Making a Garden Bed in the High Desert
42,906
79
25
About: I have a compulsion to make stuff, all kinds of stuff. I'm glad to be here...
Growing vegetables is a big part of our spring and summer around here.  We like to grow our own food as much as we can.  Once you start you get spoiled.  The produce in the grocery store, while it looks good, pales in comparison when it comes to flavor and freshness.   We just had green beans last night from the store.  They looked great.  The taste?....Meh.....
Don't get me started on Whole Foods Paycheck either.  You don't really save money gardening unless you happen to shop there.  I don't know why they have all those buttons on their cash registers since it seems that they simply take the number of items you picked out and multiply it by $20.
Back to gardening...
Growing veggies is great but your results are going to be in direct relationship to the quality of your dirt.  Great dirt = healthy plants = awesome vegetables.
Supplies:
Step 1: What Is Great Dirt?
From a plant's point of view great dirt is soil that is composed of neither too much clay (doesn't drain) nor too much sand (drains too fast) and chock full of decomposed organic matter.  Plants need the soil to be light and fluffy so that they can grow their roots easily.  Fluffy soil also means it's well aerated which the plants appreciate since they need air underground too to do their growing magic.
How does the soil in New Mexico look from a plant's point of view?  Not so good.  If NM dirt was being tested for the above requirements we'd have to pick...D-none of the above.  Our soil tends to be either just clay or just sand and since our climate is arid enough to keep all but the scrappiest of plants from thriving we don't have much of a natural cycle of organic material building up.
Step 2: What to Do?
Back in the late 1800's a method of gardening developed called the French intensive method.  The French gardeners of that time refined a method of building raised beds that still applies today.  The beds were built by a process called double digging.
Double digging involves digging out all the top soil from the bed to the depth of a shovel head (about 12" ) and then go back and do a second pass to the depth of a second shovel loosening the dirt another 12" and amending it with fertilizer; traditionally horse manure cause they had a lot of it at the time.
After working the lower layer you add the topsoil back along with more manure.  In the end you have a raised bed full of soft fluffy dirt with lots of organic matter.
Step 3: Adapting to the High Desert
In NM it's not that easy.  We have to go a few steps further.   First of all,  in my yard if I plant anything it's like I just set up a neon sign advertising Joe's Diner and everyone comes out to see what kind of handouts they can get, especially the gophers and moles.  Competition is fierce here and tender plants in good dirt are like the scrawny kid with glasses in the schoolyard.  They're gonna get rolled for their lunch money or worse.
In order to protect our plants I've learned the hard way that they need to be kept in a maximum security facility.  This means my garden beds need to be lined on the sides and bottom in order to keep intruders from tunneling in and taking out half the plants in one fell swoop.
Step 4: Sifting, Sifting
We live in the foothills of the Sangre de Christo Mountains and I'm lucky if I have two feet of soil before I hit bedrock.  Digging a garden bed for me consists of a pass with a pick axe to break up the clay and or rock and then shoveling it out. It's more like carving than excavating.
This also means that there is a lot of processing to do before that dirt goes back into the bed.  I sift all the dirt I took out of the bed through a 1/4" screen to remove rocks and break up the clay into smaller bits.  Usually about half the dirt that I've extracted doesn't qualify as gardenworthy and ends up as backfill somewhere else.
Step 5: Bed Building
Our dirt has no organic matter in it and by no organic matter I mean none, zero, zilch.  I need to do a lot of amending to the soil when I build a bed.  I use a combination of techniques to help the soil hold the maximum amount of water and supply nutrients both now and down the road. I build up the bed in a series of layers in order to build up a mix of ingredients that will support and nurture our plants.
The first layer is paper or cardboard.  This attracts worms.  We want worms and lots of them.  They're like little bulldozers and compost makers all in one.  They work the soil endlessly areating it and mixing the various components together.  Worm castings (poop) are also one of the richest sources of nutrients for plants.
Next I put down a 3" layer of straw or hay.   A few years ago we scored about 90 bales of alfalfa for free from freecycle so that's what I use.  The bales break apart easily into ~ 3" sections (leaves) and I layer the bottom with it.  The straw holds a ton of moisture.  It's like having a giant sponge at the bottom of the bed.  Eventually it breaks down into compost providing a rich source of food for the plants down the road.
If I feel like spending the money I sprinkle a 50/50 combination of bone meal and blood meal on the straw.  The nitrogen in the blood meal helps to kick off the decomposition of the straw.  Lately I've switched to adding a layer of chicken poop which is high in nitrogen as well as free and plentiful around here.
