Low-cost / High-scare Slender Man
21,331
149
18
You're peacefully walking in the woods, enjoying the night breeze. You left your friends at the party, so nothing could disrupt your quiet lonely walk. The night is dark, but the moonlight can still allow you to find your way among the trees.
Suddenly, something lights up. And... HE'S HERE! THE SLENDER MAN! RUN!!
So. This is our first Instructables.
We made this sweet three-meter-tall Slender Man for a Halloween party. We plan to set it up in the woods with a proximity-sensor-equiped backlight.
This is quite a low-cost project, made out of simple parts you can find in any hardware store.
It was easy to build. You can of course add your own improvements to this basic prop.
/!\ We are French, so we used meters instead of inches and feet.
Step 1: Tools and Materials
Materials
  • 2-meter-long PVC pipes (x4)(we used 40mm pipes, use any diameter you want, just make sure it matches the joints you'll use)
  • joints (x11)(check the picture to see how many of each kind)
  • 6-meter-long PVC flexible air ducts (x2)
  • plaster bandages
  • white shirt
  • black fabric (we had 150cm*600cm and had just enough leftovers to sew the bag. Be sure to get enough fabric!)
  • black pants (or you can sew the entire pants if you are not lazy like us)
  • tape
Tools
  • heat gun
  • hand saw
  • cutter
  • a pair of scissors
  • sandpaper
  • sewing machine
Step 2: Structure
The structure is entirely made of PVC pipes and joints. Cheap, easy to cut, pretty robust.
We also wanted the Slender Man to be transportable. No parts will be longer than 1m so they can fit in a reasonable-sized bag.
First, you are going to cut the PVC pipes. Use the saw for this step. Than use the sandpaper to smooth the edges.
CUTTING
  • legs: 4*1m
  • arms : 2*30cm
  • torso: 2*90cm + 2*10cm
  • shoulders: 2*15cm
  • chest: 1*45cm
  • pelvis : 1*35cm
  • neck: 1*30cm
Then the bending part. You will have to bend 5 different pieces. Check the picture to see which ones.
We recommend you assemble the greatest part of the straight structure before doing the bending. It will be easier to make the pieces fit that way by bending them while still hot.
BENDING
/!\ Make sure you work in a ventilated area, as PVC produces toxic fumes when heated /!\
Basically, you just have to heat the tubes with the heat gun, as you spin them so they don't burn. They will bend easily and stay in place when cooled.
Torso: The parts have to be bent slightly, at approximately one third of the longest parts.
Pelvis: Bend a 90° angle at mid-length (note: you can also get rid of this step by using T joints and a straight tube for the pelvis; we found it nicer our way but it is clearly not necessary)
Legs: This part is only necessary if like us you want to stick your Slender Man in the ground to make it more robust. Heat the tip of the end-tube and flatten it with a smooth surface (we pressed it in between wooden planks). Then shape it with the saw.
Chest: Flatten the central part of the tube (like you did for the "feet"), wait for it to cool. Then heat again and slightly bend each side (approximately 45°) so they fit the torso.
Optional: we used a very small tube (we had leftovers from a previous project) to make the chest look fuller when the clothes are on. You just have to cut a small incision and fit it on the chest-tube (see detail in the picture).
Assemble everything.
Cut the PVC air ducts in half and tie the pieces to the shoulders and pelvis. This way the arms and legs will be thicker.
Your slender man is coming to life!
Step 3: Costume
You can cut the sleeves off the shirt, it will be easier to dress the structure and you won't see them anyway.
The tie is a simple piece of fabric sewn in the shape of a tube, and then ironed to flatten it.
Here comes the suit part.
SIMPLE WAY
If you want to avoid the complicated sewing part, buy some over-sized old suit at your local charity shop and add fabric to the end of the sleeves and at the bottom of the jacket.
We would have done that but we didn't find the perfect jacket... Here we go.
GOT-TIME-TO-WASTE WAY
Unless you have a 3m-tall friend, you'll have to sew a tailor-made suit for your slender man. The picture should explain most of the process.
The numbers are not very precise. You should take more accurate measurements once your structure is built up.
* I am a beginner when it comes to sewing. I apologize for the lack of precision here, but this part was mostly improvisation. The pattern should help you understand how the different parts are shaped though. *
Step 4: Head
Sadly we didn't take pictures of this step. That's not a problem as there is not one right method.
Use any material you like to shape a head around the neck tube. We used a wire structure stuffed with newspaper.
Then shape the angles. We used cardboard that we taped to the head. Don't be afraid to be imprecise, as everything will be masked at the end of this step. Shape the nose, chin, cheeks and the arch of the eyebrows with this technique.
When you find the shape acceptable, you can tape everything so it holds together.
Then cover the entire head and neck with plaster bandages.
Pre-cut 10/20 cm long strips. Dip them in water one by one and carefully apply them on the structure. Smooth them with your fingers so they'll blend together. You want to work one layer at a time, letting them dry for some time before applying more.
When you're done the head will have a homogeneous finish. You can spray it with white paint to make it more water-resistant.
Step 5: Assembly!
Everything is ready!
Some parts can stay together so you won't lose them. Don't hesitate to tape together everything that won't need to come apart.
Hope you enjoyed this. We will eventually add details after the prop is displayed at the party.
Don't hesitate to ask if some parts are too confusing.
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    18 Discussions
    Pistol44
    Question 8 months ago on Step 2
    why do you bend the pelvis at 90 degress?
    Rougarou
    Question 8 months ago on Step 3
    Is there a pattern an measurements for the pants?
    LintBallz
    3 years ago on Introduction
    Just for ballpark comparison, one meter is very close to one yard, which is 3 feet for those of you that needed help.
    daandelange
    4 years ago on Introduction
    Here's a nice photo of this instructable:
    https://www.flickr.com/photos/karmakusala/15975120082/in/set-72157649248663747/
    babylake
    4 years ago
    so scary
    ffrisell
    4 years ago
    Very creative! Seems easy to make and yet the result is "highly" impressive! I might try for someting like this next year. Possibly it works with a very long cape/mantel a'la Dracula instead of the suit?
    Ikelabffrisell
    Reply 4 years ago
    What a great idea! That would make a wonderful Bela-Lugosi-style Dracula!
    It was indeed easy to make. PVC pipes are really good material for quick and low-cost structures. This was a successful first try, I think we will experiment a lot with these.
    Ikelabwilgubeast
    Reply 4 years ago on Introduction
    Thank you! That was some piece of work. I was a bit anxious but it turned out quite well for a beginners project.
    seamster
    Ooh, very nicely done! I'd be creeped out by this.
    I like how you shared both the easy way, and the "got-time-to-waste" way. So funny!
    Ikelabseamster
    We creeped ourselves out when we tried it in the garden. ^^
    Happy it made you laugh! Not being able to use the "simple way" made us creative.
    Ikelab
    1600 views already? Featured project??! Wow! We didn't expect that!
    Thank you so much guys for all these nice comments, it makes us want to document more projects...
    Delete_
    4 years ago
    Lol. I loved slender man until Five Nights at Freddys came out. Nicely done
