, as far as I have tried, it is really quite comfortable. A well fed North American butt does help.
JohnC430
2 years ago
It is a beautiful chair but is it comfortable to sit on for any prolonged time? I would think that with the 1" spaces between the slats it would feel uncomfortable after a while.
JohnC430
2 years ago
wow! really great project although it is very expensive in terms of cost of materials. I suppose it may be possible to make it in wood for a little lower cost. but thanks for sharing this wonderful idea.
jim_chungJohnC430
Reply 2 years ago
I understand. Though price is a relative quantity. The original, signed by the designer, sells for 2700 euros in Amsterdam.
FamilyGuy2006
2 years ago
I'm not clear why it doesn't slide flat. Is there something tying the front rod to the back rod while it is in use?
jim_chungFamilyGuy2006
Reply 2 years ago
It's just the friction between the ground on the two ends that keeps the chair from collapsing when sat on. For that reason, it won't work on a smooth surface like a ceramic tiled floor (I know from first hand experi-dent!)
DaveMcG
2 years ago
What a beautiful project! I commend your integrity in identifying the design owner. I only have 2 questions. 1) I can't see where you've identified the spacing for the 3/8 inch thru-holes. From the picture of the jig, I'd guess it to be about 3/4 of an inch in from the end. (?) 2) If one was to use hardwood, would 1x1 be substantial enough or should I try a 1x2 perhaps? Any help would be greatly appreciated. Thanks, Dave
jim_chungDaveMcG
Reply 2 years ago
Yes, the 3/8" hole should be about 3/4" from the end and I think a solid 1x1" wood strut should be strong enough, in some sort of hardwood.
RickyH88
2 years ago
I love the design. Is there a way to make the back more upright? I prefer to sit with my back a bit more vertical. Any idea what adjustments would be need to which lengths to achieve that?
jim_chungRickyH88
Reply 2 years ago
I believe if you shorten the cuts in the even numbered struts, you will have a more vertical back.
thundrepance
2 years ago
omigosh! coolest, most STYLIN' piece o' furniture i've ever seen, jim!! x^D
LeslieGeee
2 years ago
GORGEOUS chair!!!! Do you happen to have a diagram of the layout of the pieces according to size? That would be helpful :)
jim_chungLeslieGeee
Reply 2 years ago
I added a photo that might make the layout more clear.
LeslieGeeejim_chung
Reply 2 years ago
Thank you Jim :) The additional info is most appreciated.
mrsmerwin
2 years ago
how much weight can it hold? I would probably be making a wooden version.
