Lock Bracket That Doesn't Interfere With Bottle Cages or Panniers.
14,987
147
12
The bracket which came with my lock was (as with most I've ever seen) rubbish, insecure & would have prevented me mounting any water bottle cages. However I don't like always having to have a bag with me when I cycle or putting a wet lock (if my bikes been locked up out in the rain) in my bag so I came up with this.
Materials needed:
•  PVC Conduit - As close a fit as possible to the U part of the lock. I got a suitable 2m length for £1.70 from B&Q
•  Hose clamps - 4x 10mm and 2 or possibly 4 x 22mm (sizes will vary according to your rack & lock diameters)*
•  Bits of old inner tube or other material to make shims
•  Zip ties - 2
*The hose clamps need to be reasonably robust I initially used some from Aldi which were soft and thin and not up to the job. I got some more substantial ones from Screwfix which seem just fine.
Step 1: Cut Conduit to Length
The conduit should be of a length where it's outer edge is pretty much flush with the lock mechanism. If the conduit is too long you obviously won't be able to attach the lock, too short and the lock could move about when you ride.
Step 2: Bevel the Inside Edge of the Conduit.
This makes it easier to insert the shackle into the bracket and is easily done with a stanley knife.
Step 3: Prepare Attachment Points on Rack
I'd have preferred to use hose clamps to hold the conduit at the rear fixture as well but the strut on the rack was at too much of an angle to I used zip ties instead.
Step 4: Attach the Pieces of Conduit.
Slide the conduit pieces onto the shackle then slide the shackle into the attachment points on the rack. Find a position for the lock where it doesn't interfere with your panniers. Tighten everything up.
Step 5: Job Done
  • Gardening Contest
    Gardening Contest
  • IoT Challenge
    IoT Challenge
  • Arduino Contest 2019
12 Discussions
exodous
3 years ago
Wow, I was thinking of doing this same thing, just hadn't thought of how to connect it. I searched for bike racks and this was one of the results! now I have no excuse, I need to do this. . .
wavey davey
4 years ago
Excellent!!! Will be doing this to both mine and my wifes bikes!!
syidid
5 years ago on Introduction
I'm so making this! My Masterlock was really prone to falling off the bike & is currently held on more by cable ties than the bracket it came with. Will report once done
jkjgabrielsen
5 years ago on Step 5
well done, mate! simple, cheap, practical, easy.
Deesea
Great idea! I've got some alloy tubing that'll do nicely, and cable ties 'cos it'll save me buying hose clips.
spencerzzzzzz
5 years ago
Id really like to know how to make one of those metal saddle bag holder things :
If you mean the supports for Carradice type saddle bags the supports I've seen that come down from the saddle use a pretty high grade steel that would be difficult to accurately shape with the equipment most people have in their workshops. I don't think I'd be able to manage it anyway.
It might be possible to come up with something with lower grade materials coming up from the upper pannier rack bosses though.
In My case I'd just support it with my rack.
pjones21
5 years ago
Cool. Very cool.
Goatie
5 years ago
excellent idea, I may have to make one of these
