Marble Clock
31,370
367
46
Introduction: Marble Clock
About: Try again. Fail again. Fail better
Marble Clock is a 3D printed rolling ball clock that tells the time by the location of marbles/balls. It consists of 3 main rails, where,
  • The 5-minute rail with 1-minute intervals
  • The 15-minute rail with 15-minute intervals
  • The 12-hour rail with 1-hour intervals
add up and tell the time.
Outline
In the first step, I will give you a little bit of history of rolling ball clocks and ball clocks in general. Next, I will explain the Idea behind this project. Then I will give you an insight into the design process of this clock, so you'll be able to design your own clock. I'll give you a 3d print guide so you can easily print the required pieces and arrange them. After giving you a step by step assembly guide and show you how to sync your clock, I'll end the instructable with a troubleshooting guide. So, if you encounter any problems during your build you can solve them easily.
The purpose of this instructable is not just to give you a cookbook. I'll show you the way I built this project and provide you with open-ended questions, so you can add your own ideas, and take this project even further. Many parts I've designed are not connected. This way you can change the design to your own liking and then glue them together.
I strongly encourage you to share your build when it's done!
Let's get started.
Step 1: A Short History of Marble Clocks
This instructable is based on the design called "rolling ball clock" that was invented by Harley Mayenschein in the 1970s. He patented his invention and started a company which began to manufacture these clocks from solid hardwoods in the 1980s.[1]
The original rolling ball clock had 3 main rails, 2 for minutes and 1 for the hour. by adding the two rails one can get the total minute. This way the time was shown.[1]
There were many varieties of these clocks ... for example the kineticlock which had 10 minutes intervals instead of 4, or the Chronomeans Clock which was built with anodized aluminium.
Other rolling ball clock varieties:
Source:
[1] https://en.wikipedia.org/wiki/Rolling_ball_clock
Further Reading:
http://www.chilton.com/~jimw/ballclks.html
Step 2: The Idea
I've been a long time fan of ball clocks. I've seen one when I was a kid in a novelty store. And I just stood there watching it endlessly. The movement of the balls with time was magic to me. After I heard about the clock contest on Instructables. It gave me the Idea to try to design and build a ball clock from scratch. So I started to sketch on paper.
What I wanted to do was to design a different lifting mechanism instead of the traditional rotating scoop type design. So then it hit me. I was going to use a rotary to linear motion mechanism so while the mechanism was rotated by a motor the ball would be moving in a line, up and down. Creating a little illusion.
The rails were mostly inspired from other ball clocks but I had an idea to create a bell mechanism so everytime one hour passes there would be a sound. Unfortunately, I could not build this into the project.
Step 3: Tools & Parts
Note: these are the Tools&Parts I had available. You can use any other part for your needs.
Tools:
Parts:
3D Printed Parts :
all parts are on step 5 I recommend you to read read step5 before printing them.
Step 4: Design Process
You can skip this step if you just want to print the project. This step is for people who want to design their own ball clocks or want to add new features to this project. It gives an insight on how the ball rails were designed in Fusion 360.
If you are new to the Fusion 360 environment I suggest you take a look at a few tutorials.
You can enroll in this class: https://www.instructables.com/class/3D-Design-Clas...
also, this youtube series gives a good beginner tutorial: https://www.youtube.com/watch?v=A5bc9c3S12g
I suggest you to read this step after you've seen the tutorials.
Details on the design process are noted on the images.
Base Structure & Rails
The base structure is basically 6 rails holding 4 rods. The rods(8mmx8mm) were designed to be sturdy. They are held by bolts to a wood plate. The rails were inspired by the original rolling ball clock. But the dimensions are different due to different ball sizes and weight distribution.
Elevator
The elevator design was inspired by this mechanism. User mgg942 used this design and created a rotary to linear drive on Thingiverse . I tweaked and re-designed this to create an elevator mechanism.
Step 5: 3D Print
There are two seperate .zip files you can download.
The 3d parts.zip folder contains all the parts for the clock separately.
The 3d_parts_sets.zip contains 5 sets. each set is designed for a 25x25cm print area.
If you have a large print area you can print these like I arranged them in sets. Or you can print them separately.
