Make a Microbial Fuel Cell (MFC) - Part II
84,187
198
106
This instructable provides detailed directions for building your own microbial fuel cell using Jello, Saltwater and Septic Tank treatment. It's based on the information provided in Make a Microbial Fuel Cell (MFC) - Part 1
This is a true fuel cell in that both the anaerobic and electrolyte media are replaceable and the salt bridge may be serviced as needed. The fuel cell consumes organic material and produces electricity and methane ( or more properly biogas include CO2 and other gasses ). These are captured in a methane store for further processing....Okay, it's a balloon and I have no idea what you should do with the biogas except be careful and experiment with it.
We'll be using a traditional two cell design with a gelatin/salt bridge. Most commonly agar is used but we'll be trying both traditional unflavored gelatin as well as hide glue. Yes, you can actually use Jello brand flavored gelatin and I would be very interested in your results.
I also intend to experiment with gelatinous nutrient medium in the anode chamber. It seems to me a gel based replaceable anode would be a significant enhancement to the utility of this technology.
The device has two relatively small chambers (approximately 100 mL). In theory microbe population densities are primarily a function of nutrients and not space and we should be able to obtain (more or less) the same charge out of a 100 mL cell as we would from a 1L cell with the same population.
Now let's take a look at the materials we'll be using.
Step 1: Bill of Materials
Tools:
Drill Press or Drill with bits
Soldering iron with solder
Measuring cups
Skewer ( wood or metal )
2 power tool replacement brushes
I got these from the specialty hardware department at ACE
2 1x1x1 PVC Schedule 40 Tee
3 1" PVC Schedule 40 Connector
1 1" PVC Schedule 40 Slip Cap
2 1" PVC Schedule 40 Plug
1 1x1/2 Slip vs FPT threaded adapter
Titanium fishing lead
Clear plastic wrap
Rubber bands
Salt Bridge Medium
  • Knox Unflavored Gelatin
  • Hide Glue (powdered not liquid)
  • Agar
Household salt or lye
Anaerobic Innoculent
  • Microbe-Lift Septic Tank Treatment - Ace Hardware
Make sure you rurchase an anaerobic treatment, there are a number of treatments including
Rid-X which are not specifically anaerobic. I have not tested these and have no idea what results
their microbes may produce
  • Wastewater primary effluent
  • Fish bearing river, creek, lake or stream sediment
  • Prepared culture such as E. Coli
Step 2: Create the Salt Bridge
The heart, so to speak, of a two chamber MFC lies in the salt bridge or membrane that seperates the cells. Agar is most commonly used but isn't necessarily readily available. However since Agar is a gelatin I thought conventional unflavored gelatin might make a substitute.
This is my least favorite component in this design, although I like its novelty. I would really like to have something at the ends to provide mechanical stability.
To create the salt bridge we will use Knox Unflavored gelatin in place of the more common agar. I have some reservations about the stability of this innovation. My next round will focus on the use of hide glue (dry not liquid) as the binding agent. This will not substantially alter the bridge process.
Start some water to boil, you don't need and actually won't use more than a couple of tablespoons.
Take one of the coupler sections. Place the plastic wrap firmly over one end and secure with a rubber band to form a tight seal. Place the coupler open end up in a bowl.
Take one packet of Knox unflavored gelatin and pour it into the coupling. Fill the rest of the way with salt. Pour this mixture into a dry measuring cup and pour back into the coupling. You'll notice that settling left a little more room. Top off with salt, pour back into the measuring cup and add an extra tablespoon. Mix the dry ingredients thoroughly and pour back into the upright coupler.
When the water is at a strong boil pour a bit into the measuring cup and use this to gently fill the salt bridge. Pour carefully so you don't flush the tube but be generous. The mixture will settle and allow you to "top off" the water, this will disclose air bubbles flushed out and help judge when the bridge is full. Carefully picking it up and examining the bottom can also help make sure that the entire column is saturated.
Allow to stand for a few minutes and pour off any tiny bit of standing water on the top. Then place the bowl in the refrigerator for 3-4 hours.
This is the salt bridge, it should be left in the refrigerator until final assembly.
Step 3: Assemble the Electrodes
It seems the biggest challenge facing the amateur microbiologist or energy researcher...er, among the challenges facing the amateur microbiologist or energy researcher is the elusive carbon electrode.
Okay, first you will need to use one wire and one carbon brush to make a carbon electrode according to my other instructable Easy Carbon Electrode.
Now taking the DRY sponge cut a strip 3/4" wide and about an inch long. This piece should fit smoothly into the neck opening of the screw top. Now take it back out and using a skewer, nail or other suitable object punch a hole big enough for the wire to pass through.
