LOW COST DIY 500€ CNC MILL
58,405
540
45
About: I am a 20 years old student from Germany who love to make things. Later I want to become an Electrical Engineer :-)
Hi,
in this Instructable I want to show you, how you can build your own CNC-Mill for less then 500€. I designed this machine for CNC-beginners, who don't want to spend a lot of money for their first experiences with CNC machines but also expecting a rigid and professional looking CNC.
This machine is perfect for maker, tinkerer and everyone who wants to start CNC-Machining.
In the pricerange of sub 500€ you will not find any other CNC with these features:
  • 710 Watt spindle motor
  • MGN linear-rails on all axis
  • 1204 ballscrews on all axis
  • effective workarea of 250x220mm
  • max. travelspeed of 3000mm/min (at 12V)
  • high accuracy of 0.1mm in all axis
  • super rigidportal frame (out of one piece of wood and aluminium extrusions)
Below on this site, you will find a detailed instruction + a bill of materials (BOM) with links, where you can source the required parts.
The complete CNC is build out of CNC milled screen printing wood plates. So assembling will not be a problem. For the build you don't need any expensive tools like (3D-Printers, CNC or Lasers). The only special tool is a M5 and M6 thread cutter.
Video of CNC in action:
If you like my Instructable, please vote for me in the Build a Tool Contest
You can see the CNC live at Makerfaire Ruhr 2019
I really like to see, when someone has rebuilded the CNC, so please post a photo of the CNC in the comments with "I made it" :-)
Change Log:
  • [06.03.2019] Added step "Configure Estlcam for This Machine" + video of test run
  • [07.03.2019] Added video of CNC in action
  • [15.03.2019] Added photo of Linear Parts
Supplies:
Step 1: Mechanical Parts
The complete CNC is designed in Fusion 360, below you will see the complete CNC in an interactive 3D-model:
Required Parts:
CNC-Milled-Parts:
Here are all required CNC-milled parts. You can buy all the CNC-milled parts in my Online Shop. The total cost of all the CNC-milled parts will be 150€ + shipping.
QuantityDescriptionHow the part looks like
1x
Y_Axis_Front
1x
Y_Axis_Rear
1x
Y_Axis_Nut
2x
Portal_Side
1x
Portal
1x
X_Motor
1x
X_Bearing
1x
X_Carriage
1x
Z_Motor
1x
Z_Plate_Front
2x
(normal+mirror)
Z_Plate_Side
1x
Spindle_Mount
1x
Main_Plate
Aluminium Extrusion Parts:
I am trying to use as much standart aluminium extrusion parts, so it will be relativly easy to source the parts.
QuantityDescriptionLinkPrice
10x2040 extrusion angle bracket
Aliexpress9,10€ (for 20 pieces)
2x428mm 20x20mm aluminium extrusion 6mm slot
dold-mechatronik2,07€
2x400mm 20x40mm aluminium extrusion 6mm slot
dold-mechatronik3,70€
1x330mm 20x60mm aluminium extrusion 5mm slot
dold-mechatronik4,26€
Nuts, Screws and Washers:
I am trying to be as accurate as possible while counting all the screws and nuts. If you find any fault on the list, please tell me, so I can update the parts list. Also I recommend to buy some more screws.