I suggest you to finish printing before the assembly of any pieces. It's much easier if you lay them on a table in an arrangement. Like a LEGO set.
Each part is given a number and a letter. these will be useful while following the building instructions next step.
Step 6: Base Assembly
you can use the pdf template to drill holes on the wood.
Parts used in this step:
  • [3d printed] 1a-3f (28 parts)
  • 5 x 40mm M3 bolts & nuts
  • 6 x 30mm M3 bolts & nuts
  • 3 x 15mm M3 bolts & nuts
  • 6 x 10mm M3 bolts & nuts
  • 10 x 6mm M3 bolts & nuts
  • 4 x (3mm*6mm*2.5mm) ball bearing
Tools used:
  • Tack-it
  • philips head screwdriver
  • pliers
Estimated Time:
  • 15-20 minutes
Note: Assembly instructions are noted on the images.
Step 7: Center of Gravity
This is the most important part of this project. I did not design the rail pieces connected to the joints. This way everyone can adjust them to their needs. The rails and the connectors under them are not attached. You have to figure out the center of gravity and glue it when you are certain. Let's begin,
The 5min rail:
Slowly put 4 balls on the minute rail. And position the connector piece accordingly so it doesn't tip over. It should tip over when the 5th ball comes. This takes a bit of time to adjust. When you're satisfied go to the 15min rail.
The 15min rail:
Slowly put 11 balls on the rail. again it shouldn't tip over while 11 balls are on it. When the 12th ball arrives it should tip over.
The Hour rail:
This is the same as the 15min rail. wherever you glued the connector on the 15min rail you can glue it on the same place on the hour rail.
Lastly, to test them all at once put 11 balls on the hour and 15min rails and 4 balls on the 5 min rail. then drop one ball to the 5 min rail. They all should go smoothly and leave the rails
Step 8: Elevator Assembly
  • [3d printed] 4a-5d (9 parts)
  • 1 x 25byj-48 Stepper
  • 1 x (F6-14M 6mm x 14mm x 5mm) Thrust Bearing
  • 2 x 10mm M3 Bolts & Nuts
  • 2 x 25mm M3 Bolts & Nuts
  • 2 x 6mm M3 Bolts & Nuts
  • 4 x 40mm M3 Bolts & Nuts
Tools used:
  • Tack-it
  • pliers
Estimated Time:
5-10 minutes
Step 9: Driving the Motor & Timing
How to drive the motor
To drive the 28byj-48 stepper motor with a constant speed I've used an Arduino Uno with the AccelStepper library. you can download the library here . If you don't have experience with Arduino or don't know how to install libraries you can check this site.
Connect the pins on the stepper motor to the Arduino like this:
Stepper---Arduino
  • IN1 ----> 2
  • IN2 ----> 3
  • IN3 ----> 4
  • IN4 ----> 5
After uploading the code you are good to go!
Timing
The most important thing about a clock is precision. We want this clock to be as precise as any other wall clock/ watch so it works without any error. To do this we have to change the speed of the motor so the elevator completes 1 revolution in 60 seconds precisely.
Now get a stopwatch in your hand and run the motor. Start the stopwatch when the elevator gear crosses a specified point. And stop your watch when it crosses the point again. Take a note at the time. now let's calculate the required speed
T = time on your stopwatch
t = 60s (time you want it to complete 1 revolution)
M = old motor speed("stepper.setSpeed()" in code)
m = new motor speed("stepper.setSpeed()" in code)
new motor speed(m) =(T*M) / t
Insert this into the code and check your stopwatch again, repeat this until you are satisfied with the result
Step 10: First Test
You're done with the build now it's time to test this clock!
Check your watch and put the balls according to the time. And start the motor when you are ready. It's really fun to watch time go by with this clock. Go and put yourself some tea and enjoy the sound off balls clicking. Now while doing that you should check a few things to be sure that this clock can run for 7/24 straight.
Things to look for:
  • Can the elevator bring a ball without dropping it each minute?
  • Are balls not getting stuck on the rails after 2-3 hours?
  • Is the clock on time after several hours?
If your answer is no for at least one of those questions, you can check the Troubleshooting step!
If your answer is yes, then congratulations you've built a precise ball clock!
