Make Your Own Fog Juice
402,222
148
33
Published
Introduction: Make Your Own Fog Juice
Make your very own fog juice that is cheap and very effective!
All you need is a few things.
*What You'll Need:*
• Distilled Water
• Glycerin
• Container
• Fog Machine
• Measuring Cup
Step 1: Distilling Your Water
Distilling water simply means that you are removing the minerals that build up in small pipes, such as in a fog machine.
You may have a solution to distilling your water, buying distilled water is much cheaper and easier.
Step 2: Mix Water & Glycerin
Very Thicker Smoke:
30% Glycerin | 70% Water
Medium Thick Smoke:
20% Glycerin | 80% Water
Less Thick Smoke:
15% Glycerin | 85% Water
Note:
• Make sure that your smoke is not to thick, fog can blur someone's
vision and make it hard to see where you are going.
• Measurements do not have to be exact, but should be rather close.
Step 3: Store in a Container
Store your final solution into an empty, clean container you have. Make sure to store all unused fog juice in a container before storing it. Keeping fog juice in the fog machine can clog the machine and can also cause infections to grow in the liquid, making it become no good for use. Adding a few drops of bleach to each liter can prevent infections from growing.
Enjoy!
  • Water Contest
    Water Contest
  • Clocks Contest
    Clocks Contest
  • Oil Contest
    Oil Contest
33 Discussions
I’ve had an issue with bacteria forming in my fog machines. It says to add a small amount of bleach to the solution. Is that okay to do even though it’s being heated? Breathing bleach seems like a bad idea, but maybe if it’s a benign amount it’s not as bad?
can you use VASELINE as glycerin?
Making distilled water.
Distilled water can be created as a by-product of other devices in your home...
a) The ice that builds up in your refrigerator - though this can be quite dirty and contaminated with bits of food etc. depending on how clean you keep your fridge.
b) Water from a dehumidifier - this seems quite good. I'd recommend filtering it either through filter paper or through several thicknesses of kitchen paper to remove any dust. We use a dehumidifier to assist clothes drying and we produce several litres of distilled water every week. For long term storage, adding a few millilitres of isopropanol per litre distilled water seems to prevent any bacterial build up.
You can also use an reverse osmosis filter,from fishkeeper shops
Simply boiling water will not remove minerals. Distilling water would be accomplished by converting it to steam, then back to water, leaving the minerals and other impurities in the pan. What you have described here is a good way to sterilize water, but it will not remove minerals. The best way would be to purchase distilled water or to use a filter to remove the majority of the impurities that might cause problems.
Thank you very much for that. Boiling water can be used to remove some minerals, such as the ones that cause water to become stagnant.
Thank you for your input.
I'm sure you are wrong there. Water, on boiling vaporises and it is the vapour that is pure water. No minerals can be ever removed by just boiling, except for Ca/Mg(HCO3)2 (bicarbonates of calcium or magnesium) which form the precipitate CaCO3 which gets deposited on the vessel . However, in these times finding this "hardness" in water is very rare, and the fog might be contaminated by complexes of various 'other' salts and minerals present in non-distilled water.
Just for the info.
Great instructable and thanks for sharing :)
Im gonna make it with very thick smoke :D
Hi guys, I'm not too sure if there's a slippery finish, I just wanted to make a suggestion that if you want a cheap distilled water, I'd recommend battery water...it's available in all gas stations and it's truly distilled.
But, saying that, I do plan on using my new fog machine in an exhibition (tiled floors), I think I have to lower the glycerine content to make sure it's not TOO slippery, if a visitor slips and breaks their back, I'm in the deep end.
hello. would adding a food coloring or some sort of scent, change the color or smell of the fog. and also, would it be possible to take this liquid put it into a container, and then like drop in something redhot and have same effect?
Thank you. U save my day ?☺
Is that vegetable glycerin or polypropelene glycol?
hi, i have been using this recipee for many years in a large town centre pub, we have wooden floors and have never found them to get slippery from the fog juice, the machine is actually a hazer and it has a remote timer which is set to give out a lot of smoke for 6 hours a night.
ps i also thought that boiling the water was the same as distilling it, i am now going to change to buying the stuff. great instructable, im of to look at your led site now. :)
If I may ask please; I bought a fog machine which uses mineral oil based fluid. I've still got a half jug of Water-based fog fluid from a previous machine. Can one use water-based fog fluid in a machine that is stated (on it's box) as one that uses Miner oil based fluid?
I don't recommend this glycerin is oil and makes floor so slippery and dirty I know i used cheap smoke juice in my disco and I had to clean up whole floor
buy some disco smoke 5liter of martin super pro juice costs 20€ in finland and you can do about 10 disco gigs with one liter
and 5l of cheapy cost 12€
some cheap juice http://www.thomann.de/gb/stairville_e_fog.htm
I use my fog machines outdoors on Halloween. Sorry, I didn't think about that, thank you for your input though.
If you are using the fog machine on Halloween, what would be best to cover the area of a garden? I'm not really caring about the plants, but how much stuff would I need?
so, i hate to sound like an idiot, but how do you turn it into fog? do you heat it? expose it to air? or is there some special way to do it?
Well that guys failed to answer you bc he simple dose not know. My guess is based of of some facts. Like a fog a machine E-cigs work under the same conditions.
E-Luiquid used Glycerin, More specifically VG and PG (vegetable glycerin,
propylene glycol), Now, How dose this get turnned into fog. Simple really,Like like in my Ecig There is a heating element (Kenthal wire coil(s)) and some sort of wicking material that gos inside of the coil. Heres how it all fits togeather. When you put the Juice on the wicking .(cotton is what I use) then heat up the coil with and eclectic current if heats the juice in the cotton causeing a boil effect as you would see if boiling water. you get vapor,fog,steam. But seince VG has a higher viscosity of PG water and UPS rated Glycerin.it will there for have the highest amount of fog,vapor production. I hope my explanation helped out.
I probably should have grammar spelled checked that but most of it is pretty easy to figure out where my mistakes are. Only thing is USP not UPS
