Lightwings: Fiber Optic Fairy Wings
95,036
337
19
About: I'm a digital artist/crafter/maker who likes electronics and sewing. I used to run the blog Soft Circuit Saturdays, which is now part of my site GellaCraft - dedicated to techy crafts, costuming, and art.
Add some glamour to your fairy costume using fiber optics.
This method for light up wings uses a simple circuit of LEDs and a battery to achieve a look a similar to EL wire, but thinner and almost invisible when not lit up. The lighting isn't as even as EL wire because it uses a single light source instead of glowing along its length, but it was an interesting and fun experiment.
It would be pretty easy to advance the project by hooking the LEDs up to a LilyPad to create blinking or fading light effects as well.
Step 1: Materials
Materials:
* Fairy wings (store bought or handmade), with any decoration removed from the middle/center of the wing frame
* Sparkle Fiber Optic Cable - a specialty fiber optic that lights up along the length of the cable, choose the kind with 6 strands. The amount will depend on how large your wings are: in this example I used ~4 ft.
* Sewable Coin Cell Battery Holder
* 3V CR2032 Coin Cell Battery
* (2) 5mm or 3mm LEDs - super brights work best for a dramatic effect
* Conductive Thread
* Needle and Cotton Thread
* Felt
* Hot Glue Gun & Glue
* Electrical Tape
* Masking Tape (optional)
* Scissors
* Pliers
* Pen/Pencil
* Velcro
* Cardboard/Posterboard
Step 2: Plan Your Design
On a scrap piece of cardboard or posterboard, trace the outline of your wings. Use this outline to help plan where your fiber optic strands will be placed. I drew three concentric loops per wing to complement the design and shape of my set of wings.
When you’ve finalized your design, cut your fiber optic cable to size using the outline as a guide. Inside the cable there are 6 strands of fiber optic, so the pieces I cut will have enough fiber to cover the design on both halves of the wings.
Step 3: Prep Fiber Optics
Carefully remove the fiber optic strands from the plastic tubing. If you are having trouble grabbing the ends, use scissors to cut a small slit in the tubing to access them. It helps to keep the tubing straight and the fibers should slide out pretty easily. Keep them grouped together - they are very easy to get tangled.
Step 4: Bundle Fiber Optics
Begin laying out your fiber optics over the outlines on one section of your wings. Use masking tape (or electrical tape), to lightly stick them into place.
Once you’ve got all the fibers taped down, gather up the ends in the segment into a small bunch. Wrap tape around the bundle to hold in place while you hot glue the strands to each other. Make sure not to glue over the ends of the fiber optics - I glue about 1-2” from the ends. Remove the masking tape.
Repeat for each wing segment - you should end up with 4 little fiber optic bundles. Gather up the bundles and trim the ends even with scissors. Cut about 1/2” from where you glued them together.
Step 5: Attach LEDs
Take the fiber optic bundles for the top and bottom of the left half of your wings and lay them on the table.
Cut a small piece (3/4”) of the original plastic tubing you pulled the fiber optics out of and grab one of your LEDs. Carefully push the fiber optic ends into the tube, and then the LED into the other end, getting them as close together as you can. Make sure the longer leg of the LED is facing the top. If the LED doesn’t fit, cut a small slit in the end of the tube to give it more room. Hot glue everything together once it is in place.
This will hold everything together and keep the fiber optics from moving around away from the LED. Wrap some electrical tape around your LEDs/fiber optic ends to block any extra light from escaping.
Repeat for the right side fiber optic bundles.
Step 6: Bend LED Legs for Sewing
Using pliers, bend the legs of your LEDS, making sure to orient the longer leg (+) upward and the shorter leg (-) downward. Curl the legs into spirals to make them easier to sew.
If needed, mark the positive leg with a sharpie to make sure they don’t get confused after spiraling.
Place your fiber optic/LED bundles in the middle of the front of your wings with the positive legs facing upward.