QuantityDescriptionWhere to buy
Price
84xM3 T-slot Nut Slot 6mm
Aliexpress
5,60€
40xM4 T-slot Nut Slot 6mm
Aliexpress
5,60€
32xM4x20mm DIN912 cylinderhead screw
local hardware store
32x
M4x16mm DIN912 cylinderhead screw
8xM4x12mm DIN912 cylinderhead screw
8xM3x16mm DIN912 cylinderhead screw
52xM3x12mm DIN912 cylinderhead screw
8xM3x10mm DIN912 cylindergead screw
84xM3x8mm DIN912 cylinderhead screw
6x
M5x20mm DIN912 cylinderhead screw
12x
M5x10mm DIN912 cylinderhead screw
16x
M6x20mm DIN912 cylinderhead screw
8xM3 nylon nut
24xM4 nylon nut
8xM3 washer
6xM5 washer
80xM4 washer
16xM6 washer
Linear parts and custom machined ballscrews:
For the CNC mill you will need three custom machined 1204 ballscrews. I have attached a drawing with the dimesions at the bottom of this step. Additionally you will need MGN12 linear rails, ballscrew, bearings and housings. Because it was a littlebit hard to source all the parts, I contacted a manufacture, who can supply all these parts for a resonable price. This manufacture will also make the custom machined ballscrews. You can buy all the parts here: Aliexpress
QuantityDescription
1x
1204 Ballscrew 425mm
1x
1204 Ballscrew 395mm
1x
1204 Ballscrew 200mm
4x
400mm MGN12 Linear Rail
2x
250mm MGN12 Linear Rail
12x
MGN12H Linear Rail Wagon
2x
FF10 Ballscrew Bearing
3x
24mm 1204 Ballscrew Housing
3x
5 to 8mm shaft coupler (rigid ; not the red or flexible)
Step 2: Electrical Parts
Electrical Parts for the CNC:
Here you will find all the required electronic parts for the CNC mill. For the router you can use the Katsu from Amazon or a Makita RT0700C. Both will fit to the CNC-milled parts.
1x710W 230V spindle motor
Amazon59,99€
3xinductive limit switches NPN
Aliexpress4,44€
3x
Nema 17 Motors
Stepper-Online33,00 €
1xArduino Uno + CNC-Shield + DRV8825
Aliexpress9,76€
1x12V Powersupply 5A
Aliexpress7,05€
some
wires
Step 3: The Main Frame
What you need for this step:
QuantityDescription
32x
32x
M3-T-Slot-Nut 6mm-Slot
2x
400mm MGN12 Linear-Rail
4x
MGN12H-Linear-Rail-Wagon
1x
Y_Axis_Front
1x
Y_Axis_Rear
8x
8x
M6 washer
2x
What you have to do:
At frist you have to cut eight M6 threads inside the aluminium extrusions. After that you need to attach the MGN12 linear rails to the alumnium extrusions by using the M3x8mm screws. Then you have to take the two wood parts and attach them to the aluminium extrusion with eight M6x20mm screws.
Step 4: Y-Ball-Screw
QuantityDescription
8x
4x
M3-nylon nut
8x
M3-washer
1x
FK10 Bearing
1x
1204-ballscrew housing
1x
395mm 1204-ballscrew with custom end-machining
1x
Nema 17 Stepper Motor
1x
5x8mm shaft-coupler
Now it is time to install the Y-ballscrew to the main frame. At first install the Nema 17-motor to the rear plate and fix it with four M3x16mm screws. Then you can slide the 395mm ballscrew in. Once the ballscrew is in place, attach the FK10 bearing at the front plate. The FK10 bearing is fixed by four M3x16mm screws and M3-nylon nuts.
Step 5: Y-Ballscrew Plate
QuantityDescription
4x
1x
Y_Axis_Nut
For that step, you have to install the Y_Axis_Nut plate to the ballscrew housing. You do that with four M5x10mm screws.
Step 6: The Portal Side
QuantityDescription
4x
4x
M4-T-slot nut 5mm Slot
1x
330mm 60x20mm aluminium extrusion 5mm slot
6x
6x
M5 washer
16x
16x
M3 washer
2x
Portal_Side
At first you have to connect the two Portal_Side plates to the linear wagons. After that you have to attach the 60x20mm extrusion to the Portal_Side plates by using the six M5 screws. Finally connect the ballscrew housing from the previous step to the extrusion.
Step 7: The Main Plate
QuantityDescription
1x
Main_Plate
16x
M6 hammer nut
You have to hammer the 16 hammer nuts to the predrilled holes.
