Medieval / Renaissance Box
16,031
349
28
About: https://www.facebook.com/leplanhisto/
hello everybody,
On this instructable, im going to explain to you how i made the reprodution of thi box possible.
Supplies:
Step 1: Create Plans From the Original Box
Before explaination , let's talk about this box :
This box was sold in a auction house in france last year and we found it's image on the web.
The commisaire in charge estimated the box from the XIII th century but the lock is from the XVI th century, at some point , it must have been changed.
The particularity of this box it's that the head is made in one piece of wood
Dimensions from the original :L 32cm x l 23cm x H 21cm
Origin: france
Wood: chestnut
Now , with all of theses elements, i did the plans and lets go for step 2
Step 2: The Head of the Box
So, the original was made in chestnut, but in France today, it's simply impossible to find a piece of chestnut that size, so the idea was to use elm .
This kind of work can only be made by hand:
first step using scisels is to cut out the inside of the head , clean it and sand it.
second step, using hand saw, the outer part of the head was cut.
Voila !!!!
Step 3: Assembling the Box Itself
Now that's the easiest , assembling the box and the head.
step one: cut the board and give them the right angle .
step two: glue all together with wood glue and the box is done
sanding and finishing
Step 4: Dyeing Step
Now it's dyeing time, looking back at the original, the idea is to use tincture, with different try and mix, to approach the color of the original box
Step 5: Creating Templates for the Metals Parts
The idea is to glue the the part of the plans wich corespond with metal part on cardboard (cereal boxes for exemple )
and then once i got the templates, i put it on the metal plaques and spray paint it.
Thickness : 1.5 milimeters
Now start the longest work.....
Step 6: Making Angle Irons and Hinges
after cuting all parts with the metal hand saw ( jewlery hand saw ), all the paterns where made using metal file ( needle file )
and believe me , it take time !!!!!!!
Step 7: Bending All Metal Parts
for this step what you need to know :
In order to have the iron angles at the proper angle , you need to bend it and then re-open it, for that the parts must be heated at each step of the bending.
Step 8: Finishing Hinges, Lock and the Box Handle
All the photos are in the right order, sorry
the handle : after drawing a template or patern , the handle was bend and forge then monted on the iron angle
The lock: actually it's a lock without mecanism for the moment, but it come one day.
all the metal parts were cleaned with metal whool and polish with bee wax
the hinges: bend and monted together
Step 9: Assembling
Now evrerything is done, it's time for assembling
Every metal parts has been mouted with nails, wich have a head like a half ball ( dont know it's name in english )
The box is protected by a plastic film, the same that we have in our kitchen.
The metal parts can be placed at there right place and marked before nailing
Step 10: Box Finished
For making this box i used :
A plan from : leplanhisto.com
Big piece of Elm
Spare parts of metals
Wood work: 16 hours
Metal work: 30 hours
Thanks for watching, you can follow us on facebook: leplanhisto
Make a Box Contest
Grand Prize in the
Make a Box Contest
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    28 Discussions
    Kierana
    2 years ago
    This is a great instructable for a fantastic reproduction. Congratulations on the enormous amount of hand work needed to complete this accurately.
    Dersky99
    2 years ago
    If you truly want a brown finish for the metal you can use Metal Browning liquid that gunsmiths use. It's like the Bluing liquid but turns the metal a nice brown.
    leplanhistoDersky99
    Reply 2 years ago
    thanks, it is a really good idea but it is not historical, if i put a product on it it has to be accurate
    Dwargh
    3 years ago
    A fine piece of art and handcraft, dear sir, which is hard to find these days!!
    Good work!!
    warriorethos2
    3 years ago
    Great work. I like that you carved out the inside of the lid first and then cut the gable on it afterwards. I don't know if that is easier than cutting all the angles and then putting it together but it looks real nice. The metal work is just as great. Good job and good luck in the contest.
    chuckmadere
    3 years ago
    A very nice and detailed instruction.
    twighahn
    3 years ago
    Lovely. Needs a real lock
    leplanhisto
    3 years ago
    Thanks you all
    to explain a little our process
    the main idea was to reproduce identicly the original boxe , it is why there is not brass but iron. I agree whith you brass would have been really nice. This box was made to carry precious thins as money, jewlery etc.....
    you can follow our actuality here:https://www.facebook.com/leplanhisto/
    and you can find the plan here :http://leplanhisto.com/produit/coffre-chest-13/
    Dawsie
    3 years ago
    wow it's a stunning rendition of the original, I just asked me Dad and he said the half ball head nails would have been called rivets :-)
    I love what you have done it's a lot of work that's for sure it would look great with either Brass or copper sheeting in place of the metal :-)
    If I had the time I would love to try my hand at it but I have enough hobbies already without adding yet another to the list :-) but if I do find some spare time one day I just might make it as it would be a great box to put Dads ashes in once he joins Mum one day and I can add Mums to his in the one box I think She would have loved it :-)
    Thank you for sharing your Instructable with us :-)
    Londonbrig0
    3 years ago
    Beautiful work. 800 years from now they'll find this antique, date it to the XXI century, and remark on the amazing craftsmanship in an age of mass manufacturing.
    LeslieGeee
    3 years ago
    Beautifully done Leplanhisto!!!! I was thinking that copper flashing sheets could also be used for the metal parts, and can be lightly hammered, as a different take. :)
    Quander
    3 years ago
    amazing work,,,good job.thanks for sharing.
    dorchard
    3 years ago
    Beautiful and skillful reproduction! Thank you for sharing!
    Shibinrajk
    3 years ago
    The design has a great deal of resemblance with Kerala Jewel boxes.
    leplanhistoShibinrajk
    Reply 3 years ago
    yes indeed ,i ve just discoverered it, very surprisng !! thanks
    Patxi Alai
    3 years ago
    I've get out of words. The very idea of doing this work, is a big bet, and show value and knowledge. Congratulations on your work.
