Make Your Own Sensored ESC
7,456
26
8
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how a sensored BLDC Motor from an electric bike works and how we can create our own sensored ESC in order to let it rotate. Let's get started!
Supplies:
Step 1: Watch the Video!
The video gives you all the information you need to create your own sensored ESC. But you can get some additional information in the next steps.
Step 2: Order Your Components!
Here you can find a parts list with example seller:
Amazon.com:
1x Arduino Nano: https://amzn.to/2H1cCRV
1x 10k Potentiometer: https://amzn.to/2JKY7mZ
1x 74HC14 Hex Inverter Schmitt Trigger: https://amzn.to/2HCejq8
3x TC4427 MOSFET Driver: https://amzn.to/2JMSZin
3x IRF5305 P-Channel MOSFET: https://amzn.to/2H0zjFA
3x IRFZ44N N-Channel MOSFET: https://amzn.to/2JMzPsO
6x MUR460 Diode: https://amzn.to/2HF3FPr
1x LM7805 5V Regulator: https://amzn.to/2vcRUNx
1x LM7815 15V Regulator: https://amzn.to/2JJMDA4
Ebay:
1x Arduino Nano: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10k Potentiometer: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 74HC14 Hex Inverter Schmitt Trigger: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
3x TC4427 MOSFET Driver: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
3x IRF5305 P-Channel MOSFET: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
3x IRFZ44N N-Channel MOSFET: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
6x MUR460 Diode: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x LM7805 5V Regulator: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x LM7815 15V Regulator: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.de:
1x Arduino Nano: https://amzn.to/2qvAplS
1x 10k Potentiometer: https://amzn.to/2GWYKvL
1x 74HC14 Hex Inverter Schmitt Trigger: https://amzn.to/2qzbca2
3x TC4427 MOSFET Driver: -
3x IRF5305 P-Channel MOSFET: https://amzn.to/2qy6bPg
3x IRFZ44N N-Channel MOSFET: https://amzn.to/2qxWrEJ
6x MUR460 Diode: https://amzn.to/2IUqOMT
1x LM7805 5V Regulator: https://amzn.to/2HCgM3S
1x LM7815 15V Regulator: https://amzn.to/2HzRuTK
Step 3: Create the Circuit!
Here you can find the schematic and pictures of my completed circuit. Feel free to use them as a reference.
Step 4: Upload the Code!
Here you can download the code for the sensored ESC. Make sure to upload it before attaching the motor wires.
Step 5: Success!
You did it! You just created your own Sensored ESC!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    8 Discussions
    sharjeelz
    4 months ago
    Greetings to All my friends!
    Hardware:
    I used Ir2110 High-low side mosfet Driver for irf3205 Mosfet, Used 6 irf3205 on highside and lowside to make "3ph- H-bridge".
    Code:
    Used 32khz pwm on lower side mosfets for current chopping and digitalWrite command for high side. digitalRead command hall sensors and call sequenced function for rotation.
    Motor is not rotating smooth at low speed. Please Help
    AndersonL9
    4 months ago
    I think it would be best for you to use the Ir2110 high-low side Mosfet drivers and use N Channel transistors.
    Abhijithekv
    5 months ago
    What changes should I make so that I can adapt this to a In-hub BLDC 48V 500W motor?
    It is powered using Samsung ICR18650-26J cells which is in 13S4P configuration.
    enoch kranthi
    9 months ago
    What is the power rating that your circuit can handle, because I have a 250W BLDC motor and planning to build an ESC for my motor.
    MohdK19
    11 months ago
    How can i change the direction of motor in this esc
    MohdK19
    11 months ago on Step 5
    why have not you written anything in void loop in the code. please tell me soon because i am making like this one, sir.
    junwoo0914
    12 months ago
    Great project! although I don't really understand what "TIMER1_COMPB_vect" is intended for...(Lowering Effective Voltage? as you said in the video). More study ahead...