Step 8: Attach the Main Plate to the Main Frame.
QuantityDescription
8x
8x
M4 T-Slot mut 6mm slot
8x
M4 washer
You have to connect the preassembled Main_Plate to the main frame. The connection is made with eight M4x12mm screws.
Step 9: Portal
QuantityDescription
32x
32x
M3-T-slot nut 6mm slot
8x
8x
32x
M4 washer
2x
4x
MGN12H Linear Wagon
2x
428mm 20x20mm 6mm slot aluminium extrusions
4x
4020 angle bracket
1x
portal plate
At first you have to connect the linear rail to the aluminium extrusion.Then place the extrusions on the portal plate. Now screw the extrusions to the extrusions. Don't forget to place the angle brackets.
Step 10: X-Ballscrew
QuantityDescription
4x
M3x10mm DIN912 cylinderhead screw
4x
8x
M3 washer
4x
M3 nylon nut
1x
425mm 1204 Ballscrew
1x
1204 24mm Ballscrew housing
1x
5x8mm coupler
4x
4x
M6 washer
1x
Nema 17 Motor
1x
X_Bearing
1x
X_Motor
1x
FF10 Bearing
You have to place the ballscrew between the two linear rails. The connection of the motor and the FF10 bearing is made by four M6 screws. Don't forget to cut the four M6 threads to the aluminium extrusions.
Step 11: X-Carriage
QuantityDescription
4x
32x
32x
M3 washer
1x
X-Carriage plate
Connect the X-Carriage plate to the linear wagons by using the M3x12mm screws and the predrilled holes.
Step 12: Z-Axis Part 1:
QuantityDescription
1x
Z-Plate_Front
2x
2x
250mm 20x20 aluminium extrusions
8x
M4x16 DIN912 cylinderhead screw
16x
M4 washer
8x
M4 t slot nut
20x
20x
M3 t slot nut
Connect the linear rails to the extrusions by using the M3x8mm screws. After that attach the extrusions to the Z_Plate_Front .
Step 13: Z-Axis Part 2:
QuantityDescription
1x
Spindle_Mount plate
1x
Z_Motor plate
4x
M6x20mm DIN912 screws
4x
M6 washer
Connect the Spindle_Mount at the bottom of the Z-Axis and the and the Z_Motor plate at the top of the Z-axis. Don't forget to cut a M6 thread inside the extrusions.
Step 14: Z-Axis Part 3:
QuantityDescription
2x
Z_Plate_Side
8x
16x
M4 washer
8x
M4 T-slot-nut
Place the Z_Plate_Side plates at the side of the Z-axis. Then connect them with the M4x16mm screws
Step 15: Z-Axis Part 4:
QuantityDescription
1x
Nema17 Motor
4xM3x10mm DIN912 cylinderhead screw
1x
200mm 1204 Ballscrew
1x
1x
5x8mm shaft coupler
Attach the Nema 17 motor to the predrilled holes and connect it with four M3x10mm screws. After that connect the ballscrew to the Nema 17 motor with the 5x8mm shaft coupler.
Step 16: Connect the Z-Axis and the Portal
QuantityDescription
4x
M5x16mm DIN912 cylinderhead screw
4xM5 washer
Slide the Z-Axis into the linear wagons on the X-Carriage. Then connect the Z-ballscrew to the X-Carriage with four M5x16mm screws.
Step 17: Connect the Portal to the Main Frame
QuantityDescription
6x
2040 angle bracket
32x
M4x20mm DIN912 screws
64x
M4 washer
32xM4 nylon nut
Finally connect the portal to the main frame. You do this by using six additional angle brackets. All the requiered holes are predrilled. Please take a look at the pictures, where the angle brackets are located.
Step 18: Prepare the Spindle
For the connection between the spindle and the machine, I am using the allready existing spindle mount. You simply need to remove the plastic part at the bottom of the mount.
