Magnetic Induction Bike Lights (Mod)
113,852
217
52
About: I'm the former Frontend Engineer for Instructables. Problems with the site? It may have been my fault... Like what you see? Sing my praises!
For staying safe at night, magnetic induction lights are a great way to go. They just bleed off a tiny sliver of your momentum to generate nice, bright light. They're perfectly silent (unlike dynamos) and need no batteries (unlike clip-on bike lights.)
Just to be up-front, this instructable doesn't contain details on how to build induction coils or the lights themselves. I adapted commercially available magnetic induction lights to fit my bike perfectly, opening up the cases so that I could separate the lights from the coils.
A short video is below, showing the initial test of the separated coil, the finished setup, and how it looks at night:
Read on to see how it was done!
Step 1: "Reelight," Its Shortcomings, and Other Options
Reelight is a commercial product by a Danish company. At present, they're the only large manufacturer of these induction-powered bike lights that I know of. I've attached some diagrams from their manual, below, showing how the lights work.
The problem with Reelights, though, is that they are mounted directly on the wheel axles. This makes the actual product small and compact (the coil and light are in one integrated unit) but has a number of shortcomings:
  • The lights are very low to the ground, making them less apparent to drivers
  • The arms can flex a bit as the magnets pass by them, so they have to be adjusted every so often
  • The arms are kind of ugly
Separating the coil and the lights would solve these problems. The could could be mounted directly on the frame, making it smaller and less obtrusive. It would be much more secure, requiring no adjustment. Finally, the lights could then be placed anywhere on the bike, connected by wires.
One last, big drawback of Reelights is their cost. They cost anywhere from $25 for a low-end one to $85 for a fully-featured pair, plus shipping. So I'm also including some links to help people get started with making their own induction coils, circuits, and lights.
Okay, onwards to how my Reelights were set up!
Step 2: Break Open the Reelight
Reelights are glued together with some pretty hard-core adhesive, since they were never meant to be opened. You should probably do a neater job than I did. A dremel with a fine cutting wheel would serve you well; I went at it with a saw and a screwdriver and pried the thing open, which sadly cracked the case in a few places.
This step has a number of close-ups of the internals of the Reelight, for others' reference. These pics are for the red rear light; the white front light was identical except for the color of the plastic cover.
Step 3: Re-Assemble LED Housing, Without Coil
Basically, the lights went back into their original housing. I installed a 1/8" audio plug in that housing and connected to the power inputs so that I'd have a simple way to detach the lights, then the whole thing was sealed back up with a hot glue gun.
I repeated these steps for both of my Reelights.
Step 4: Induction Coil Housing: Back Wheel
I tied the audio cable around the induction coils to protect the delicate leads from any pulling force and soldered them in place. Each of these was now independent of the LEDs in their housings; to connect them, I'd just need to plug them in.
Now, to build the housings for the induction coils. For the rear housing, I wanted an aerodynamic housing that would nestle into the rear triangle of my bike frame, right next to the axle. I cut this from a satellite dish (same one that provided me with the audio cables and jacks. Everything was carefully measured out and sketched onto the satellite dish, and then I cut out the housing and shaped it using a dremel.
The induction coil was then sealed with large amounts of hot glue and mounted into the housing. Hot glue was also used to mount the housing to the frame. Afterwards, I did a quick test to make sure that the wheel was inducting a current in the circuit, and that it indeed lit up the LEDs.
Step 5: Induction Coil Housing: Front Wheel
I didn't take as many pictures of the front wheel housing, but it basically used the metal bracket that came with the Relight, but put on behind the front fork so that it would be more cleanly nestled away. The thing was sealed with hot glue and a short length of inner tube that was zip-tied on.
Step 6: Finishing Touches
Finally, the LEDs were mounted on the bike with short strips of old inner tube. I basically fashioned my own, large rubber bands and attached everything that way. The lights were plugged in via their jacks and the cables were then run alon the frame from each induction coil to its respective light.
There's no noticeable drag while riding, and the lights have been working quietly and reliably for many months, now.