Using the smallest drill bit you have equal to or greater than the size of the wire drill a small hole in the center of the screw cap. Thread the electrode lead through the sponge and slide the sponge into the the neck of the screw top. Thread the wire through the cap, it should pass more or less freely. Screw the top down lightly and add water to the sponge. It will expand to fill the neck and provide a slight overcover at the base.
This is the anode assembly. It is used for the anaerobic (microbe cell). The small gap will allow the decomposition gasses to escape while the sponge will inhibit the passage of air into the chamber. To add nutrients to the anode chamber simply unscrew the top and gently pour the nutrient medium through the sponge.
For the cathode we are using a different approach. The cathode is inserted into the sponge (actually placed between two pieces of sponge) where air can circulate freely.
To make the cathode assembly remove the coil wire from the remaining brush. Because the brush lead will be fully exposed I did not add a secondary lead or connector although it would certainly do no harm.
From the remaining section of the sponge cut a strip 1" wide by 4" inches long, then cut this into two strips. Please the remaining carbon brush between the two strips so that only the top is exposed. Insert this into one of the 1" connectors. Wet the sponge and it will expand to hold the electrode in place.
Step 4: Assemble the Fuel Cell
Once the salt bridge has cooled and solidified its time to assemble the device. For easier dis-assembly and maintenance I recommend coating the PVC with the graphite powder when assembling.
Take the two remaining couplers and insert the end caps fully into them. Insert these into the base of the tees to provide feet for standing.
Insert the salt bridge into the center tee. When properly seated the tees will meet and the salt bridge connector will not be visible.
Your fuel cell is now complete and ready to be charged.
Step 5: Charging and Operating
Dayyum, that septic tank stuff stinks...You're going to want to do this outside or in a well ventilated area.
Pick on chamber to be the anode (microbe) chamber and one to the cathode chamber.
Fill a measuring cup with about 2 ozs of warm water and add salt to it until no more will dissolve ( a saturated solution ). Stirring and shaking will help. Allow the water to completely cool. Remove the sponge slices from the cathode assembly and make sure they are thoroughly soaked in the salt solution. Pour the rest into the cathode chamber until only the salt slurry remains. Place the carbon electrode on top of one sponge, cover gently with the slurry and then use the remaining slice to complete the sandwich. Place this gently back into its connector and insert into the cathode tube. The tube will overflow as the cathode is inserted, That's okay we want the carbon electrode to come into contact with the air so pour off a bit of water as well.
Fill the anode chamber 1/2-3/4 full of the septic tank treatment. I also added a couple of teaspoons of sugar and some shredded paper to provide carbon and nitrogen. Fill the chamber the rest of the way with pure, dechloronated water. Inser the anode assembly fully into the anode tube.
I began measuring voltage on the open circuit. Within 15 minutes I was generating measurable voltage (82 mA). Once the output voltage seems to stabilize I will measure under load and update.
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    106 Discussions
    AmitK122
    3 years ago
    can you please tell me how you can put feed to the cells because they are sealed and respiration will be anaerobic.
    Thank You
    jinfante1
    3 years ago on Introduction
    What will i do if i want to widen the voltage output.. Thanks for the answer.. :D
    ThrovinL
    4 years ago on Introduction
    There is a similar experiment on Sciencebuddies that uses a 220 Ohm resistor when measuring the output voltage of the microbial fuel cell. In many of these pictures and many other experiments online, I see that the user does not use a resistor to measure the voltage. When I do not use a resistor to measure the voltage, I read around 0.3 millivolts. However, when I connect the ends of the voltmeter to the wires directly, I read around 150 millivolts (this is after an hour or so). Do you know if the resistors are necessary to read the voltage?
    It depends on whether you are doing science or actual work. Without a resistor ( or load of some sort ) across the circuit you get the actual output voltage which is what one measures in, say, a science fair project. Once a load is applied (which represents actual work) you are measuring the current, not the output voltage.
    ahirdstudent
    4 years ago
    How big a system could you make with this process?
    Could you actually make a sceptic tank into a power cell, say on a rural property that has no access to mains power?
    And if so would the generation be more efficient or productive?
    Yes, you could. It would require some modifications. A septic tank would be a single model more similar to some of my other projects. The tank would have to be drained and cleaned so that carbon paint could be applied to use as electrodes. There would need to be air flow across the top of the tank so a methane capture system of some sort would be required which could be used supplement LNG in a generator. Energy output is a function of water volume ( primarily ). However its always going to be trickle charge level current, not direct tap generator style so its potentially valuable as a supplemental source. Possibly stand alone for 12V batteries or to supplement a solar or wind system.
    ahirdstudentegbertfitzwilly
    Reply 4 years ago
    Cool thanx for that.