Step 19: Attach the Spindle Mount to the Machine
QuantityDescription
4x
M4x16mm DIN912 cylinder head screw
4x
M4 washer
1x
Spindle mount
Place the spindle mount on the Z-axis. Then connect it to the Z-axis with four M4x16mm screws. Once completed, you can slide the spindle inside the spindle mount.
Step 20: Electronics
For the electronics I am using an Arduino Uno with a CNC-shield. This is the cheapest methode to controll the CNC.
For the connection you have to connect the X-Motor to the X-Motor-Port, the Y-Motor to the Y-Motor-Port and the Z-Motor to the Z-Motor Port. Then you have to connect 12V to the board at the blue terminal pins. After that connect it to your PC and flash the software (GRBL or ESTLCAM) to the Arduino.
Now you should be able to move your machine.
(coming soon):
On the machine there are also holders for inductive 12mm end switches in the CNC milled frame. I am still waiting for delivery, so when they arrieved, I will update the instruction.
Step 21: Software
To controll the machine you need 3 types of software:
1. CAD software:
Inside the CAD software you create your 3D-File, which you want to manufature. I personally use Fusion360 for this kind of application.
2.CAM software:
In the CAM software you define the tool path of your CNC machine, here you can also use Fusion360, because it has a build in CAM-module.
3. G-code Sender:
The G-code sender took the G-code file, from the CAM-Software and sends it to the controller of the machine. Because I am using an Arduino as the controller you can use GRBL as a software on the Arduino and a G-code sender like "Univerversal-Gcode-Sender" or "bcnc"
As an alternative I also want to mention Estlcam. In Estlcam, the CAM and controller part are combined in one software (If you use an Arduino as your controller). Also it is more simple to use compared to other CAM Software.
Step 22: Configure Estlcam for This Machine
I personally recommend to use Estlcam over GRBL for this CNC because of these aspects:
  • It is a lot easier to configurate than GRBL
  • It has a build in CAM, so you don't need any additional Software
  • Controller and CAM are combined in one Software
Now I want to show you which configuration you have to do, that the machine will work propably:
1. Open Estlcam and go to "Einstellungen" then click on "CNC Steuerung"
2. After that a window will open with some configurations. There you will see all the basic values for this machine. Once you have all the settings like in the picture, connect your Arduino to your computer, select the right COM-Port, click on "Steuerung-Programmieren":
3. If the programming of the Arduino was a success, close "Estlcam" and open "CNC-Controller". Now you should be able to move your machine.
4.Here is a video of the test-file. The test file can be downloaded at the bottom of this step. The feedrate in the testfile is 2400mm/min.
Step 23: CNC-Milled Results
Here I will show you some CNC-milled parts, which where milled on this machine. ( list will be extended in the future )
Second Prize in the
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    45 Discussions
    MarkusK39
    Question 13 days ago
    Do the arduino need cooling or could i just asamble it in a box?
    VulcamanWafflerun01
    Answer 4 weeks ago
    The Z-axis needs to be zeroed manually. Because your Z-zero depends on the workpiece, you want to mill, you have to define the zero point first in your CAM. After that you move your mill to the disered zero Z-Point. Finally you set the Zero point in the controll software.
    doncore
    2 months ago
    Danke für das Gespräch auf der Maker Faire!
    Viel Glück beim Wettbewerb. Habt meine Stimme.
    Vulcamandoncore
    Reply 2 months ago
    Freut mich zu höhren, dass es ihnen gefallen hat. Vielleicht sieht man sich irgendwo ja nochmal :-)
    aleteck
    2 months ago
    Excellent guide, really well made and useful.
    I have only one question: how did you align axis? How do you guarantee the perfect coplanarity of the X-Y axis and the perpendicularity between the 3 axes? Are there any adjustments?
    Thank you
    scottie_dog
    Question 2 months ago
    Wow, an excellent Instructable. Voted up!
