Melt in Your Mouth Ribs
8,810
128
52
About: My name is Christa. I'm interested in history so I'm a Rennie. I've been sewing since I was little and was introduced to cosplay and conventions by some friends of mine in college. I love art and music and l...
I'm a modest person, there are many things I don't share on Instructables because I don't think it's perfect and thus it's not good enough to post. I'm my own worst critic.
That being said, I'm a Texan and I used to work for a BBQ pit to help pay for college. I have never had ribs (made by a person or a restaurant) that are as good as these. The secret is keeping the moisture in the meat. When you're done they shouldn't be difficult to cut because they're so tender and falling apart.
As a Texan I prefer dry rub over southern style sauces. I feel like the meat should have enough flavor it doesn't need a sauce, it should be savory and have a little bite to it without being overly hot. Some of this is because if it's just hot without flavor it seems like you don't know how to flavor the meat. The other part is my husband can't even handle too much pepper. (Sorry honey, I love you!) So let's make the best ribs you'll ever have. ;)
Supplies:
Step 1: What You Will Need
I place a couple of dishcloths on the counter to keep the cutting board from sliding while I'm working with the ribs. You'll need a roll of aluminum foil, a large cutting surface to work on and a good knife. The ingredients are easy! Mayonnaise (NOT miracle whip), Cajun seasoning and babyback ribs. It's easier to cook them on a baking/cookie sheet if you have one but mine bit the dust last week so I used a roasting pan I had on hand. You can make these on the grill if you have one, but I made them in the oven for this recipe.
Step 2: Dry and Trim
Preheat your oven to 300°F (149°C). Dry off the blood from the ribs and trim the fatty tissue off of the end. This is pretty easy to do, it just is a little tedious because it may come off in pieces. Take your time so you don't accidentally cut off the meat. That's the good part!
Step 3: Score the Membrane
The membrane attached to the rib bones acts as a moisture barrier and stops it (and the flavors from the rub) from getting through to the meat. I've seen people cut it off but it's a giant pain in the butt and completely unnecessary. I just score it in a crosshatch pattern with my cutting knife. A couple of good passes for each line is good enough, you just have to get through the membrane.
Step 4: Tenderize the Meat
Nobody likes tough bbq, and if you tenderize the meat with your knife then it gives the seasoning and mayo a place to soak in more thoroughly. Take your knife and stab the top of the ribs all the way across until they're perforated. You're just going through the top, don't stab so hard that you cut all the way through the meat.
Step 5: Moisturize
The way you get fall of the bone tender ribs is make sure they retain their moisture. You could only wrap them, but using mayo adds a lot of extra moisture and is the secret to why they're so tender! Make a line of mayo across the ribs and massage it into the meat until it covers (this includes the sides!). If you're like me and you hate the feeling of raw meat, this will be the most disgusting thing you've ever felt. Just grit your teeth and bear it.
Step 6: Rub
The Cajun seasoning is the perfect dry rub: tangy, savory and a little bit spicy. It soaks into the meat and tastes amazing! Take your seasoning and shake it back and forth to cover the ribs in a light layer. Make sure you get the top, bottom, and all of the sides!
Step 7: Wrap
You want to wrap the ribs completely in foil to trap the moisture in while they're cooking. Lay them out and fold over the ends then fold over the sides. Pull another sheet over where those sides are together to cover the gap they create and flip them over. Fold again the same way and place them bottom side down on your baking sheet then place in the oven. You want them bottom (bone) down to begin with so the moisture will rise and permeate through the membrane.
Step 8: Cook and Flip (a.k.a. Wait Forever)
Place your wrapped ribs bottom side down on your baking sheet and place in the oven. Set the timer for 1.5 hours. When the timer goes off, flip them over to their top side and put them in for another 1.5 hours.
Step 9: Cut and Serve
Be careful removing the foil! It's full of extremely hot steam and juices from the ribs. You can easily burn yourself if you put your hand over the opening in the foil. Gingerly remove it and let the ribs rest for 10 minutes. They will be so tender you could pull them apart so you will also need care in cutting them apart. Take your knife and follow slowly along the bone as your guide. Serve and enjoy!
  • Fandom Contest
    Fandom Contest
  • Classroom Science Contest
  • Arduino Contest 2019
52 Discussions
briscaF1
1 year ago
This is a great recipe and our "go to" ribs method after trying others that just didn't work.
We normally use BBQ or jerk rub but next time will try Chinese five spice.
Thank you for this.
SwansongbriscaF1
Reply 1 year ago
Awesome, I'm glad they worked out for you. :) Five spice sounds yummy, you'll have to tell us how it turns out!
dan adams
1 year ago
Whoa this looks delicious! Can't wait to try it. Great use of gifs too!
Swansongdan adams
Reply 1 year ago
I appreciate it, I hope you enjoy them!
chefspenser
2 years ago
I tried this over the weekend...maybe I used too much mayo because they were a bit soggy. Might try without the mayo as a second starting base and go from there. I'm thinking possibly poking a few small hols for the las 30 minutes on the third trial, if #2 is too wet. All in all, they ere delicious and thank you for the post!thi
Swansongchefspenser
Reply 2 years ago
It sounds like you may have used too much mayo, it doesn't take a lot. Just enough to coat and stick the rub to it. I hope the next batch comes out better. :)
Feeble
2 years ago
Really good!
This is, by far, the easiest recipe for good ribs that i found so far. Definitely something to put in my map with favourite recipes. I made them and they were great. A little too crispy, but that's because i didn't wrap them well enough and they started to leak.
Also, no dirty oven, no dirty dishes (almost).... Great recipe.
SwansongFeeble
Reply 2 years ago
I love the easy cleanup too! Glad you enjoyed them :)
ReaA6
2 years ago
My ribs are always fall off the bone, seasoned or not. The secret is in the meat. Buy the best grade meat you can afford, but even the cheapest will come out de-lish if cooked this way. This is only one method I use. But if you want that " off the grill flavo ", this is it! Braise the ribs on the lowest range top temp that you can after first bringing to a boil and immediately turning down to lowest temp. Cover and braise for half an hour, turn, braise another half hour. Take off heat, leave covered, and let rest for 15 minutes, ( forgot to say tilt the lid slightly so they don't ' steam '. Take out and place on platter to cool completly. These an be made hours in advance but do not refridgrrate. When ready to serve, throw on HOT grill, ( with or without sauce ) to get grill marks. After the first stage of braising, be very careful handling as they will start falling off the bone soon after.
watford
2 years ago
My wife makes this in a similar same but instead of wrapping them in foil she just sits them in the pan with foil sealing the top of it while adding lemon juice and water to the bottom. A friend showed it to us many years ago. He said using a slow cooker makes it even more tender and juicy but doing it the way she does as I mentioned it basically falls off the bone anyway. I think she uses butter instead of mayo. I know for sure that she doesn't use mayo. Is there any reason you prefer mayo to butter?
Swansongwatford
Reply 2 years ago
Honestly, I haven't tried it with butter. Mayo was the way I was taught at the pit so it's how I got started. I'd be worried about the butter adding a lot of salt to the flavor with this rub though, it's already really salty. It would probably be yummy with other seasonings. ^.^
ReaA6Swansong
Reply 2 years ago
the answer is simple. Use UNSALTED butter. ?
watfordSwansong
Reply 2 years ago
She only uses unsalted butter and she doesn't use a mix of spices. She always mixes her own spices and I couldn't even begin to imagine what it is she uses for this. She's always been good with spices in my opinion.
