Laser From Dead Computer
60,252
256
31
About: love the outdoors, technology, reading, drawing, and much more.
Here’s another neat way to make use of that old computer that has been lying around your house: Turn it into a red burning laser using parts salvaged from the dead computer. The burning laser is powerful enough for you to wear safety goggles.
The components you need to salvage are: the power supply, DVD Burner (16x speed or more), and the heatsink. The DVD Burner provides the laser diode which is housed in the heatsink proofing. The PSU and the right wires are connected to the heatsink and the laser module. That’s it! The heatsink helps to run the laser long enough to burn through things like plastic and ignite matches.
Supplies:
Step 1: Key Points
Sorry they're out of order.
Step 2: Credits
I give all credit for this idea to YouTube user styropyro . Please support him however you can. He has great ideas. Here is a link to his YouTube page  <http://www.youtube.com/user/styropyro>
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    31 Discussions
    Ravirarmondeluz
    Reply 5 years ago on Introduction
    These lasers can sometimes be used as weapons if you have enough power. See
    The are also fun to put in a laser gun prop so that it actually works to cut paper or something to show your friends. They are pretty awesome lasers.
    pokemech
    6 years ago
    I almost can't wait for my computer to die now... its got WAY higher than 16x. >:)
    slaserjlstaničić
    The plastic lens will not melt because the plastic is clear. The lens will not absorb the light and therefore will not melt. The same is true for white materials and other light colors. These lasers will only burn dark colored objects because they absorb the light. If anyone wands to explain this in more "scientific" detail, please do.
    werdna223
    does anybody know if a 5mW diode now can be turned into this( limited through resistor power so not full power 5mW
    werdna223
    no you cant use a Magnavox, i tried and forund it has a wrong diode it is more advanced
    sniper shot
    wow,its a lot like the thermal discouragement beam from portal 2
    mondeluz
    a better way how to get laser diode from dvd burner
    http://www.youtube.com/watch?v=fWHFu7uJnpU
