Making a Small Knitting Loom
26,190
245
22
This is a simple knitting loom I created out of wire for making cord cozies. A cord cozy is used by some to keep small pets from chewing on cords. I just think they look neat.
Step 1: Materials
No pictures for this step!
What you need is:
- 2 needle nose pliers
- 16 gauge wire
- A ruler
To knit with it later you will need:
- Some yarn
- A small crochet hook
Step 2: Bending
I would suggest a length of 2 feet on the wire. The first step I guess would be to straighten out your wire as much as possible. It doesn't need to be perfect but it's easier to work with when it's straight. Start bending the first bend about an inch and a half in. It doesn't need to be exactly that length. But that's what I went with.
Next just keep bending back and forth to create a zig zag pattern. Try to keep it at even lengths as you bend.
Step 3: Create "Hook" Bends
Next you want to bend little "hooks" on one of the sides. Try to keep them uniform. This works better using both pliers.
Step 4: Make It Circular!
Okay, I apologize for not having a decent picture of how I did this. But it's really not that difficult. Just keep evenly bending each zig-zag in a little bit until it forms a circle. You can probably see by the pic, I also cut off some of the excess wire. When you get it all bent the way you like, cut the excess to line up with the bottom bends.
I first tried taping the two end pieces with some electrical tape, but when I started working with it the tape just got warm and wanted to slide off. It got sticky and gross, so I wouldn't recommend it.
Also, if you look at the last picture, it allows for cords to be shoved through without having to force open the loom you created.
Step 5: KNIT IT UP!
You're done! Now you just need to knit away!
This was made using the "e-wrap" stitch with a small gauge crochet hook and my very own knitting loom.
I didn't know how to do this 'til a couple weeks ago when I watched this video. So it's really not hard to do!
Here's my tutorial on how to use it: https://www.instructables.com/id/Using-PixelanteAnnies-Knitting-Loom/
Have fun!
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    22 Discussions
    bamfg
    3 years ago
    creative
    debegar
    3 years ago
    Cool idea.its called ,"i-cord". I made aloom as a kid from a wooden spool & all nails.used large plastic sewing needle toove yarn over nails.
    beornica
    9 years ago on Introduction
    human pets chew cords as well. The kind that are several years old and have a lust for destruction. I will definitely make use of this one!
    I have a little brother named Silas(he is cute!)he is 6 monthts old and I will make some for my dad.But for now,I just make snakes!
    Mauigerbil
    7 years ago on Introduction
    you can also use a latch hook for knitting. If you use stiff cardboard, you can make one that way also
    craftygreen
    10 years ago on Introduction
    THIS IS SO CUTE!!! I absolutely love it!!! Not any of of pets chew on my cords or anythings, but I am sure I will end up making one for every cord in the house. just adorable
    Nice work on the cord cover, this is definitely a 5/5 project. If you've ever purchased these from a home store or decorator source, you've most likely experienced: the lengths are never a perfect fit, the colors are the most common standardized ones and the manufacturing is shoddy. Btw awesome first Instructable (faved till further use)
    Cats may chew cords also... I am on my 5th pair of headsets due to this. Thank you for the Instructable, it is going to be put to good use. I will foil the feline cord bandits.
    Pixelante_Anniecanida
    Reply 11 years ago on Introduction
    rabbits and chinchillas like chewing on cords. I lost my hamster once in my apartment and found her chewing on a playstation cable. =)
    iq_abysscanida
    My dog did, but stopped when he got zapped a couple of times. He is still alive-that's good.
    Bitsi
    Sure wish I had seen this before I went out and spent $10 on a spool knitter. What I like best about this is that you can make them in several sizes. I'm thinking that my earbuds could use a cozy like this to keep them from getting tangled in my bag. :-)
