Make a Massive 4096 LED Display for Retro Pixel Art
91,266
571
43
About: Al is a wearable tech entrepreneur and creator of a line of smart phone controlled LED handbags http://catclutch.com With 22 years of experience in the IT industry, Al is currently Senior Director of Info...
***** Updated March 2019 ******
There are a couple ways you can go on this project, build everything from scratch or leverage a kit version. I'll cover both methods in this Instructable. This Instructable covers a 64x64 or 4,096 RGB LED installation but the PIXEL LED controller board also supports 32x16, 32x32, and 64x32 installations. See here for a list of supported LED panels.
Supplies:
Step 1: Getting the Materials
Materials
  • 4 sets of 32x32 RGB LED Matrix panels (Dimensions 7.5" x 7.5") or 2 64x32's, supported panels here
  • PIXEL Maker's Kit (a custom IOIO board designed to control HUB75 LED matrix panels)
  • Free Apps for Android and Raspberry Pi with included pixel art content, free apps here
  • 5V power, rated at 20A minimum, an old PC ATX power supply is one option
  • (3) 16.5" x 16.5" acrylic sheets (I got mine from my local Tap Plastics shop)
  • (4) IDC 16-in cables around 19" long, example here
  • (4) M3 hex spacers
  • (32) M3 x 10 pan head screws (the LED matrix panels use M3 threads, 4/40 screws won't work)
  • More info about this project at http://ledpixelart.com
If you have access to a laser cutter, use "super-pixel-svg-files.zip" and then modify to fit the mounting holes of your LED matrix panels. This file assumes P6 LED panels so if you're using P5 or smaller, then scale accordingly.
The panels used in this project are originally meant for large-scale building and scoreboard LED displays. You'll find several kinds out there from Adafruit, Sparkfun, Ali Express, etc. Unfortunately while they make look the same, there does not seem to be any standard for LED matrix panels and each manufacturer can use a different chipset causing them to behave differently. So be sure and only use the verified and tested LED panels listed here.
A special thanks to Ytai Ben-Tsvi, creator of the IOIO board, for all his invaluable help on this project.
Step 2: Mounting the LED Matrix Panels
You'll find mounting holes on the back of the LED panels. Unfortunately each manufacturer's mounting holes will be different so you'll need to make your own template. The holes in the mounting template will probably be 1/8" but I'd recommend drill a couple sizes bigger to leave yourself some margin for error. The pan head screws you will use will still cover up the larger hole so it won't be noticeable.
Once you've got the LED panels mounted to the back piece of acrylic. Then add the hex stand-offs and attach the front panel acrylic pieces. It's up to you what color you go with on the front acrylic panels. I used a frosted white acrylic front panel on the bottom and a translucent smoke front panel on the topic, this gives the LEDs enough diffusion while hiding the LEDs when the display is off. Alternatively you can get away with just one front acrylic panel if you sand the translucent smoke acrylic panel with 1000 grit sand paper giving it a frosted effect.
If you have access to a laser cutter, use the SVG files from the previous step. VERY IMPORTANT: The mounting holes on these CAD files for sure will be different than the LED panels you order because different manufacturers use different mounting hole layouts and this CAD file was originally down many years ago. So you'll just need to measure the mounting holes on your actual LED panels and then modify the CAD file mounting holes accordingly before you laser cut.
Step 3: Connecting the LED Panels
Instructions here on how to wire up the LED panels with the IDC ribbon cables.
To power the panels, you'll need to make your own custom cable. The LED panels take 5V and you'll want a power supply rated at 4A per panel so that's 16A in total so get a 20A to be on the safe side.
Step 4: Get Some Cool Pixel Art
The apps for this project are free and come included with some fantastic pixel art that was commissioned just for this project that you see here. You can find some really nice pixel art in 64x64 resolution on sites like pixeljoint.com and wayofthepixel.net to name a few. Tumblr has some great pixel art too. Of course, you can also make your own art. Still images should be in .png format and animations in animated .gif format. There are a few nuances to working with the LEDs, the main one being low contrast colors don't look good on the LEDs as the brightness of the LEDs tends to wash everything out. Here's a content guide with some tips for creating art for the LEDs.
Step 5: Get the Apps
Apps are available for this project for Android (recommended) and Raspberry Pi. You can find the apps for this project at http://ledpixelart.com/support/get-the-apps/.
The best app experience is Android which offers the most functionality. There are three main Android apps, one for pixel art designs (you can add your own too), one for scrolling text (including phone text messages), and a pixel art editor to create your own designs.
PIXEL has two modes: interactive and stand alone. In interactive mode, the Android and Raspberry Pi is driving PIXEL what to display based on the application's logic. In stand alone mode, an animation or still image is written to PIXEL's onboard SD card and then the animation will loop with no connected device required. Long tap from the Android app to write an animation or still image to the local SD card.
Android users can connect to the IOIO board which controls PIXEL over Bluetooth or USB. Raspberry Pi users can connect via USB.
Raspberry Pi apps here.
Also note that in the software you can change the physical configuration of the LED panels. For example in this Instructable, I have them in a 2x2 square. But you can also have them 1x4 vertical or 4x1 horizontal. 1x2 vertical (2 panels) or 2x1 (horizontal) is also possible.