    How would it work, if you tried to adapt a biogas digester to also produce current. Could that work as well, producing some charge as well as methane production? Or does the process of a digester make a power cell adaptation too complicated to be feasible?
    if you can figure out how to tap the digester tank in a way similar to the one outlined above you should be able to get some current out.
    cjthedad
    7 years ago on Introduction
    I was going to purchase some Nafion and found it in three different thickness what is the corelation of effectiveness to thickness
    I have absolutely no idea.I've never used a Nafion membrane, my areas of research use electron rather than proton bridges.
    TimW6egbertfitzwilly
    Reply 4 years ago on Introduction
    Hi, please tell me more about the electron bridge theory? Would that cause an MFC to run backwards? I may have accidentally made an electron bridge.
    (MFC-Microbial Fuel Cell)
    egbertfitzwillyTimW6
    I'm not sure what you mean about the electron bridge theory. An electron bridge is something that allows electrons (current) to flow. I'm not sure how one would accidentally make an electron bridge. If the current is running backwards its more likely you've reversed the leads on your output.
    adinoffi
    I am student in Nigeria intending to perform this protocol. please how can i get some these materials over to me in Nigeria... Pleas help me
    ehernandez26
    5 years ago on Introduction
    I am a student that will be conducting this protocol and was hoping you would tell me what type of carbon brush you used. Each carbon brush has a different size,etc. So if you can tell me where you brought yours, I'd appreciate it.
    Sorry it took so long to reply. I got these at my local Ace hardware store. They had quite a selection so I picked the one with the largest surface area that would fit inside the apparatus.
    ehernandez26
    bobtannica
    9 years ago on Step 5
    Fascinating 'able you have here. Can I suggest a few more pictures re the charging and operating section? Could these be hooked to others for more power? (in series or parallel?) Are there temperature parameters? (Min/Max) Approximately how long will this last overall, not just between "feedings". Really interesting and thought provoking. Thanks for your effort and sharing!
    egbertfitzwillybobtannica
    Reply 9 years ago on Step 5
    Thank you for your kind words. This is alpha rollout, the charging was primitive to say the least. I'm very interested in looking into this more, particularly energy which might be released during fermentation as well. The nutrient medium is pretty ad-hoc, I'm working on a formalization. Optimizing the nutrient/species/feedstock mix is left as an excercise for the reader... Lifetime borders on infinite. Like a septic tank the MFC must be cleaned of sludge (exhausted biomass) periodically (probably annually) but if well fed should continue along their merry way as they have for the last few hundred thousand years. I'm not sure what the optimum range is, its septic tank treatment so it's going to be pretty broad. I wouldn't leave it in a parked car with the windows rolled up in Death Valley or the Arctic circle for extended periods. Multiple cells can be arranged in series or in parallel to increase voltage/current. I asked Dr. Logan of Penn State about this, he said that multiple cells could be put into a single septic tank with separate cathode assemblies ( a closed pipe with a salt bridge at one end and a vented aeration chamber at the other ). He would recommend a Nafion bridge and suggest using a catalyst such as Platinum or Cobalt. If you google platinum coated wire you'll find scitoys has a 1 foot section of platinum coated nickel wire for $14.
    bobtannicaegbertfitzwilly
    I guess my only concern with using nafion is sourced at the same place as my "affection" for the gelatin salt bridge that you concocted. It is readily available to the common man, such as myself. I certainly applaud any and all efforts at scaling this up and making it usable for the general population, however, I love the instructability of your alpha. Thanks again.
    I agree about the Nafion. This is also the reason i published the "Easy Carbon Electrode" 'ible. The bridge as constructed as too deep. I tested another bridge in a bowl of water and it seems to be holding up fairly well, but then it doesn't have microbes eating away at it. More experimentation needs to be done to determine the minimum mechanically stable depth. Interestingly enough the bridge swells in water. I think hide glue is more promising, if one can find it. That's unrefined gelatin and more stable at room temperature. It's available cheaply on the net (actually so is Nafion) although, as I said, the gelatin is doing fine. Make sure you get the flakes that need to be melted and not the liquid type. I think there's a great deal of electrical loss in the current design. I'm working on two revisions. Dr. Logan is very, very big on single cell designs with an exposed electrode. So I've got a consolidated two cell 'tee' design with a smaller cathode chamber and a single chamber design with an exposed cathode. I'm also experimenting with using silk screen material. Soak it in salt slurry and allow it to evaporate. The crystals should form on the silk screen and a few layers should form a stable, highly conductive salt bridge. This is a variation of the sponge design I used for aluminum air batteries.
