Making a Quill Pen
120,006
100
7
About: The RISD Museum encourages discovery and creative expression by connecting audiences with art and design.
The quill pen, my favorite tool for ink drawing, was the standard tool for writing and drawing in Europe until the 19th century. Goose quills, particularly large (at least 10-inch) feathers taken from the edge of the wing, provide the ideal combination of flexibility and strength needed for fluent drawing that will not scratch the surface of the paper. This Instructable is part of a project I completed for the RISD Museum, for which I copied Luca Cambiaso’s drawing Deposition from the Cross (ca. 1570).
You can also read an article I wrote discussing my process for copying Luca Cambiaso 1570 drawing using a quill pen.
Written by Andrew Raftery (RISD faculty, Printmaking)
Supplies:
Step 1: Selecting a Quill
Once I choose a proper quill I strip the feathers from the bottom of the shaft to make the pen easier to handle.
Step 2: Scraping the Membrane With a Knife
The quill has a membrane covering the surface toward the tip. This is gently scraped off with a sharp knife.
Step 3: Finding the Bottom of the Quill Barrel.
At this point, I turn the quill so that the shaft arcs downward. I want to find the natural bottom of the quill barrel, the oval directed up and down.
Step 4: Finding the Bottom of the Quill Barrel and Making the First Cut
The pen is now ready to be cut. With the belly of the shaft facing up, the first cut takes off the tip of the quill at an acute angle.
Step 5: Removing the Quick
You will notice the quick within the quill. This must be removed.
Step 6: The Second Cut
The second cut follows the direction of the first, but is shorter and at a blunter angle.
Step 7: Cutting the Slit
A slit is cut into the center of the tip. This allows the ink to flow from the pen.
Step 8: Shaping the Pen
The sides of the pen can be trimmed to make a fine point or the tip can be trimmed to a chisel edge for broad, calligraphic lines.
Step 9: The Finished Pen
The pen can be trimmed and sharpened periodically during the drawing process, and with proper maintenance can last for many drawing sessions.
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    7 Discussions
    Hoopajoo
    5 years ago on Introduction
    Thank you for sharing this! I've used quill pens for art and calligraphy for almost 30 years. I notice that it helps to drill a tiny hole at the top of the slit you cut in step 7. It will not only keep the slit from riding up the quill with usage, but will also give you a slightly greater ink reserve.
    docwriteHoopajoo
    Reply 1 year ago
    Very true. A fine hole at the top of the slit not only increases the ink retention, but increases the longevity of the nib and, more importantly, the longevity of the quill.
    Curiositykt
    4 years ago on Introduction
    But what should I look for in a feather? Can I use chicken flight feathers? or tail feathers? Do I need big goose/turkey feathers?
    Jasco97
    I thought the quill had to be hardened by dipping it in hot sand
