Keyboard Tip Trick Add a Little Dazzle to Your Frazzle
About: The most complex design is simple…
This trick tip will help to put an end to the frazzle.
A quick and easy way to add some flare, some dazzle.
What you need is a bead, one side is sticky.
Any size, any shape no need to be picky.
Clean the keys real good and remove all the icky.
The sticky can be a little tricky, take the time, do it right, soon you see, an end to your fight.
The key to this tip, the bead needs to stick.
I found these keys being the ones I continually missed, having to hunt and peck for... adding the beads was just enough feedback.
This has improved my hand and finger position and most of all keystroke accuracy.
I remembered  the basics from typing class. The "Home-Row" being the point of reference.  My fingers don't fit on a key board or the home -row. "One size fits all" doesn't apply to keyboards.  I made my own Home-Row where my hands and fingers position were comfortable, the keys I choose have worked for me.
I listed each row on the key board 1 thru 6  /  I added beads to 10 keys - The keys are listed for each row
   1st row:  "F KEYS" - NONE
   2nd row: 2-@  /  0-)  /  Delete
   3rd row: Tab
   4th row: J  /  Return-Enter
  5th row:  . / >
  6th row:  Command  /  ^- Arrow
Focus on being comfortable, everyone is different, take note to the your keystroke mistakes, because this is the end no more mistakes!
These keys are what I see as your Personal-Row.
* Go with the flow... typing isn't easy, it takes practice, focus on the habits you have,  to improve your skills.
* It's important to knowing the fundamentals, seating, posture, hand and finger position...
    • Pocket Sized Contest
    • Pie Contest
      Pie Contest
    • Trash to Treasure
      Trash to Treasure
    3 Discussions
    NorCalDomDream Dragon
    Reply 6 years ago on Introduction
    You are correct.
    The keys I used the most were my feedback keys:
    "2/@, delete, Directional Arrows, <,^ , and the 0 )."
    These work for me, and imagine it would be different for everyone.
    The basic idea is a quick way to reference, needing less visual confirmation, making it easier to navigate to the neighboring keys.
    Where there's Sparkle there will be Flare!
    Thanks for sharing!
