MOTION SENSOR .... Good to Go,Quick & Easy...
38,971
176
7
About: The most complex design is simple…
If these type of motion sensors ever cross your path, this is a great project to keep in mind and a great way to conserve energy.
Quick and easy to assemble and install.
Excellent way to quickly light up dark rooms or hallways.
Never worry about leaving lights on inside closets or storage areas.
MATERIALS :
(1) 2 Gang Electrical Box
(1) 1-Pole /3 way Motion Sensor
(1) Receptacle
(1) Cover Plate to fit receptacle and Sensor
(1) Industrial grade power cord / pig tail,  cord connector / grommet.
(4) Wire Nuts
As we all know electricity is very dangerous, so if wiring isn't something you are comfortable doing.  It is very important to have it inspected prior to any testing.
It is very important to strip all wires cleanly without scoring the copper wire, stranned wire should be tightly twisted prior to connecting to other wires with wire nut.
A 6" length of wire is a fair amount for a service loop inside the box. Electricity flows like water through a hose any loose connections, tight bends  or kinks in the wire can create hot spots, over time can become a problem.
Some receptacles are marked
"Hot" / Black Wire
"Common"  / White Wire
"Ground Screw" /Green Wire.
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    7 Discussions
    pbates123
    6 years ago on Introduction
    Hey neat project and very usefull! I just thought a great addition would be to substitute a GFCI (ground fault circuit interupter) for the receptical. Costs a little but adds a lot of safety...
    Great ible!!
    - Phil
    NorCalDompbates123
    Reply 6 years ago on Introduction
    Phil ,
    Great point, Safety First! I totally agree, the GFCI is the only way to go and is well worth every penny when you consider the added safety benefits.
    Thanks,
    Dom
    PatM144
    2 years ago
    It doesn't look to bad BUT you should have used either a Decora receptacle or a gfci receptacle or the correct raised cover.
    gluvit
    4 years ago
    This is very helpful
