Man Make Spoon
10,959
59
6
Materials: Block of wood
Hand chisel
Bansaw
Vice grips
Two handed shaver
Confidence!
Step 1:
First choose your type of wood. If you’re a beginner go with a cheaper softer wood like pine. If you want to make a really nice spoon choose a good hard wood like maple.
Step 2:
Second choose your type of spoon, There are two options either just a stirring spoon or a scooping spoon like a ladle.
Step 3:
Then cut out an 8 inch piece of wood.
Step 4:
Next trace an outline of the spoon you want onto the block of wood.
Step 5:
Then use the bansaw to cut out the head of the spoon.
Step 6:
Vice grips are necessary to hold down the wood.
Step 7:
Use a small hand chisel to start scraping out the head
Step 8:
When starting with the chisel make one deep groove to mark how deep you will chisel the rest.
Make sure you go with the grain as to not wreck the texture of the spoon.
Also make sure you’re not going to close to the edge or you will blow out the side.
Step 9:
When you are done making the spoon head return to the bansaw and cut out the rest which should be the handle.
Step 10:
Then you will use the two handed shaver to start thinning the handle to a good round shape
Step 11:
Once your done shaving the handle use fine grit sand paper and sand the whole thing down to your liking, then your done!
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    6 Discussions
    techshop1
    7 years ago on Step 11
    Thank you, you did a great job explaining your process.
    Very well done!
    Wi11
    7 years ago on Introduction
    Awesome! Though, a more specific name for your "hand chisel" is a gouge.
    weldor
    Another name for the tool you refer to as a two handled shaver is spoke shave.
    One time at Scout camp I needed a spoon and fork (I had forgotten to bring them) so I picked up some used boards similar to what you are using and carved them out with an old pocket knife. I am glad to see a young person such as yourself learning to do it in the shop so that you learn to make a good quality piece. Mine are rough at best.
    Keep up the good work!
    zomfibame
    Nice! .... do you have a picture of the finished product?