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    52 Discussions
    Unkful
    7 years ago on Step 2
    Hey Nagutron, thanks you for these photos and share it, I'm really glad to see your manual, but I have 2 questions. What is capacitor's value (in F)? and, if you only put one of these, may be posible that only one of the couple of led works right? I think that so the coil makes AC and I think the leds are reverse biased to fully profit the AC. I think may be better put 2 capacitors, one for each led, what do you think?
    nagutronUnkful
    Reply 7 years ago on Step 2
    Sadly, the whole thing's been coated and the details aren't visible. For a more from-scratch approach, see these instructables: https://www.instructables.com/id/Contactless-dynamo-powering-bike-safety-lights/ and https://www.instructables.com/id/Contactless-dynamo-bike-wheel-lights/
    would it be possible to mount the coil & circuit to the spokes, and instead have the magnets be fixed to the fork, in order to wire LEDs to the tire rims/spokes themselves? or would the motion of the wheels mess up the way the magnets moved within the coil itself?
    monjnoux
    5 years ago
    great job! an inspiration for my next mod!
    berserk
    5 years ago on Introduction
    I have a reellight, and a cheaper Danish (or more likely Chinese) knock-off, love them. I thought about opening them to separate components when I first got mine, but when it didn't want to come apart easily I chickened out. Good for you for going through with it.
    Dranem
    6 years ago on Step 6
    Why haven't you put all the magnet on the same wheel, and the two coils in the same housing? Like that, each coils is used with four magnets...
    F:Pourquoi n'avez vous pas mis tous les aimants sur la même roue et les deux bobines dans le même logement ? Comme ça, chaques bobines est utilisées avec quatre aimants...
    Step 2, photo 5. What's the tool in the background that looks like a nail clipper?
    lets say i wanted to make my own induction charging system. where can i go to find the plans for the charger and the induction coils. i know how to make the coils the problem i have is i dont know how to use them. and help would be greatly appreciated.
    I've never built one from scratch, but this guy did and he has some details in his instructable:
    I'd love to see photos of whatever you make, when you're done!
    nagutron
    9 years ago on Introduction
    Note: Reelight now makes lights that do all of this out of the box: http://forums.mtbr.com/showthread.php?t=578686
    onrust
      These light are GREAT!  I had only one complaint.  When I would walk away from my bike they kept flashing.  Every TWEAKER in the area would be drawn to my bike.........they had to go!
      If this is not a problem in your area,  these are well worth the money.
    rpvanpatt
    9 years ago on Step 4
     do you kno about how much volts are created with the coil?
    cantsolder
    9 years ago on Step 2
    Which solder joint on the circuit is positive and which is negative? I plan to directly wire mine rather than use a jack. Also if thicker wiring was to be used on the coil would there be more windings or fewer windings? Do windings have to follow a certain direction?
    nagutroncantsolder
    Reply 9 years ago on Step 2
    I actually don't know which side was positive. I just did the dumb thing and kept track of which wire went where on the lights, and kept those connected on the proper side through all of the components I added (wiring, audio jack, audio cable, coil.) There's probably a better way...
    cantsolder
    One reason why I went to this instructable was that my front Reelight 120 failed (the rear is still working great). I heard a ticking noise inside the housing just before it failed. When I opened up the housing the two strands going to the LEDs had completely broken off their solder joints, leaving the two strands attached to the coil. I think the fragile connection between the LED and coil strands broke during use and the rest broke off when I dremeled the housing. Reelight should have put in beefier wires as there is a lot of vibration on a bike wheel as well as jolts from everyday riding. Maybe speaker wires will work.
    nagutroncantsolder
    Yes, those wires coming off the coil really are extremely thin. I thought that that just made them difficult to hack, which is excusable, but it they're also less durable under normal use, i'd say that's inexcusable.
    cantsolder
    Having the coil separate from the lights makes more sense; especially for small wheeled bikes. Reelight should consider this and design their nest gen lights to allow remote mounting. Is there a way to do this with electrically conductive glue? I am sensitive to solder fumes and don't handle a soldering tool very well anyway.
