Make Your Own Simple & Cheap Portable Bluetooth Speaker
119,889
548
49
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how to build a simple portable bluetooth speaker that can play its tunes up to 30 hours continuously. Most of the used components can be found for only 22$ in total which makes this a pretty low budget project. Let's get started!
Step 1: Watch the Video!
The video gives you a good overview on how to create a portable bluetooth speaker. In the next steps though I will present you additional information so that you can create this project easily as well.
Step 2: Order Your Parts!
Here you can find a parts list with example seller for your convenience:
Amazon.com:
2x Li-Ion Battery: http://amzn.to/2eUuthD
1x Bluetooth board: http://amzn.to/2eUrCp1
1x SPDT Switch: http://amzn.to/2fJI5ek
1x TP4056 board: http://amzn.to/2eucBvk
1x Micro USB Breakout: http://amzn.to/2fw3nvH
1x MT3608 Boost Converter: http://amzn.to/2g3hjRX
1x RGB LED: http://amzn.to/2eQgQgl
Ebay:
2x Li-Ion Battery: -
1x Bluetooth board: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x SPDT Switch: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x TP4056 board: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Micro USB Breakout: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x MT3608 Boost Converter: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x RGB LED: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.de:
2x Li-Ion Battery: http://amzn.to/2eUzhDP
1x Bluetooth board: http://amzn.to/2eUto9y
1x SPDT Switch: http://amzn.to/2eUxqyK
1x TP4056 board: http://amzn.to/2eUvMNO
1x Micro USB Breakout: http://amzn.to/2eUtzSu
1x MT3608 Boost Converter: http://amzn.to/2eUzFCh
1x RGB LED: http://amzn.to/2eUB5gb
Step 3: Build Your Enclosure!
Here you can find the .dxf file that I created with the LibreCAD software or you can simply use the attached .pdf files to print out the templates that I created.
Step 4: Do the Wiring!
The wiring is rather simple to begin with, but here you can find a couple of pictures on how the insides of my bluetooth speaker look like. Feel free to use them as a reference.
Step 5: Success!
You did it! You just created your own portable Bluetooth Speaker!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
4 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
49 Discussions
PhilipB111
Question 2 months ago
What is your voltage going into the boost converter? My outputs are measuring 20 mV and Vin are at 700 mV.
Andy32
1 year ago
Great project !! I am currently doing it so thnak you for this great tutorial. I had just a problem for soldering the battery together (dangerous, no spot welding etc...) so I buy this case holder. I hope it will be fine, but at least it's not dangerous ^^
Thank you again ! It's my first DIY project and it's thanks to you =)
EvensonEAndy32
Reply 11 months ago
Don’t worry about that one thing to say is to say a lot different . Te Bote returns is a good game to play for free.
JosD12
2 years ago
hi,
I am using pam8403 module to drive two 4ohm 3watt speakers using a 2200mAh Li-ion battery but when I increase the volume around 75 to 80% on my phone the sound starts to cut off (speaker cones move in and out extremely during the time),and when I increase the volume further it becomes worse and sounds p p p pp ppp p ppp p p... I cannot understand what is the problem, could it be because there is no enough current ?,I also tried a 2 amp 5v dc input from a fast charger of my phone but same is the case
please help me with this.
StephenAllen1215JosD12
Reply 11 months ago
Speakers are way too small/watts too small.try a bigger watt speaker or goto a 8 ohm spear.
Zecatfish937JosD12
Reply 2 years ago
I belive the problem may be your speakers, I saw a guide that suggested having speakers with double the wattage rating of your amp.
ScottG214
Question 1 year ago
Anyone know what types of speakers were used here? (watts etc.) Because those dont look like 3W speakers and the board has 3W speaker ports.
1 answer
StephenAllen1215ScottG214
Answer 11 months ago
Which ever speaker board you desire to use you should use a speaker that can handle twice the amount of power I.e. 3w board should use a 6w speaker. The trick to having a great sounding speaker is mostly its enclosure and the amount of power going into it. I'm not too hip on home sound systems but I do know car stereos 1998 I had a home made setup in a Isuzu Rodeo consisting of four 1200w duel voice coil subs and using only one 800w amp per set of subs(2 amps used) I took second place for loudest car stereo in Hillsborough county. So by using less amp than the speaker was asking for I produced a heart stopping sound that most people could not make using the same size amp to speaker. I hope this helps!!
Nerdy'sD
Question 11 months ago on Step 2
Hi,
Im doing a final project for my engineering class in high school and i was wondering if you could help explain this more and go into to more detail like a step by step thing. And also what tools are needed for this project.
Thanks so much
andyg140
1 year ago
has anybody had any problems with the battery charger board
the ones i have seem to trip the overcharge when switching on when using the batteries but it is ok when i use a 5v mobile phone charger
WietseB1andyg140
Reply 1 year ago
I got a problem as well. When I turn on the speakers with the power connected they work. When I disconnect the power, they keep working. But when I turn on the speakers with no power connected the voltage is much lower and the bluetooth board does not turn on.
andyg140
1 year ago
Can you charge up the rechargeable batteries with an external solar power pack like the ones for charging phones
DavidT567
1 year ago
I made this but when I increase the volume about 90% to 100% the speaker stops working and the light on the Bluetooth board get off and the music stops.what can be the problem?Pls help me
Joebisc1
1 year ago
which resistor did you use on the led. Thanks
Joebisc1
1 year ago
if I wanted to add tweeters, would I need another amp and more battery power? If so what do you suggest. Thanks
TomTurbo83
1 year ago
Hello Scott! Another great project! Thank you!
I have a question about the very loud voice, which screams at me every time at the start! Is there a way to turn this off or to make it at least quieter?
Many Thanks!