Step 7: Connect Battery Holder to LEDs
Cut a round piece of felt big enough to cover the taped ends of your fiber optics. Glue it to the back side of your wings. Then glue your coin cell battery holder on the felt with the positive tab (+) facing upward. If you are using a different type of battery holder, make sure to check the packaging to see which end is positive.
Using conductive thread, loop the thread through the metal tabs a few times and sew a line across the felt. Turn the wings over and sew through the loops of your LEDS, securing them to the felt and making sure to make a good connection. I like to loop about 3 more times than I think is necessary.
Repeat with the other side of the battery holder/LEDs. Make sure the conductive thread is not crossing over to the other legs of the LEDs or it will short circuit. Test out your connections by placing your coin cell battery in the holder to see if everything lights up.
Step 8: Sew on Fiber Optic Strands
Remove the battery after testing and sew your fiber optics into place, using the pattern you designed earlier. Use cotton thread in a coordinating color (or monofilament) to stitch the strands onto your wings.
Step 9: Finishing Touches
Cut another circle of felt to cover up the electrical tape/middle of the wings. Sew into place. Decorate the felt on the front if desired. I added a sequined star applique to go with my fabric/design.
On the back of the wings, sew a rectangle of felt onto one edge of your circle, making a flap. This will cover the battery and add a little padding to the back of the wings so you don’t feel the battery holder poking into your back while wearing. Add velcro on the end to make it easy to access the battery.
Insert the battery when you are ready to wear and enjoy!
2 People Made This Project!
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
19 Discussions
Yen nhi 1981
3 years ago
Thanks for your post , I was able to creat one
sherylnd
3 years ago on Introduction
Love this idea! How long does the battery last with continuous use?
ninjanody
7 years ago on Introduction
lol. real nice instructable... i hope my girlfriend is not going to see this.. she is in love with fairy wings... she will force me to fix that for her.... :-)
the_gella
8 years ago on Introduction
Here's my Halloween costume using this technique - I added a switch in there and ended up soldering the connections instead of conductive thread, but the fiberoptics method was the same. I also made a matching mask with the left over ends.
Phusilly
8 years ago on Step 9
This is a great tutorial! Makes me want to be a faery next year! Thanks for posting :-D
TinCan
At Radio Shack you can buy a 3 AAA battery holder with built-in on / off switch for $1.99 and use rechargeable AAA cells. May be a bit bulkier but in the long run, more usable & rechargeable.
Skyriam
Hey great ideas! Thanks for sharing. I can't get the special fiber optic you mention, is there any way to get normal fiber optic to light all the way? Thanks!
TinCanSkyriam
I called the link to wiedamark.com for the fiber optic cable and was able to order by phone a small amount. Their website has a $50 minimum, but by phone you can order as little as 1 foot + S&H
the_gellaTinCan
That's great news that you can order small quantities. Thanks for sharing that fact!
the_gellaSkyriam
If you are using normal fiber optic you can try sanding it a little bit along the length or scraping with an exacto knife or scissors, that should scuff up the surface enough to get some light. It won't be as bright as the specialty stuff, but I've had some ok results with that method, just make sure not to accidentally break the fiber optic by sanding/scraping too much.
MrKazekage
o very nicely done may i have an estimate of how much eveything cost? my friend would love this for her costume
the_gellaMrKazekage
The fiber optic I used was about $2.25 per foot, battery was $2.50, holder $1.25, and a 2 pack of LEDs was around $2.50. I had conductive thread and the wings on hand, but if you want a small sample of conductive thread you can get it for $5 at http://soft-circuit.com.
The total cost of materials to augment the wings should put you anywhere between $20-$40. (add in extra if you are buying your wings instead of making them).
MrKazekagethe_gella
well thank you very much ill get right on it haha i showed my mother this also so it looks like im making two one for my mother and best friend xD ill make the fairy wings and try a different method for angel wings it will look good with the feathers in my opinion. ill try and take a photo of the angel wings and show you thanks again ^-^
mkdieb
Love it! how clever! The steps made it a cinch to follow!
