Laser Cut MDF Fidget Spinner
2,373
28
Here are some Fidget Spinners I made.
The small ones are 65 mm in diameter. For small hands. eg under 12 Years olds.
The large ones are 90 mm in diameter. Standard size.
I cut the brass inserts (photos and drawing later.) on a metalwork lathe from 20mm solid brass. 8mm insert press fit.
Step 1: This Is Just a Trial. My First Upload.
Ill add when I know it works.
Thanks
Adrian
Step 2: Materials
22mm Skate bearings
5/16" - 13.2 mm AF Nuts
3/8" - 15mm AF nuts
6mm MDF
Step 3: Files.
Inventor and DXF files.
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    2 Discussions
    Kris82
    1 year ago
    What type of glue did you use?
    Swansong
    1 year ago
    Those are all fun designs :) I like the big one on the top right the best.
