Make a Children's Log Cabin With Pallets
14,467
217
21
Published
Introduction: Make a Children's Log Cabin With Pallets
About: Passionate of DIY of any kind, I am not of the trade (I am developer in computing) but I am self-taught and I like to learn new things. I decided to share my creations with you through photos and videos. I ...
In this article I propose to you the making of a cabin for child!
I create it for the 3 years of our daughter, Colyne. It is mounted on stilts (Electric recovery poles), the floor is realized with wood terrace floor targeted on a structure of lumber (battens).
The structure of the hut is made in studs covered with pallet planks and the roof is made with composite plates imitation tiles.
It receives a staircase, a guardrail around the terrace, plexi windows that open, wooden shutters, window boxes and solar LED lighting.
With the falls of wood I could also make a table and 2 chairs.
Materials:
  • pallet boards,
  • wood terrace floor,
  • Electric poles,
  • concrete,
  • battens,
  • joist,
  • composite plate tiles,
  • screws,
  • paint ...
Tools used:
  • Circular saw,
  • miter saw,
  • drill,
  • screwdriver,
  • router ...
Time spent:
about 50H (excluding study and dismantling of pallets)
The vidéo :
https://youtu.be/ixSi46ECyx8
The plan is available in PDF format
Step 1: Foundations and Wood Posts
The owner chooses the land of his future home.
Cleaning of the ground and preparation of the studs.
I used concrete pillar elements to avoid formwork and for a better result.
The pole brackets are made of recovered shelf brackets, attached with a rail chute for plaster boards.
And finally the blocks are filled with concrete
Step 2: Floor
Installation of the 6 wood recovery poles (height 85 cm, diameter 18 cm)
The structure of the floor is made of joist (thanks for translation to brmarcum) (3m x 1,24m), nailed and screwed, it is fixed to the posts with framework brackets.
The floor is made of wooden deck boards screwed to the structure (with stainless steel screws)
Step 3: Structure of the Walls
The structure of the hut is made of studs assembled by screwing.
It is then screwed onto the floor
Step 4: Pallet Walls
Removal of pallets (approx. 30) and removal of nails.
They are then sorted to keep only the most beautiful boards.
The planks are cut with a miter saw then screwed on the structure.
Step 5: Roof
Laying of the roof: composite plate imitation tiles, fixed with special screws (containing a seal) on truss.
Step 6: Stair and Railing
Installation of the guardrail and the staircase for the happiness of the future occupant.
The railing is made with pallet boards and battens for the handrail. The staircase is made with the rest of the decking boards and 2 boards (planks) as strings.
Step 7: Paint
The planks are not very beautiful, they are painted after having plugged the holes of nails with wood pulp.
The shutters are made with falling pallets. A circular saw in the middle of the 3 planks gives the illusion that there are 6 boards.
Not functional, they are targeted on the walls for decoration.
Step 8: Table and Chairs
To furnish the cabin, I made 2 chairs and a table with the wood I had left
Step 9: Solar Lighting
I added solar LED lighting and 2 solar terminals at the top of the stairs.
Step 10: Reward
My work has been published in the French magazine "Système D"
    • Water Contest
      Water Contest
    • Game Life Contest
      Game Life Contest
    • Creative Misuse Contest
    21 Discussions
    Hey It's amazing!
    Well, garden cabins can be used for children's extra space or for home office as well. Garden offices trend has already become hugely popular with growing numbers of home
    workers.
    super travail félicitations !!!
    nice job, congratulations !!
    Almost makes me wish I had a grand-daughter to build it for! Love the furniture.
    Precious! Downloaded the PDF for future reference!
    Thank you ! You can also make one for yourself ! ;)
    Wonderful! I always admire parents that make things for their kids. :) Just so long as the kids don't become spoiled brats that is. ;)
    Good idea but Colyne already has a slide with its swing :)
    I love this. Great work.
    FYI - bastaing translates to plank. For the floor bastaings you would say joist, the wall bastaings would be studs, and each roof support on either end would be atruss. All of these come together to form the framing.
    Merci, c'est normal c'est pour une fille adorable ?
    Peut-être pour une adorable princesse :)
    Beautiful job! I especially love the pallet siding
