Lego Mindstorms EV3 Race Gate Timer for Micro Drones
256
About: I like flying, tinkering, origami, engineering, art, camping, life hacking, winning souls for Christ, and getting things to work the first time around.
Guten Tag! Today I'm going to show you how design a racing gate for whatever micro FPV drone you have. All I used was Lego Mindstorms EV3 and its companion software. You might feel a little ripped off because there are no specific instructions here. And also the odd method I used to capture the program. I apologize. But anyway, this opens up an opportunity for you to get your creative juices pumping and DIY! That's what Instructables is about, right?
Step 1: Start Block
Here are some pictures of my start block. If you are using a Rakon 3.5 mm Cockroach frame, then great, you can just copy mine! Otherwise, design one specifically for your frame and flying style. Make sure it won't flip over too.
Step 2: Visual Aids
These gate thingies are to make the end gate more visible in my room clutter. If you have a ton of these wing pieces, I guess you could make some gates out of them, but I don't.
Step 3: End Gate
The end gate I will leave up to you. You should have a touch, color/light, and infrared sensor at your disposal. I found that it was easiest to use the infrared sensor by flying up to it and getting a distance reading below a certain level, but others might have different preferences.
Step 4: Program
Here is the program for the gate system. Sorry about the odd method I used to capture it, I don't have a screenshot software. If you want to program your own, here is how it works:
1. Clear screen, display message.
2. Wait for brick button to be pressed, make a noise, then wait a few seconds.
3. Play starting noise, reset timer, then measure time.
4. Display object.
5. Wait for sensor to reach a certain threshold, then take a timer reading, display it, and make a file to store it.
6. Restart program after a few seconds.
You can see your times either after you finish your run or by accessing the brick files on the EV3 software.
If you have any questions or improvements, be sure to let me know. Also, don't forget to click I Made It! to show off.
    • Fat Challenge
      Fat Challenge
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    2 Discussions
    Jake_Makes
    8 months ago
    Nice. I was on a lego robotics (FLL) team once, way back when I was knee high to a grasshopper. Dang that was a TON of fun. Our team won second place in the state championship :)
    Thorondor95Jake_Makes
    Reply 8 months ago
    I tried applying for a local robotics team once (I'm homeschooled, so I can't join a school team) but it was just too expensive and we would have to drive an hour to meetings, so it didn't work out. Not that I'm complaining, because the resulting boredom forced me to become an at-home DIYer!