Step 11: Troubleshooting
- Balls are not moving easily on the rails
Sometimes filament residue blocks the balls. use a sandpaper to sand the pieces.
- The motor is stopping after a few hours.
Try to connect external power to the motor.
-the balls are falling even though I set them not to fall
The surface the clock is on can effect this try to change the location of the clock
-The clock is not on time
Repeat the timing step as much as you can until you are satisfied
Step 12: What's Next
There are lots of things that can be improved on this clock. Here are a few that I have in mind.
  • Adding an am-pm rail.
  • Adding a bell so it makes a sound every hour.
  • Creating a more stylish ball descent system. instead of the ball tower that just drops the balls.
  • Make a bigger version with different kind of balls
I hope you enjoyed this instructable.
If you have any questions ask away! & tell me about your build!
Clocks Contest
First Prize in the
Clocks Contest
    • Metalworking Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    46 Discussions
    Does anyone have a CAD file or dimensions and measurements for the base and holes in the base? It doesn't have any dimensions and I'm going to cut mine out on a laser so I'm going to need to make a CAD file if there isn't one.
    1 more answer
    I guess it is supposed to be printed on DinA4, so just print it out and measure it :)
    Here is where I'm done, functional, not yet finished. Rails must be assembled at first. I've made a stronger ladder by doubling posts thickness. Base plate must be rigid to preserve geometry, I chose 5 mils MDF instead of acryl. Also, I did not choose the bearing version for swivel but I prefered a 4mm diam brass tube on 3mm screw all along rail width (12mm), a nearly no play assy ( bushing) much easier to align. At second step, the reception part must be built with the same logic of stiffness. For elevator, I've printed gears out of ABS cause I don't believe in rotating mechanical parts made of PLA. When ready, I'll make a longrun for reliability check. At last, motor speed, synchro and precision will be matter of software but peanuts in regards to that mechanical system made from printed plastics....
    What diameter were the balls you used? looks like a fantastic build. Getting stuff ordered so I can make one too.
    2 more answers
    He updated his instructable: 11mm Steel Ball
    I've used 11mm diameter steel balls.
    I forgot to add it thanks for pointing it out!
    I've used 11mm diameter Steel balls
    Ok, because I looked to see if I missed on one of the pages. Thanks for the update. Can't wait to get started.
    Very nice instructable.
    26k views just in a couple of days wow, I hope some of those will also contribute to this project.
    Here is just an idea:
    metal + plastic doesn't play well on the longrun, if your motor have a small metal/copper gear on it which will move a bigger PLA gear the metal will "eat" the other gear with time, especially if the clock operates 24/7.
    Also someone could design a proper printable base board.
    Very cool. I'm another guy who had one of these as a kid and I look forward to trying to make this one. Like some others, my printer isn't big enough to print the large parts. I have an idea to try to make the large gear and the crossmmember on my CNC router. Would you be willing to make the CAD files available? Sketchup would be ideal but I'll take whatever you are willing to provide.
    1 more answer
    There is always the simple possibility to import stl files into Sketchup. That works great for such not so complex drawings
    Great job ! To bad most printer on the market are 200x200... possible To resize /adapt ?
    This just fits on my Anet A8 which has a print bed size of 220 x 220
    Yes of course!
    You can print the parts seperately.
    Rather than gamble with the delay in the C code, why not set up a periodic interrupt using timer off the clock crystal (say 16 per second, or whatever is convenient) and run a piece of code that increments the stepper drive? This way, while the code produces time jitter, this is on the microsecond scale and does not accumulate. You will have much better control of the speed.
    Thanks for the tip! I was actually going to use a Real Time Clock (RTC) module but I wanted the movement to look continuous. When using little increments to move the stepper the gears look like they are lagging. But you are right. It's more accurate to use such method. I will add this option on the last step & update the Instructable accordingly.
    Very interesting project. Congratulations!!!
    I plan to build it. Will You update just time settings method?
    If yes i will build it.
    If you will update mechanical parts too, then i must wait version 2.0
    Sincerely,
    Thank you!
    I will add it as an option to the step after I test it. I will also update the mechanical parts in the future for a ver 2.0 according to feedback(This is a prototype after all). If you want you can build it right now and give me feedback, or you can wait for an update.
