LED and Switch Modules for Prototyping Arduino Projects
2,675
49
12
About: Beginner maker who loves stargazing.
Hi! I come back with a tool to help you prototype arduino projects easier!!!
Many DIY Projects contain LED and switch. Building prototype circuit on breadboard costs a lot of space and time, and makes breadboard messy. So I came up with these 2 modules to help you reduce your amount of work on breadboard from LED and switch.
LED module can connect to 5 sources with common ground or individual ground.
Switch module contains 5 push button switch with pull-down resistor.
Supplies:
Step 1: Materials and Tools
Materials
  1. Perfboard
  2. 5x 360 ohm resistors (depend on your leds)
  3. 5x 10K ohm resistors
  4. 5x LED (color and size as you want, I used 3 mm red)
  5. 90 degree Pin Header
  6. 5x 6x6x5 mm Micro Switch Push Buttons
  7. 5x SS-12D00G3 SPDT Switchs
  8. 4x M3 x 10 mm screws
  9. 4x M3 nuts
  10. 3D Printed Parts (They are just mounting plates so you can use another things if you don't have 3d printer)
Tools
Basic tools such as screwdrivers, drill, utility knife, etc. Soldering tools
Step 2: Prepare Perfboard
  1. Cut out 2 pieces of 14*25 dots from perfboard.
  2. Drill four 7/64" holes on those plates. (see the positions of the holes in the pictures)
TIPS:
An easy way to cut the perfboard is to score both sides with utility knife and snap it.
Step 3: Prepare Components
  1. Cut out
    • 2 pieces of 1x3 pin and 3 pieces of 1x2 pin for LED module
    • 2 pieces of 1x3 pin and 3 pieces of 1 pin for switch module
  2. Bend resisters' legs into 90° angles. Resistor lead forming tool is a very helpful tool to help you do this process. You can print it out from thingiverse.
Step 4: LED Module
Put and solder all components on the perfboard. (see more details in pictures)
TIPS:
You can use components' legs that you cut out as wires.
NOTES:
The graphic pictures are not exactly 100% accurate, so please also see the actual pictures.
Step 5: Switch Module
NOTES:
Step 6: Attach to Mounting Plate
Put the screws through nuts and attach circuit boards to mounting plates. (There is no need for using nuts if your screws are shorter than 8mm.) Use only 2 of them because the position on the circuit boards and mounting plates do not exactly match.
Now it's ready to use!!!
Step 7: One More Things...
  • Thank you to my sister who helped me writing these instructions in English.
  • Thank you for visiting.
If you like this project, please vote me : ) and don't forget to follow my Youtube Channel and my instructables.
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    12 Discussions
    Luke Wilson
    1 year ago
    So, from my understanding/interpretation of this project, this is just like a continuity tester to verify if certain parts of circuits you make in future projects work as planned with out having to waste the time making a new one on your breadboard for every project. That is so cool!
    Mike63Luke Wilson
    Reply 1 year ago
    And it leaves more open real estate on your breadboard for something else, or possibly don't even need the breadboard.
    Orion MakerLuke Wilson
    Reply 1 year ago
    Yeah!!! You describe my project better than me.
    PS. Sorry for very delay reply.
    Luke WilsonOrion Maker
    Reply 1 year ago
    No, that's fine, and thanks.
    If you're able to edit an instructable after it is published (I'm not sure, I haven't finished any that I'm working on yet...) you can add my description (after adapting tense etc.) to your description if you want.
    You've done a really good job on this Instructable, I think the photos are extremely good too. When I get time, (and source the parts - it's a real hassle when there are no hobby/electronics stores etc. within 60 miles of me,) I'll give it a go.
    Thanks again. :)
    fixit9660
    1 year ago
    Nice clean general purpose addition! Could you include the fritzing files too please?
    Orion Makerfixit9660
    Reply 1 year ago
    Thanks. I am glad that you like it. Now I add fritzing files to step4 and step5. But I am not sure that how much they will help you. I am quite new for this program. Check how I wired in fritzing files and Schematic in feitzing files that has Schematic in name. If you still have problems, feel free to contact me : )
    Maker_Inc
    1 year ago
    Its not a useful project for most application but i love how clean you made it .
    Nice Project.
    Orion MakerMaker_Inc
    Reply 1 year ago
    Thanks. I am glad that you like it. I always play with buttons and LED, so I love it : )
    Mike63
    1 year ago
    Nicely done, I like how clean you did yours. https://hackaday.io/project/9305-breadboard-extenders
    Orion MakerMike63
    Reply 1 year ago
    Thanks. I am glad that you like it. Your project is nice too. Maybe I will use your project to help working with breadboard easier.
    BeachsideHank
    1 year ago
    I like that you credit the help of your sister in making this Instructable understandable for English readers. ☺
    Orion MakerBeachsideHank
    Reply 1 year ago
    : ) She helps me a lot with making sure that I write what I really mean (even this comment XP)