    The kit of parts you offer looks like very good value. I wondered if you have any plans to offer a more complete kit of parts - perhaps everything except the router? I love that you've given sources for all the parts - but if I could buy everything from you as a kit I would do so right now.
    I've been wanting to build a CNC machine from scratch or a kit for a long time, and in recent weeks have decided I finally will do so in the very near future. I think this will be the project I choose.
    Great work!
    1 answer
    Vulcamanscottie_dog
    Answer 2 months ago
    I don't have plans to offer a more complete set, because it will be not possible create a complete CNC kit for sub 500€. This machine is so cheap, because you need to source all the parts by yourself. Also I have to invest a lot of money to order all the parts in a decent amount, which I can not afford.
    scottie_dog
    2 months ago on Introduction
    Me again. Just voted for you in the Make a Tool competition. Good luck with that.
    You've probably already thought about crowdfunding: if you were thinking of offering a complete kit of parts you'd obviously have some upfront costs in obtaining everything and holding stock. A crowdfunder would be a great way to get the money to be able to start offering full kits. I am sure it would be popular.
    DewulfS
    2 months ago
    Very nice instructables, one of the very best i have ever seen! Every part explained very well, i can't wait to start building mine! :)
    VulcamanDewulfS
    Reply 2 months ago
    Thanks for your feedback! I can't wait to see your version of the CNC :-)
    MarshReyno
    Question 2 months ago on Introduction
    I have access at work to a CNC. Would it be possible for me to purchase the CAD files so I can cut the pieces here in the US? I just want one for my workshop at home. Close to retirement and want a CNC for my enjoyment. If I was to convert all of the parts to items that were available here in the US would you want to do another Instructable with parts easily available in the US? Just a thought.
    By the way your Instructables are very clear and very easy to follow.
    1 answer
    VulcamanMarshReyno
    Answer 2 months ago
    Thanks for your feedback :-) . I don't want to sell the CAD-Files, but if you need to take measurements for your own DIY-CNC, you can take a look at the interactive 3D-Model. At the bottom of the model is a measurement function.
    neilscott100
    very impressive, the parts that you sell to make the mill do you create these on this mill? m based in spain and am very interested in this, I only use Mac though, would it be compatible with OSX.
    1 answer
    Vulcamanneilscott100
    Answer 2 months ago
    The parts I sell are not milled on this machine, because the machine is not big enough to mill their own parts. I have another DIY CNC-Mill (completly different design) out of aluminium, where I can mill all these parts very accurate and in a decent speed.
    I think this machine will also work with a Mac if you use this software combination: Fusion360 for CAM, bcnc or UGS for Gcode-Sender and GRBL on the Arduino. Sadly Estlcam will not work on a Mac, but for GRBL there a lot of tutorials in the internet, how you have to set it up.
    ValentinJ2
    Your instructable is great. I'm looking forward to see the videos. Can you upload the step files of the CNC-milled parts? Or do we have to buy them from you?
    Thanks
    VulcamanValentinJ2
    Answer 2 months ago
    I have added a video of the CNC in the introduction :-)
    VulcamanValentinJ2
    Answer 2 months ago
    I will upload a video in the next week. I don't want to upload the step files, but if you need to take measurements, you can use the interactive 3D-Modell. There you can take all the dimensions you need. (There is a measurement tool at the bottom of the viewer)
    PyrusBoy
    2 months ago on Step 20
    Are you going to publish your Arduino sketch file ? Please.
    Don't want to buy frame parts without the ".ino" file.
    Thanks
    VulcamanPyrusBoy
    Reply 2 months ago
    Thanks for your feedback. I will publish the config files for the Arduino tomorrow. However, please take a look at Estlcam, it is super easy to configure. In Estlcam you only need to set your dimensions, steps per mm and max. feedrates. Then Estlcam will flash the Arduino automaticly. And you are done with the configuration.
