Make an Infinity Mirror!
383,576
321
62
Infinity Mirror Illusion.
Extremely simple concept with stunning results.
The illusion may look complicated but it was really very easy to make.
Details of materials and construction for Infinity Mirror Illusion
The sizes and measurements i've provided may not be 100% accurate. Feel free to experiment with your own materials and measurements.
1 - 7" Cardboard lid 1 1/2" height
1 - 9" Cardboard lid 1 1/2" height
1 - 15 bulb LED light strand
1 - 7" diameter mirror
1 - 1' X 1' 1/10" thick plexiglass or real glass (whichever you prefer -- real glass will give a cleaner result)
Take the 7" Cardboard lid and mark a spot every 24 degrees on the outside rim halfway between the top and the bottom.
That will create 15 marks around the lid for the LED's
I used a hand drill to create the holes for the LED's. Make the wholes a little smaller than the LED's so that they'll fit snug
Push the LED's into the hole. Push them in far enough so that they visible from the inside.
Cut the bottom of the lid out.
Glue the mirror in the middle of the inside of the 9" lid.
Place the 7" ring with LED's into the 9" lid. The small ring should sit directly on top of the mirror.
Cut a piece of mirrored window tint and apply it to the plexiglass / glass.
Attached the plexiglass/glass to the top of your lids.
I used duct tape to hold the glass to the cardboard lids then cut black construction paper to cover the sides and back.
I cut a ring out of silver construction paper and placed it on top to hide the duct tape.
I used velcro to hold the battery back to the back or the top of the infinity mirror device.
Good luck!
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    62 Discussions
    GregG60
    1 year ago
    Great work! Would it be possible to reflect an image in the dark area in the center. Either by lasering the image on the back mirror or the front two way mirror.
    DawnT51
    2 years ago
    I have glass that is shaded (like smoked color) Will that work?
    What mirrot tint would you recommend?Ican only find some with uv reduction..
    What about using only plexiglass with mirror tint? i have the plexiglass but don't have any mirror I can use ^^
    Thx in advance
    lusis987
    3 years ago on Introduction
    Could someone please insert a scheme how this efect is achieved? How thouse lightbeams are going, and how mirrors are set?
    evilboy9494SamS10
    Reply 4 years ago on Introduction
    from the looks of it its a caulk called liquid nails and only way ive ever gotten it off of wood is a razor knife and elbow grease
    gravityisweakoxidase
    You could also just spin the entire unit if it was a circle. Not so much if its a square shape.
    bbarbarosoxidase
    you can lid leds by order with a small controller :) actually I liked the idea :) I`ll give it a shot :) thanks
    SamS10
    I bought an infinity mirror, but the seller isn't helping me fix a problem w/it. To fix, I need to access the inside of it. It looks like he used a glue, calk, or something to seal it together. Can anyone recommend how to open it (a knife to unseal it?), and then what material to use to put it back together the same way he did it? Also, how much time should it take a layman like me to do it and are there going to be complexities (e.g., wires complexly in there, etc.)?
    Plastic cutting jigsaw blades can be found at most hobby shops, Lowes, Home Depot, etc. I have seen where you could use a mirror and a one way mirror but this method is much more affordable.
    babs15
    5 years ago on Introduction
    I made this over the past week and I'm very pleased with the outcome! I had a very hard time using the lids though and creating a structure that would support the weight of the glass and mirror. I would recommend using a premade round object with glass (likely a picture frame or clock) to avoid this struggle. Very fun project with a minimal price involved.
    Ben Finio
    I sent the author a PM but figured I'd post this here as well...anybody have any idea how he cut the plexiglass sheet down to a circle? Laser cutter? Jigsaw? I've made some smaller, square infinity mirrors by scoring plexiglass with a hobby knife, lining that up with the edge of a table and hitting it with a mallet to get a nice, clean break - but clearly that won't work for a circle, and I don't have access to a laser cutter.
    hohoheBen Finio
    Reply 5 years ago on Introduction
    They do sell special jig saw blades for cutting Plexiglas, I used them and they cut great, with the jig saw you should be able to make the circle cut. I purchased mine locally, but the are on line @ plastic supplier sites.
    kelvinmeadBen Finio
    draw the circle on the plexi, cut a square width is the diameter of the circle, cut lines for the corners so you have an octagon, then file down / dremel it.
    for this job its not so bad as the corners are covered.
    Ben Finiokelvinmead
    Unfortunately I didn't have a dremel or a file handy (really need to pick up both)...see above comment for how I wound up doing it. Thanks though!
