Manual Fire Alarm
6,588
36
4
About: My name is Troy. I'm a Mechatronics graduate studying Mechanical Engineering. I like to make things and spend time outdoors (especially SCUBA diving). I am a Community Manager for Instructables.
Whether you are trying to get someone's attention, signaling danger, or getting a sporting event started, this manual bell will do the trick.
This manual trip bell features a lever activated clapper arm with a spring reset. This project was inspired by Measured Workshop's Boxing Bell YouTube video.
This is a simple metalworking project that can be done with limited tools.
Step 1: Tools and Materials
Materials:
Tools:
Step 2: Rough Cut Parts
Cut out and attach the templates to your steel. Cut out the pieces for the bell mechanism.
Step 3: Shape Pieces
Using a bench grinder, clean up the edges of each piece. Using a center punch, mark the center of each hole from the template.
Step 4: Shape Striker
Cut the outside of the tabs and bend them using a vise. Bend the end of the striker slightly. This angle can be changed later.
Step 5: Drill Holes
Drill 1/4 in. clearance holes for each piece. Shape the tabs round using a bench grinder.
Step 6: Bend Catch Tab
Attach the catch to the lever arm. Mark the edge of the lever arm on the catch. Bend at that point and verify it fits correctly on the lever arm. Mark and cut off the excess tab.
Step 7: Finish Mechanism
You can finish the mechanism anyway you like. I opted for a brushed metal look. I sanded each piece up to 180 grit sandpaper.
Step 8: Create Standoffs
Mount the 3/8 in. bar in your lathe. Drill and tap 1/4 - 20 in. threads. Be sure to cover the bed of your lathe to protect it from metal shavings. Sand and finish to your liking.
Cut standoffs to 7/8 and 5/8 in.
Step 9: Finish Bolt Heads
All the bolts should be finished to your liking. All of the bolts were mounted on the lathe to have the marking removed and to be shined up.
Step 10: Attach Catch
The bolt for the catch needs to retain some of the square carriage bolt profile. Remove a small amount of it until it only has the thickness of the catch. Finish the head of the bolt as shown in the previous step.
Using small files, cut the hole in the catch square. Attach the catch to the lever arm with a lock nut. This will allow the tension on the catch to remain constant. Cut off the excess bolt.
Step 11: Create Stops
You will need to create two stops for this mechanism. One 3/4 in. long and one 1 in. long both with 1/4 - 20 in threads tapped.
Mount the 5/8 in. rod in the lathe and file the end round. Finish to your liking and cut to length with a hacksaw. Turn the stop around and drill and tap the other end.
Step 12: Create Brass Striker
Turn a 7/8 in. long striker from 3/4 in. brass on the lathe using the same techniques as before. The brass was polished to a high gloss using buffing compound.
Step 13: Drill Spring Holes
Drill two spring holes in the top of the striker bar. One spring hole in the edge of the catch and next to the catch in the lever arm.
Step 14: Mounting Board
Using the attached template, mark and drill corresponding holes. All holes are 1/4 in. except the main hole in the middle for the bell is 5/16 in. Use edge banding to cover up the plywood edges and spray with lacquer. The corresponding holes for springs were just eyeballed based on spring tension.
Step 15: Assemble
Assemble the bell by fist attaching the stoppers (longer stopper on top). The lever arm assembly and springs are next followed by the striker arm. Finally attach the bell with a 5/16 in. carriage bolt.
Step 16: Attach Pull
I braided some black paracord with the traditional circle boondoggle stitching.
With that, your bell is complete! You can now hand it up anywhere you want to get some attention.
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    4 Discussions
    wingartistmwhalen5
    Reply 6 months ago
    What a drill press?
    Just a lathe standing up on it's end.
    tomatoskinsmwhalen5
    Reply 6 months ago
    Sure! You would need to use nuts instead of a threaded tube. You would also need to finish your bots using a drill instead of the lathe.
    AndresR145
    6 months ago on Step 16
    A really nice idea and remarkable craftsmanship.
