Library of Congress Ornament
4,928
42
24
About: I'm a software developer who loves to hike. I have two young boys (a 3 year old and a 1 year old). When they sleep, I stay up and partake in my newest addiction-- 3D modeling (via Blender) and 3D Printing ...
For my entry for the 3D Printed Ornament Design Challenge, I decided I wanted to do something inspired by one of our family’s favorite DC destinations-- the Reading Room in the Library of Congress' Jefferson Building. The beauty of the building and knowledge within is a great testament to the best of mankind and all the accomplishments yet to come!
Reading Room image is by Carol M. Highsmith and in the Public Domain
Supplies:
Step 1: Prep and Planning
I worked in Blender, which can be downloaded for free. It can be intimidating at first, but I've found tutorials are plentiful!
I typically work using Blender Units as Centimeters. Per the contest rules, the ornament could only be 3” by 3” which meant 7.6 centimeters by 7.6 centimeters.
I don't own a 3D printer, so I typically use companies like Shapeways to do my prints. Shapeways has start of the art 3D printers and can print in a variety of materials, including premium metals like gold and silver. I reviewed the Materials design requirements and decided that I would want my ornament to be 1 millimeter thick—which would keep it printable in the materials I was eyeing-- Strong & Flexible Plastic, Brass, and Premium Silver.
Deciding your materials and knowing their limitations from the get-go is really helpful and makes the process go MUCH smoother.
Step 2: Modeling the Base Ornament
Now the Jefferson room has eight arches, so I started offwith three planes (one on the Z axis, one on the Y axis, and one rotated 45 degrees on the Z access) to help me visualize my working area. I modeled just 1/16th of the ornament and used mirrors to fill in the rest.
I started by going to Add->Mesh->UV Sphere
I made it 7 centimeters by 7 centimeters by 7 centimeters.
I hit the Duplicate Objects button to make a second sphere. This one I wanted to make smaller as it was going to be the inside walls of my sphere. I mentioned I wanted my ornament to be 1mm thick, so my inside sphere is 2 mm smaller in diameter than my larger one.
I selected my smaller sphere and switched to Edit mode. I selected all the Faces and then I flipped the face normal by going Mesh->Normals->Flip Normals. This tells the smaller sphere that it is going to be on the inside.
To make my outside sphere pretty, I clicked on the Modifiers icon. I selected Add Modifier and added (and applied) a Subdivision Surface modifier to it.
I highlighted both my outer and my inner spheres and went to Object->Join to make them one single object. Now I had a single, hollowed out sphere.
Now, I only needed 1/16th of my sphere to model. So I needed to delete the parts of the sphere I didn't need.
You can do the Select->Border Select (as Jonathan Williamson demonstrates in How to Model a Pumpkin in Blender). However, at this point, I had lots and lots of faces and vertices because of the Subdivision Surface Modifier. So what I did was add cubes, size them, and rotate them to cover the parts of the sphere I didn’t want. Then I used the Boolean Modifier to subtract those cubes from my sphere.
Step 3: Modeling Windows and Doorways
Then I made a bunch of little objects for my windows and doors. They all started out as Add->Mesh->Cylinders of various sizes and rotations. For the doors, I took a cylinder and went into edit mode and dragged some of the vertices down. Then I used the Boolean Modifier to chop off the bottom.
I lined up my objects on my sphere. The planes really helped with visualization the layout. I also turned on all my Mirror Modifiers (More on that below) to see how everything looked as I work. As necessary, I rotated the objects so they were positioned better on the sphere.
Step 4: Carving the Windows and Doors
Tip - before carving, I usually make a backup of my work so far—be it through duplicate objects in the same file—or--- saving another file altogether. I have found if I have any issues with thin walls, it is often easier to fix in this stage rather than correct after all the mirroring and subtracting.
I used the Boolean Modifier to subtract all our little details from the spheres. (Again I have all my Mirror Modifiers on to see progress as I work).
After carving everything, I highlighted my sphere, went to my Print3D options in my left pane (via the free 3D Printing Toolbar Extension for Blender) and clicked on Solid to check to make sure my object is airtight.
