Mentos PowerBank
22,083
471
28
this is my first time doing an instructable so go easy on me
Supplies:
Step 1: Stuff You Need
18650 3.7v 2200mah (from old laptop battery)
1A lithium charging module ($1.39 dx.com)
0.9v - 5v step up boost module ($1.99 dx.com)
slide switch ( from a broken toy)
Mentos chewing gum container
Step 2: Wiring
solder wires into module and battery + to + and - to - dont put it on backwards unless you want your modules to get toasted
Step 3: Stuffing Everything Inside
this is the hardest part for me since the container is too small. but you can figure it out.
Step 4: Done!
dont expect this to full charge your phone. when charging the powerbank red led means charging and green for full
  • Fandom Contest
    Fandom Contest
  • Gardening Contest
    Gardening Contest
  • Classroom Science Contest
28 Discussions
betmachassantobah222
Reply 7 months ago
Yes, use as many as you like as long as its parallel, but the problem would be charging time unless you can charge each cell individually
Ganesh sivakumar
2 years ago
instead of a 2200mah battery can I use 9v battery
DaytonaPete
3 years ago
Very nice and simple. I'm building one!
betmacdmahato
Reply 3 years ago
www.dx.com/p/tp4056-4-2w-1-2a-5v-lithium-battery-charging-discharging-protection-module-w-micro-usb-blue-397213#.VgXcBTOwrqA
kartik negandhi
4 years ago
can I connect 4 18650s in parallel to extend the mAh of the bank? or if not 4 den at least 2?
neopolitankartik negandhi
Reply 4 years ago
yes in theory, but in practise you need to isolate the cells from each other
Please explain what you mean by "isolate the cells from each other". I would like to use the same parallel design suggested above. Thx!
lazychris2000OrlandoSailor
Reply 3 years ago
Basically, you would use a diode on each battery to prevent it from back-charging the other batteries.
Make sure you install them in the correct orientation because it only allows the charge to flow in 1 direction
betmacMagnusK
Reply 4 years ago
im not sure. i just scavenge those wires from a broken fan.
JasonM11
4 years ago on Introduction
if you want longer batt life you can get wafer type RC 1 cell lithium's from hobby king for a very cheap price, great build by the way.... Lastly everything in life is dangerous however, this isn't going to be risky the current coming out of the battery is very low. If you were to allow the battery to get to low of a charge and it was an unprotected battery then you could have an issue. but that battery is protected so there isn't any worries there.
samalert
How much time does is take to fully charge a cell phone from Dead.
shane better
4 years ago
Isn't this really dangerous because of the heat and the lithium ?
