How to Build Project Enigma Minor
9,417
24
125
About: Hi! I'm Ruben, better known as RNB. I'm a student Mechanical Engineering and hence like to build contraptions related to that. I mostly make use of K'nex, which is convenient to use since it is easy to desig...
Here's my newest project - Enigma Minor. It's compact, has a lot of paths (5!) and looks cool. The name was suggested in my question "how shall I call my new K'nex ball machine" It looks like project Splat, but I modified it. My add - ons on Splat:
- 1 extra path: Freefall
- 2 kinds of path separators: the classic version and the Infinity-Switch
- 1 new element, that I've designed: the dual ball element. (on path 4 and 5)
- less pieces!
Good luck with building!
Step 1: Pieces
Here's the piece count!
Rods:
- Green: 244
- White: 138
- Blue: 289
- Yellow: 64
- Red: 1
- Grey: 9
Connectors:
- Grey 1 – way: 71
- Grey 2 – way: 9
- Orange 2 – way: 25
- Red 3 – way: 144
- Green 4 – way: 29
- Purple 4 – way: 106
- Yellow 5 – way: 137
- Blue 7 – way: 51
- White 8 – way: 35
Spacers:
- Blue: 50
- Gray: 37
Other:
- Blue clip: 4
- Tan clip: 4
- Y – clip: 26
- Blue hinge: 4
- Black hinge: 4
- Red gear: 6
- Chain: 46
- Battery motor with short lead: 1
- Original K’nex balls: 2 or 3
Total: 1537 pieces.
Step 2: Base
Let's start building! In this step, you'll make the base and the bottom gear. Good luck again!
Step 3: Receivers
A receiver's a path that brings a ball back to the lift. In this step you'll make them. Look carefully to the amount of spacers and where Y - clips are placed!
Step 4: Spiral-Bottom
Here's where you'll start building the Spiral. In the middle of the Spiral's the freefall. You'll also make that part yet. Look again carefully to the amount of spacers.
Step 5: Path 4 and 5
Now you'll make 3 elements at once; the new element, the switchback and the maze. It's a lot of work, so start with it!
Step 6: Spinner
This is the Spinner, a well - known element. This could be painful for your fingers, so be careful.
Step 7: Spiral-Top
Again a part of the spiral. These 2 elements (spiral and freefall) are the last elements you're going to make. Make sure to check the last picture. It includes a few changes to the rest of the pictures, if you don't change it it wan't work!
Step 8: Top - Left
Now you'll make the infinity-switch and a path separator. Good luck with 'em!
Step 9: Top - Right
This part includes 2 path separators. Look carefully to the connection points with the other parts!
Step 10: Motor-house
You're almost done! Just make the motor-house, and after that the chain.
Step 11: Chain Lift
Last part! Make 2 sets of 15 chains, and one of 16, with at the end a chain-claw.
Step 12: Finished!
You're done! If you're maze is stopping the balls, use gray connectors to stop the maze from going up. Thanks to tardis fan for this.
Have fun watching or changing it! Please give me pictures of your finished model, I'll add them to this step.
RNB
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    125 Discussions
    MisterBukweet
    6 years ago on Step 12
    I'm about to install the chain right now... after spending several hours on this project, the only thing I can find bad to say is.... You must have the tiniest little girl hands..... it was tough to get into many of the places to make connections.... I has been a much fun build and I can't wait to see it in action.... I'll be sure to send you a pic... thank you for a nice project
    RNBCrumble
    I started designing. I've 3 new lifts in mind, I'll go build it within a few weeks.
    Orangepanda
    hey RNB this ball machine is awesome!!!!!!!
    this is going to be my first ball ive built so thks for that!
    can i keep u updated on how im going because ive never made one before!
    thks if i can
    =D
    RNBCassisDude98
    Reply 7 years ago on Step 2
    Bedankt! Omdat deze baan zo'n succes is, heb ik besloten om door te gaan met de 'Enigma's'. Ik ben nu een gigantische baan aan het bouwen die Enigma Major heet, later komt er nog een Enigma Micro
    CassisDude98RNB
    Eigenlijk zou je ook instructies moeten moeten maken voor de Enigma Micro
    (hoeveel stukjes gaat die in beslag nemen?)
    Alvast bedankt!!!
    RNBCassisDude98
    Enigma Micro: Nog geen enkel idee :-P. Eerst bouw ik de Major, later komt Micro nog.
