Leather Chessboard
3,669
73
7
How to make your own leather Chessboard (pieces not included :)
You will need...
1 Large piece of leather (size depends on what size chessboard you wish to make)
1 Piece of wood the size of your chessboard
2 different leather dyes
Leather sheen (to waterproof)
ruler
pencil
swivel knife (optional)
Leather modelling spoon and stylus (optional)
nails
Supplies:
Step 1: Measuring and Cutting
Measure your leather to what size you want. I made mine 29 cm x 29 cm, allowing 3 cm per square, 8 squares by 8 squares, the extra 5 cm was to allow attachment to the wooden board.
After you've cut out your leather, you need to measure the depth of your wooden base board, and then cut a square of that measurement out of each corner of the leather - see second picture.
Step 2: Marking
Using a ruler and stylus or pencil, mark out a border around the edge of the leather, and then mark out the squares.
Sorry, the picture doesn't show it very well :-/
Step 3: Dyeing
Now its time to start dyeing the leather, using a paint brush go through and neatly paint every first and third square in the first row, and then every second square in the second row, keep alternating between first and third and second, until you have the effect pictured, then paint the blank squares and the edge a different colour.
After its dried coat it with come leather water proofer.
Step 4: Nailing
Now you need to nail the leather to the wooden base board, make sure your board is the right size, so that you can nail the tabs around the edge as shown in the photos, and make sure you pull the leather tightly, so that the playing surface is flat.
Step 5: Finished!!!
Now your leather chessboard is finished!!! Happy playing!
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    7 Discussions
    bigdaddycole
    2 years ago
    I really like this idea! I am thinking of making something similar.How did you keep the dye from bleeding into the lighter squares? I thought that the leather would wick dye along the grain. What kind of dye did you use?
    Janssen1998bigdaddycole
    Reply 2 years ago
    Thank you. I think the dye I used was Fiebing's from Tandy Leather. I didn't really have a problem with it bleeding, this may have been because I marked out each square first?
    Kuledoode
    3 years ago
    What about the waterproofing? I will try this method for a backgammon board. Stay tuned ?
    Janssen1998Kuledoode
    Reply 3 years ago
    Sorry I forgot to include that.....I just coated it with some leather water-proofer, and I guess that should work?
