LED Acrylic Glass Sign
10,022
261
7
About: Innovative Projects, Diy's, Life Hacks
In this Instructable, I made a LED acrylic sign.
You will need:
For the Sign:
  • Acrylic glass
I used a 100 X 80 X 5 mm sheet
  • Mini drill with diamond burr bits.
  • Stencil knife
  • Picture/print out for the stencil
For the base:
Instamorph moldable plastic
2 LED's with a battery holder, batteries and a switch
Step 1: For the Base
I melted the Instamorph and coloured it blue.
I used "no-brand" pigment.
Step 2: For the Base
I used a wooden box as a mould.
Instamorph should not be too hot or else it will stick to the box.
When I removed it from the mould, I reheated the bottom to cut it off.
Step 3: For the Base
To make sure batteries hold in place, I added more Instamorph.
Step 4: For the Base
More Instamorph was added on top to hold acrylic glass.
Step 5: For the Base
I drilled holes for LED's and the switch.
I soldered LED's and a switch to the battery holder.
Then I glued the switch to the case and inserted LED's.
Step 6: For the Base
I covered bottom of LED's with electrical tape and inserted the batteries.
Step 7: The LED Sign
I cut out the stencil and secured it to acrylic with the scotch tape.
Step 8: The LED Sign
Then I used diamond burr bits to colour the stencil.
Now you can put your art on top of the base and watch it shine.
If you get bored, change it.
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    7 Discussions
    Chris Weatherford
    3 years ago
    Great ible. I love your base.....I purchased this moldable plastic a couple weeks ago and haven't made anything yet but might have to after seeing this one. Nice job hand scribing the logo. That turned out great. I just did a simular project and used a dremel. Thanks for sharing.
    https://www.instructables.com/id/LED-Glowing-Floating-Picture-Frame/
    mcfunworld
    3 years ago
    NOT A PRO TIP: you can get multicoler lights with a controler from amazon and if I make one of these I'm gonna use that
    A great looking project, especially in the dark.
    Some tips for those who may want to build:
    A defunct monitor may provide a useful hunk of acrylic as well as Mylar for the stencil, which is used as a diffuser.
    Flame polishing the acrylic edges will give a nice finish to raw saw-cut edges after sanding or scraping, as well as transmitting the light in a more even fashion. Make the surfaces as smooth as possible and practice on scrap first, there is a small learning curve but once mastered, it will be with you forever. I use a simple propane torch for my work.
