Laser Cut Ping Pong Set
1,766
21
About: microengineering student at heig-vd
Hi, this is a small, but awesome all in one ping pong set, made of laser cut wood.
You can bring in anywhere with you, and can be used, on tables / bench / ground / car roof...., you will always find a place to play with this small and fun ping pong set!
You need to cut both .dxf  files.
Red lines are supposed to be printed first.
If you don't want to edit the files, then you have to use 6 mm wood.
Once cut, use standard wood glue, and glue the case together.
You can already play, while the case is drying!
Have fun!
More information at : http://www.victorjung.net and search for ping pong or go directly to:
http://victorjung.net/?p=57
This project is also on thingivers: http://www.thingiverse.com/thing:196722
Supplies:
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    jayludden
    4 years ago on Introduction
    THIS IS AWESOME. I should make it for my brother's birthday. He would love it.