I breathed a huge sigh of relief when I see there are 0 Non-Manifold edges. :)
Step 5: Mirroring My Ornament
I’ve modeled 1/16th of my ornament. Now I needed to mirror it around. First, I mirrored it over my Plane that is rotated 45 degrees along the Z access.
Then I mirrored it over X axis.
Then mirrored that over the Y.
Finally over Z.
After each mirror, I did another Solid check on the Print3D extensions to confirm I didn’t introduce Non-Manifold edges.
(If you do get Non-Manifold edges, Ctrl-Z to undo, and try redoing the mirror, this time unchecking the Merge option when you mirror)
Step 6: Modeling the Floor and Chairs
Inside my ornament, I have a small cylinder in the middle to serve as my Reading Room floor and I wanted to add some subtle detail reminiscent of chairs and aisles. For the chairs I did Add->Mesh ->Circle of various sizes.
I switched to Edit Mode, used Select->Border Select to select the vertices of the rings and did Mesh->Faces->Fill to make faces in my circles.
On the left pane, I picked Extrude Region to raise it up my circles up.
I used some sized and rotated cubes and the Boolean Modifier to carve out my aisles.
Once I had everything modeled, I moved it into place inside my sphere.
The reference image of the Reading Room Seats is by Jiuguang Wang and is licensed Creative Commons.
Step 7: Modeling My Ornament Hook
The ornament hook was really easy. I just went to Mesh->Add->Torus, sized it, rotated it, and placed it at the top of my Sphere.
Step 8: Finalizing Object and Preparing for Upload
Now that everything is in place, I selected my sphere, my floors, my chairs, and the torus and did an Object->Join to make them all into one object. I did my Print3D Solid check one more time.
As I was designing I was using centimeters as my Blender units. When I upload to a company for printing, they often use millimeters, so I sized my Dimensions up by 10.
Finally, I went to File->Export and saved my file to .STL which I uploaded for printing.
The final .STL file is attached. Don't have a printer? You can also print a copy at the ornament at Shapeways.
Grand Prize in the
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    24 Discussions
    Well done, and very informative. I kind of stoped reading when I saw things like "1/16" and "Y axis".... My brain automatically shuts down when confronted with anything mathematical. But thanks for the tip about Blender anyway. I might be able to use it someday, if I can find the patience to learn, and someone with the patience to teach me.
    Hehe, sorry about that. I figure I might need those mathematical details myself in the future, so I went ahead and documented it. : )
    I am sure others who want to learn how to make something like this will love having those details.
    I *can* read it and understand it. I just don't *want* to. I actually do have a learning disability for real. It doesn't make it entirely impossible for me to do math but it makes it very uncomfortable. So my philosophy is, if I don't need to do it, why waste the time and energy?
    allie.fauer
    4 years ago on Introduction
    This is beautiful! I love the level of detail on both the inside and the outside of the ornament. Adding the Reading Room floor on the inside of the ornament was such a great decision! Congrats on being featured and a finalist!
    VickyTGAWallie.fauer
    Reply 4 years ago on Introduction
    Oh good. I almost didn't do that Reading Room floor. I'm glad you appreciated that detail! : )
    allie.fauerVickyTGAW
    Yes, it's such a great detail! It's something that you don't notice right away, or at least I didn't when looking at your rendering. It's something that forces people to look much closer at your ornament than they would otherwise.
    hg00021
    This is great!!!!!!!! OMG!!!!!!!! It's just amazing! Great idea to use the Library of Congress on an ornament! I LOVE LOVE LOVE to read so this is my so far favorite!
    VickyTGAWflyingpuppy
    Well, not actively. But I do have it up on Shapeways, so you can order prints from them (which I do get a small markup from). I ordered my print (a version in Polished White Strong & Flexible Plastic) from them earlier this week.
    http://shpws.me/yeJB
    P.S. If you do end up wanting to order from them and covet any of the other plastic colors other than red, green, or white-- let me know. I didn't turn all the options on.
