LM386 Audio Amplifier
328,690
309
167
I wanted to design an audio amplification circuit for a future project so i just wanted to design this one for now so i get an understanding of how it works. This is a very basic circuit that you can find all over using an LM386 integrated circuit i got from RadioShack.
Supplies:
Step 1: Obtain Parts
All Components can be found at RadioShack.
Multipurpose PCB with 417 Holes
5-15 Volt DC power supply (4 AA or 1 9v Battery)
8 Ohm Speaker
Audio Source e.g. iPod
8-Pin Retention Contact
IC1    IC                           LM386 Audio Amp IC
R1     Resistor               10 Ohm
R2     Resistor               1K Ohm
R3     Potentiometer     10K Ohm
R4     Resistor               10 Ohm
C1     Capacitor             220 Micro Farad
C2     Capacitor             10 Micro Farad
C3     Capacitor             220 Micro Farad
Step 2: Place Components
Arrange components the best you can using the wiring diagram. i placed them as close together as i could, but it may be easier to spread them out a little more or breadboard this circuit first.  I highly suggest breadboarding first just to get a feel of the arrangement, prior to soldering.
Step 3: Observe Diagram
Look through the wiring diagram to see what components need to be connected to what prior to soldering.  This is a basic wiring diagram, one of a hundred I found online, very basic. The one i used was from this website http://www.rason.org/Projects/icamps/icamps.htm.
Step 4: Solder Components
Solder components carefully to ensure there are no shorts, also ensure all connections are made at all points.
Step 5: Clean Up and Test
Trim component leads and clean solder joints. Be sure to double check connections to make sure a connection isn't left out.  Hook up a 5-15 Volt DC power supply, your audio source, and 8 Ohm speaker and test it out.  Be sure to ground out the audio sources audio low line and ground out the speakers ground wire to the circuits ground.
7 People Made This Project!
  • Party Challenge
    Party Challenge
  • Woodworking Contest
    Woodworking Contest
167 Discussions
deepu9422
2 years ago
How do i make it for 2 speakers(L & R) ,Do I have to make 2 of them?
Zeeshan gohar
2 years ago
c1 220 uF with batery ,,what is the function ??
Joe3502
2 years ago
Can I use an nte823?
patrickjane79
2 years ago
hii ..can you suggest a different ic tht can produce a 1-2 watt output
Quirc
2 years ago
Just a little question, the R4 resistor wasn't supposed to be placed before C3? I mean, at some point, the 220uF electrolytic will charge and won't allow the current to flow, right?
vivster13
3 years ago
This may be a dumb question but where do i connect the battery's positive and negative terminals specifically?
JGUZMANO
3 years ago
great and simple amp. Thanks for sharing. Room for probably a stupid and repeated question? How much current / power could this amp drive?
trax_e_rev
3 years ago
Pot on the output seemed to work better for me
Quick question, and hopefully not a stupid one. How do I connect the audio input to this circuit? What kind of cord should I use? I have tried using a 2-wire cord and grounded the black cord, using the red as the input. That gave me some sound with lots of garbage. I spliced a set of earbuds and have a red, black, and green wire. Would this work? Please somebody help!
DanielC225chris.dwyer.1238
Reply 3 years ago
green is left red is Right black is grond.
Connect green and red to the input pin and black to ground and that should work
HighEndMer4rony
Reply 3 years ago
I think it'll work, but it'll draw more current than 8 ohm speakers for the same volume, since this amp is made for the latter
ClaytonB8
3 years ago
I actually have an application for the noise. Please tell me how to use pin 5 to aggravate the noise.