You'll find the source code for all the apps on github here (not the main branch, use the board_v2.5 branch).
123D Circuits Contest
Finalist in the
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    43 Discussions
    rgrech35
    Question 5 months ago
    First, I just wanted to say this is a great instructable. I built a panel last year to hang up for holiday art displays. I am using two 64x32 Panels from adafruit. I'm wondering if you or anyone has any recommendations for power supplies that might be silent or very quiet.
    I wound up buying this panel, which may be overpowered, but it's kind of loud.
    https://www.amazon.com/gp/product/B00FRBYWMO/ref=o...
    Any recs for quiet or silent power supplies would be helpful. Note that my PSU is only powering the LED panels, not the PIXEL board.
    leetallboy
    8 months ago
    If anyone is willing to build one of these I would love to purchase one on commissoin.
    ablemachine
    Question 8 months ago on Introduction
    Thanks for the great instructable! Do you have ideas for how to make this battery powered? I want to use this in a Halloween costume. I'm trying to find a portable source for 5V and 20 amps, which is challenging!
    1 answer
    LukeH136
    Question 10 months ago on Introduction
    Is there anything I can do to fix the error in the later panels or have I accidentally bought incompatible ones?
    LukeH136LukeH136
    Answer 10 months ago
    Fixed it by changing the panel type. Thanks!
    alinkeLukeH136
    Reply 10 months ago
    great! glad you figured that out, do post a pic of the final install, would love to see it.
    the_axe772000
    1 year ago on Step 5
    Hey that's awesome, but If you could make 32x32 and 64x64 LED display board(One color red or blue or green) right from scratch. It would be a great help. Hope you will make such video.
    alinkealkhymia
    Reply 1 year ago
    of course you could but my particular Android app here will only work with the pixel board that supports only hub75 based LED panels, strips aren't supported, sorry
    alkhymiaalinke
    Reply 1 year ago
    Thanks for reply. Ok, in terms of the application, I'm going to make the code by hand; I commented because I want to do the panel on my own. With dip led I only found tutorials for 16x16 with 4 max7219, my question is if I can put 72x16 (matrix 9x2 of max7219) We thank you in advance for your advice
    alinkealkhymia
    Reply 1 year ago
    Sorry, I have no experience with DIP LED displays. I did Google around though and it seems that there are some DIP LED displays which are HUB75 based. HUB75 is the standard I've used with the panels in this Instructable. So in theory you could try using the PIXEL board with them but it would be unknown waters with no guarantee things will work as even with HUB75, I found the pixel ordering to be different across different HUB75 LED panel manufacturers. Hence why we published the specifics panels the PIXEL project is known to work with http://ledpixelart.com/pixelv2board/. Is there a reason you want to use DIP LED displays vs. SMD LED displays? Of course you can do your own code but from experience, that's a lot of work, unless you really want to spend a lot of time interfacing with hardware and coding, I'd recommend going with something already known like the PIXEL project or switch to WS28XX based LED strips where there are known libraries already developed.
    alkhymiaalinke
    Reply 1 year ago
    Cost you know, here in Argentina they are expensive. Maybe I can consider cutting rgb led strips and assembling the panels on my own. In itself, my idea was to do it from 0 and not use modules, that's why I consulted you, forgive my ignorance and thank you for your response. I will continue investigating. Best Regards
    alinkealkhymia
    Reply 1 year ago
    ah I got it, that make sense and all good questions, no worries at all. I think using modules will be cheaper than LED strips and also much easier to install (assuming you don't need an irregular shape that could be achieve with strips). You'll find that the SMD LED modules will be about 50% cheaper if you buy direct from China (AliExpress) or eBay (example here https://www.ebay.com/itm/1x-RGB-P5-HD-led-screen-display-module-64x32-led-display-module-dot-matrix-p3-P4-/252445600901?hash=item3ac6ee2c85:g:cgMAAOSwXeJXdjhN) vs. a place like Adafruit for example. Adafruit will have much better support if something goes wrong and you can return however. Let me know what DIP LED modules you are considering and I can't commit but I will look into ordering one as I'm curious if it will work with the PIXEL board. Also check out the middle of this page http://ledpixelart.com/pixelv2board/ , this has some modules we got from China, you can check prices there.
    Dffd1Maloney
    1 year ago
    How is the IOIO board mounted to the acrylic panels? Also how do I make the custom cable needed to power the Pixel Boards?
    alinkeDffd1Maloney
    Reply 1 year ago
    Hi, this page will walk you through it. You can do with an IOIO board but much much easier with a PIXEL board http://ledpixelart.com/pixelv2board/
    StephenR147
    2 years ago
    Am I able to split the connection to the panels 4 different ways in order to duplicate the panels to 4, 64x64, assuming I power the panels seperately?
    alinkeStephenR147
    Reply 2 years ago
    ah ok, let me test it , we added support for it but actually never tried it so not sure it works, will let you know.
    StephenR147alinke
    Reply 2 years ago
    Hey, thank you for checking! Any luck in your testing?
    alinkeStephenR147
    Reply 2 years ago
    Sorry late reply , did check and unfortunately support for that is not there , it could be added but some android library work would need to happen , sorry don't have the bandwidth to do that at the moment , the code is open source however
