LED Jewelry
16,052
445
33
About: Software developer during day, hardware maker at night.
Create yourself a unique necklace or earrings that will glow in the dark!
Step 1: Gather All the Tools and Material
The key to success is proper material and tools. Here is what you gonna need.
Tools:
  • Combination pliers
  • Round-nose pliers
  • Side cutters
  • Soldering station
  • Tweezers
  • Double sided tape
  • Piece of paper
Material:
  • 1mm straight brass rod
  • SMD 1206 LEDs
  • coin cell battery (CR2016, CR2025, CR2032, ..)
  • tin solder
  • soldering paste
Step 2: Start With Template
I always start with a paper template. It will help you to make a precise shape. You can use some of mine own template attached or you can create your own.
Step 3: Bend Wire Into Outline
Bend the brass rod using pliers into the shape of the outline. Take your time, make it nice.
Step 4: Solder the Outline Ends Together
Use a tiny amount of the soldering paste and tin to solder the ends of outline wire together. Soldering paste will help the tin to nicely adhere to the brass.
Step 5: Place the LEDs
Another magic is to use a double-sided tape as a third hand to hold the shape and LEDs in place while soldering. Use double-sided tape to hold the outline in the place. Put all the LEDs into the proper positions while the outline wire is still on tape and solder them. Keep in mind that the LEDs have electrical polarity. They need to be placed in the correct position in order to lit. Take a look at my template there is a graphic explaining how you need to place them.
Tip: Do not use different colors of the LEDs on the same necklace. Different colors have different voltage properties so you would end up only with one color lit.
Tip: Double-sided tape will lose its stickiness when heated. So you most likely have only one try to solder the LED to the brass.
Step 6: Connecting LEDs
Now you need to interconnect all the other leads of the LEDs together to create a proper electrical circuit. Again bend the wire, place it on tape and solder to the other ends of LEDs.
Step 7: Create Battery Holder
Solder a wire on the back of the necklace to create a pocket for a battery.
Step 8: Done
Now place a battery into the necklace and see how nicely it lit up! There are different types of coin batteries with different diameters and thickness. The only requirement is to use 3V battery. The battery depending on the size and number of LEDs used will last around 24h.
Step 9: Make More and Share!
Make whatever shape you like, the only requirement is to create a proper circuit for the battery to lit up the LEDs.
I am Jiri Praus.
www.jiripraus.cz
Jewelry Challenge
First Prize in the
Jewelry Challenge
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    33 Discussions
    Arx
    5 days ago
    This is nice and simple, but some leds won't be very reliable without any current limiting. Also, paralleled LEDs without any individual current limiting tend to hog current. This is the reason why cheap led flashlights with many paralleled LEDs tend to be uneven in brightness, and burn out over time.
    Unfortunately, there's probably not a really good way to properly limit the leds and keep the design as simple, so I guess you have to decide on a reduced lifespan (total life of the led, not per cell), or a slightly more complicated design.
    A single resistor in series with the coin holder set to limit the current to a safe value for a single led should reduce degradation over time, though it will also be less bright.
    IamTeknikArx
    Reply 2 days ago
    From an electronics point of view, this is pretty poor but its an awesome art project. As you say, no current limiting and the battery will die after about 1-2 hours of use. I think the best option would be to add small SMD resistors in series with each LED. 1206 is small but 0603 would be better and you wouldnt reduce the aesthetics of the project at all. If you can also find LED's with a Vf of 3.2V, it would naturally draw the rated current (somewhat) of about 15-20mA. Ill give this a go with 0603 LED's and series resistors for each LED. You could also get decorative with where you place the resistors.
    dejanf2
    7 days ago
    Amazing idea,very cool!
    Kiteman
    8 days ago on Step 9
    These are wonderful pieces - bravo!
    KarloHorcicka
    9 days ago
    This is amazing. I like hov you made that purple pentagram and tucked it behind out of focus. This idea is brilliant. I'll definetly make it
    vrsolanki
    10 days ago
    Very good simple and eligent design, just add smallest vibration sensor as switch to preserve battery and it will light only when needed !!
    Cat00x
    14 days ago
    I love this!!! Great way to combine electronics with jewelry. Very elegant design. Good luck in the contest.
    prnet
    14 days ago
    Very, very nice shaped. Amazing idea and realization.
    DbiswasB4D
    15 days ago
    excellent idea .
    kaz.sommers
    16 days ago
    How sweet is this idea, and so incredibly simple!
    Brilliant idea that I'm sure many young people will just love to wear to concerts etc. :)
    S0dyP0p
    17 days ago
    The brass wire & SMD's takes the old LED throwie concept to a whole new level. This is classy and so nerdy all at the same time!
    jiriprausHam-made
    Reply 18 days ago
    This guy is incredible! But my "sculptures" have to work :)
    jiriprausssbotrodriglez
    Answer 18 days ago
    You can either buy a coil probably in any shop that sells beads and jewelry imitations. Or you can buy a straight rod in hobby model shops - they use it for the construction of planes. It depends on where are you from.
