Make a Usb Laser Air Purifier Lamp
39,797
54
51
Laser can refresh your air by kill the bad bacteria and fungus in the air.You can make a cool lamp too. All with the usb power.
Supplies:
Step 1: Cut Pc Blade
cut all the blade on a pc fan,drill 4 hole on a moni dv disk and glued 4 laser
Step 2: Place Plasric Bottle on the Machine
tape with black tape and let 4 hole for the air extraction,place 4 screw for making the leg of the machine
Step 3: Plug a Usb Cable
plug a switch and after take a usb cable and take the red and black wire for powering the machine
Step 4: Now Just to Put the Switch on and See the Beautiful Light
cool
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    51 Discussions
    casper.707
    10 years ago on Introduction
    Not to down your instructable, but can;t laser radiation severely impair your eye-sight or even make you blind?Just thinking...
    P.D.T.Burdett
    Its impossible that you can purifie air with that.Air is a compound of 78.08% nitrogen,20.95% oxygen, 0.93% argon, 0.038% carbon dioxide and 1% water vapor that can varie.You cant realy say theres "bad air", you may consider it has a high quantity of bacteria,CO2,humidity...etc.The lasers dont do anything to them facts, all your doing is producing a stream of fotons throw a bottle, thats not going to change the quantity of humidity or C02 and the only way it could kill bacteria would be a powerfull laser that beamed still in one spot and mabe then the heat would kill the bacteria(that would only happen on the surfice of what your aiming at).Sorry to say but that laser thing doesnt do anything to the air.
    calinuxP.D.T.Burdett
    Even if he cannot purify anything with that ... is just another way to enrich your lab with "freaky technology" ... next to jacob scale and tesla coil...this will look gorgerous on the shelves of your lab ...
    Or, like hivoltage said, you could try get hold of a UV laser diode then try with that with some sort of protection from the beam
    Yeah probably but then you would have to mess about with an inverter to drive the tube off 5v but the USB port might not have enough current... :)
    You're right - it would defeat the purpose to make it not-USB and not-laser. Still, though, it would actually do something...
    TheMaker888
    9 years ago on Step 4
     Does it do anything other then looking kool?
    msm_bound
    9 years ago on Step 1
    very very nice project
    i have two questions :
    1- how did u make the laser work ??? i mean how and where to connect it
    2- where do i get this laser parts and for how much ??
    please i am in the dead line for doing this project so i need ur help as soon as u can
    hivoltage
    9 years ago on Introduction
    I don't believe this "purifier" is actually capable of killing bacteria. The only way red light can kill a bacteria is if it causes enough localized heating to the bacterium to kill it, which would require a very high power laser. light in the UV-C range can cause damage to the DNA of a bacteria or virus and effectively prevent it from reproducing and render it harmless. UV-C is around 250nm while this uses red laser light at around 630nm, not nearly a short enough wavelength to do much besides looking cool.
    junits15
    This is not purifing air, maybe something with carbon pellets would but not this..