After the base of paper and straw I fill the bed up with a mix of sifted soil and organic amendments.  I aim for a 50/50 mix of sifted dirt that came out of the bed and organic matter.   The last couple years I've been able to get trailers full of composted horse manure for free so that's the majority of what I use.  I sift the manure too because there are a lot of wood chunks in it.  Wood is OK once it has broken down but it ties up a lot of nitrogen from the soil as it decomposes so you want to keep it to a minimum.
About half the volume of the horse manure doesn't fit through the screen and ends up as back fill.  I layer up a wheelbarrow full of soil then a wheelbarrow full of manure untill I 've filled the bed.  A light sprinkling of straw or leaves in between every few layers of dirt and manure helps to add some structure to the soil and organic matter to break down in the future.  Again, you don't want to add a lot because it will tie up the nitrogen in the soil.
Once the bed is filled with the soil/manure mix I stir it up with a garden fork.  I do a couple passes over the whole bed to evenly distribute everything.  Once mixed, I water the soil thoroughly a couple times until it is moist all the way down to the straw.
Step 6: Finishing Up
After the soil is prepared I set up drip irrigation to go on top.  Everything here needs to be watered regularly.  If I did it all by hand there wouldn't be time for much else.
I leave a few inches of space from the top of the soil to the top of the walls.  When the plants are small I lay windows on top of the bed and it acts as a cold frame holding moisture and warmth in while keeping the wind out.  I've found that if I don't protect the plants during this crucial part of their development they will only grow to about half their normal size or not make it at all.
It takes a ton of work to prepare a bed this way.  A 2'x 8' bed takes me 12-16 hours from start to finish but once it's completed I know I've done everything I could to give the plants what they need to thrive.  After the first year all I need to do to prepare to plant is to add a 2" layer of compost on top and lightly mix it in.
Step 7: Sounds Like a Lot of Work. Is It Worth It?
Heck yeah!  Once the pain in my wrists and back has faded I don't even think about the up front work I had to do.  These beds should last for years and years.  The soil is fantastic and the plants are producing lots of greens and vegetables for us.  We eat tasty organic hyper-local produce out of the garden three seasons of the year.
If you like projects you'll find plenty more over at our site: Mike and Molly's House where we chronicle our Mighty Projects on our Mini Farm(AKA our backyard).
Gardening Challenge
Grand Prize in the
Gardening Challenge
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    25 Discussions
    ratgirl13
    5 years ago on Introduction
    I, too, live in the desert and have always made my garden beds the same way. So to all who read this, YES, it is worth all of the back breaking work. Great 'ible and yummy looking vegetables you are harvesting. Keep up the good work!
    calskin
    6 years ago on Introduction
    Congrats! This totally deserves to win!
    There's a great video called Greening the desert on youtube that I think you would find really interesting.
    spike3579calskin
    Reply 6 years ago on Introduction
    I just found the one by Geoff Lawton a couple weeks ago. Totally inspiring. Now I'm starting to reconsider the backyard in terms of permaculture principles. I definitely could do a lot more in terms of water retainment and food bearing perennials.
    calskinspike3579
    That's awesome! I would love to see what you end up doing with it. Swales have facinated me ever since I saw that video and Geoff is pretty much the king of swales and ponds and resevoirs. There's another video I think called harvesting water the permaculture way where he digs a pond. There's way more to that than I thought.
    solmstea
    Nicely done! I envy all that space. But then, I made a semi-raised bed in. My front yard and nearly killed myself just digging down 9 inches (why are pick axes so short? That cannot be good for your back...). Don't know if I could have done such a big plot even if I had the room.
    spike3579solmstea
    The nice thing about garden bed building is that once you've done it it's there forever. Do one this year, one next year, one the year after that and before you know it you have a lot of garden space.
    I'm not always so patient so I'm thinking of starting exercise classes in my yard. For a reasonable monthly subscription you get to come and dig in my yard. Pick axe included!
    That....is.....amazing!
    I have several massive wood/brush piles that I have been procrastinating on dealing with. I could easily (with a ton of labor) doubletriple quadruple my garden size.
    Once I finish terracing the back yard and stacking rock I'm starting a hugelkultur campaign!
    Thanks for the tip.  I hadn't heard of it.
    Has anyone out there tried this?
    what were your results?
    diy_blokespike3579
    read yr hugelkultur post. You really don't do half work do you? Haven't seen the finished heap yet but it seems to have one heck of a big base
    nerdmom920
    Nice instructable. Pretty much the way I start my beds in Missouri, but I don't have to do as much protection. Of course, there are lots of things to distract critters in my area.
    spike3579breumer
    Now that's a lot of work!
    I live about 1.5 hours from Taos- Earthship central.
    Good luck on a mighty project!
