Lavender Oil Printed Shirt
4,216
57
23
Introduction: Lavender Oil Printed Shirt
About: Hi, I'm Bine and I like to create stuff. I'm always interested in learning new skills and my hobby room is full of things which I tried already and others which are still on my bucket list. I like to misuse...
Do you have a nice black and white print that you wish to have on a shirt? For example on the sleeve or at the left lower corner, but your preferred shirt print company doesn't print in this areas?
Just do it yourself. Without screen printing (yes, I know, it is also really cool, but it takes a while to master it) or thermo-tranfer prints (which have usually this "invisible" area without color, which can be still seen).
Just your black print and some drops of essential lavender oil.
You don't believe me? Just give it a try…
Step 1: Material and Tools
What you need:
  • Print from a laser printer (ink jet printers don't work) or a black and white laser copy from your copy shop
  • Essential/ethereal lavender oil (I bought a cheap one from a local drugstore)
  • A shirt or fabric bag in a bright color
  • Parchment paper, to avoid oil stains on your table and backside of the shirt
  • Some tape to fix your print
  • A stainless steel spoon
  • A hot iron
Step 2: Transferring the Print on Your Shirt
Yes, I know, you want to start immediately, but it's better to give it a try first, than to ruin your shirt.
  1. Print some smaller images with the same printer for a pre-trial. If you have the chance use different printers (your own, that one at the office, the one at your friends place) It took me two trials, until I realized that the printer from my office is somehow not working.
  2. Take a scrap piece of fabric or a similar fabric to the one you want to print on. I realized that for me a knitted jersey worked much better, than a stiff woven fabric, but maybe it was also because of the laser toner.
  3. Follow the steps below :-)
Now you are ready for the real game
    1. Laser print your chosen image in black, make sure that you flipped it horizontally (if it contains letters, double check that it is flipped before printing)
    2. Set a piece of parchment paper inside your shirt, this avoids the oil and the color to be transferred to the backside of the shirt
    3. Fix your shirt on a hard underground
    4. Fix your print upside down on the shirt
    5. Gently drop some oil on the paper. Smoothly spread it over the paper until everything is oily, but there are no "lakes" on the paper, I used a scrap piece of paper for that, but you could also use a brush
    6. Rub gently with the spoon over the printed areas, try not to move the paper, otherwise the toner will leak and your print will be fuzzy.
    7. Repeat for a while and have a careful peak view.
    8. If there are areas which aren't transferred in a satisfying way, you can add a drop more and rub again
    9. If you think you're finished lift the paper and have a look :-)
    10. Yeah, it worked :-)
    Step 3: Fixing the Toner
    Now you need to fix the color on the fabric
    1. Place the parchment paper below and above your print.
    2. Hot iron for 3 min with the recommended heat for your shirt.
    3. The leftover ethereal liquids in the shirt will vaporize due to the heat, so please make sure you're ironing at a good ventilated place (or directly outside)
    4. If there are leftover oil stains, you can treat the printed area with some extra soap before the next washing. The color will also be a little bit lighter after washing and drying, but it is a really nice effect :-)
    Actually I only wanted the print on the front side of the shirt, but since this technique is so much fun, I took a smaller print, cut out the words and transferred it to the backside of the shirt. Now I need to find the next print and shirt, because there is still so much ethereal oil left... :-)
    Step 4: Explanation How It Works, Try and Error
    Unfortunately I'm not a chemical engineer, and therefore I can't explain the real chemical processes that happen during this ethereal lavender oil print. But the explanation I made to myself would be that some components in the oil are dissolving the toner, which is actually a powder activated by heat, and therefore transfer it to the fabric.
    The hot ironing process fixes the loosened toner to the shirt and vaporizes the leftover ethereal components from the oil until only the "oily" part is left, but this part will disappear in next washing.
    This didn't work out for me:
    color printed picture on canvas - somehow either the color doesn't dilute or the fabric is too coarsely woven
    black and red print from my office printer on jersey
    Oil Contest
    First Prize in the
    Oil Contest
      • Metalworking Contest
      • Game Life Contest
        Game Life Contest
      • Fix It! Contest
        Fix It! Contest
      23 Discussions
      Is it possible to use other essential oils or does it only work with lavender?
      Acetone and xylene have been used as solvents in other instructables to transfer toner from printer paper to other surfaces.
      It worked for me with peppermint oil!
      Excellent exactly what i needed?? Does it work for coloured prints?? And does anyother essential oil works???
      2 more answers
      Hi, that's great :-)
      In my case it didn't work for the colored prints, but maybe because of the printer, I don't know. I haven't tried it with other oils, but if I will try it, I will let you know :-)
      attosa
      9 days ago
      This is so interesting! I'd love to try this!
      Thank you.
      Matlek
      11 days ago
      Very interesting and cool! I'll try :)
      Thank you. Yes, you should try it, it's really cool to see that it works :-)
      Riffifi
      Tip 12 days ago
      when i was in art school i knew a woman who liked to transfer photocopies onto other paper, someone else tried the same process on a sheet of latex and it workd too. they used trichlorethylene as a solvant for the toner to transfer, so i guess lavender oil contains a similar chemical. but unlike the trichlorethylene, at least lavender oil smells good and you don't need a gas mask to use it :D
      Thank you for the tip. I will try it on other material, until now I just used it on fabric. But maybe it also works for the transfer to PP material.
      This is a really unique project, and it is very well documented. Your instructions are clear and complete, and your photos are very well done.
      Toner is, I think, a kind of fine plastic dust, which is heat-fused onto paper. It has a static electric charge, which allows it to be temporarily stuck to the paper inside the printer before fusing. I imagine that the oil is able to penetrate the paper fibers enough to loosen the adhesion enough to make some of the toner particles transfer to the fabric.
      I never would have thought of this kind of application. I like it a lot, and now must think of something that I wish to transfer to cloth.
      How does it take the washing? I am wondering if the toner crumbles and falls in the washer, or stays put.
      Interesting! And well done
      That is really cool and unusual! :) Will definitely try that out, thanks!
