MAKE UR OWN BRAKE LIGHT
5,013
8
10
you can make your own brake light by acrylic sheet
Supplies:
Step 1: Things U Need
things you need are
1)An aqralic sheet
2)Rottery tool
3)if ne curve so heat gun
4)scale
5)pen or marker
Step 2: Takeoff the Brakelight Cover
you sholuld have to take out the brakelight cover
Step 3: Make Margien N Cut Aqralic
frist u have to make the line with the dimentions which u want
secondely you cutt the aqralic
Step 4: Using Steel Rod
use steel rod for making the efact in the light make a point on the steel rod for gving efact
REMEMBER you have to give efact on the inner part or aqralic
Step 5: Your Light Is Ready
after giving effact it is raedy
stic the pice on the light by super glue
Step 6: See Older N Nue One
see older n nue one
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    10 Discussions
    Sandisk1duo
    10 years ago on Introduction
    While you at it, you should change those incandescent light bulbs with LEDs you should get a little more gas millage!
    4mem8
    muneer, How does this fit into robotics, it has nothing to do with this section, we need these submissions to be screened before entriey.
    GWJax
    I too would like to see how this fits into the robot contest. Although I love it, it's just not a robot.
    CameronSS
    If you can provide a satisfactory explanation for why this is entered in the Robogames contest, I will vote for it. Until then, I don't see how this is a robot part.
    CAR_RAMROD
    Huh? I did not really understand the English in this instructable, or the point of this instructable.
    gog
    This looks like a backup light and not a brake light? Its really hard to understand the text for this instructable.
