Metal Detector Kit
About: I am a photographer, a tinker, an electronics technology engineer, and author; I write short stories and poetry for the love of writing. I started writing poetry in high school over thirty years ago where I ...
Metal Detector Kit
Metal Detectors are used for more than hunting for buried treasure on some tropical beach. In the food industry metal detectors are used to detect foreign metal and parts of the machinery in the food. In security they are used to detect weapons. In production equipment they are used for position detection and counting parts. You can even use them for game entertainment or a proximity switch on a toy train set.
This is a kit I got off of Ebay just for the fun of building. While testing it I found some of the results interesting.
Metal Detector Specks
Operating Voltage DC 3-5V
Operating Current 40mA
Standby Current 5mA
Detection Distance 60mm
Alarm mode Sound/Light
Difficulty Easy
PCB Size 86*61mm
Step 1: Tools
Circuit Board Holder
Solder
Soldering Iron
Needle Nose Plyers
Side Cutters
Spring Loaded Tweezers
Small Standard Screwdriver
Component tester
Step 2: Component List
1. Metal Film Resistor R3 470ohm
1. Metal Film Resistor R2 2K
1. Metal Film Resistor R1 200K
1. Potentiometer VR1 100R
2. Ceramic Capacitor C2,C3 0.022uf
2. Ceramic Capacitor C1,C4 0.1uf
1. Electrolytic Capacitor C5 100uf
1. Red LED LED1 5mm
1. S9012 Q2.Q3 TO-92
1. S9018 Q1 TO-92
1. Power Switch SW1 6*5mm
1. Buzzer SP1 9*12mm
1. Power Socket J1 KF301-2P
1. PCB MDS-60
The power switch was missing from the kit but since I had a compatible one in my stores this didn’t slow me down.
This kit did not come with a battery pack; and since this metal detector runs on 3 to 5 volts, I suggest you use a 3 battery holder so if you use 1.2 volt rechargeable batteries for 3.6 volts, or 1.5 volt alkaline batteries for 4.5 volts both give you the voltage you need.
Step 3: Schematic
Although the component placement is obvious on the printed circuit board, and there were no assembly instructions, I reverse engineered a schematic just for those that like them.
Step 4: Assembly
I like to check my parts with a component tester first, it is no use assembling the circuit board with parts that don’t work.
I started at one side holding the components in place with spring tweezers.
Then I soldered the component in place.
This printed circuit board is small; so if there is excess lead, cut the excess off before going to the next part. This will prevent the leads of the previous part from interfering with soldering the next part.
Continue testing and attaching components until the circuit board is assembled.
Step 5: Calibrating the Metal Detector
Remove the tab on the face of the buzzer and attach the battery holder.
Making sure you are nowhere near metal; turn the metal detector on, the LED, (Red Arrow) and the buzzer, (Blue Arrow) may or may not come on.
If the LED and the buzzer do come on adjust the 100 Ω pot, (Yellow Arrow) just enough to turn them off.
If the LED and the buzzer don’t come on; adjust the 100 Ω pot until the LED and buzzer do come on, then adjust the pot the other way just enough to turn them off.
The LED and the buzzer should come on at the same time.
Step 6: Testing
This metal detector is weak; however I tested the detector on a variety of metals and other objects and these were the results.
Gold, Detector Weak Response
Silver, Detector Weak Response
Copper, Detector Weak Response
Lead, Detector Weak Response
Bismuth, Detector Strong Response
Brass, Detector Weak Response
Nickle, Detector Strong Response
Steel, Detector Strong Response
Cast Iron, Detector Strong Response
Aluminum, Detector Weak Response
Neodymium magnet, Detector Weak Response
Ceramic magnet, Detector No Response
Iron magnet, Detector Weak Response
Toroid core, Detector No Response
Transformer core, Detector No Response
Graphite Mold, Detector Strong Response
Oddly enough I thought I would get stronger responses from the magnets because of the magnetic fields effect on the pickup coil. I also expected a stronger response from the powdered iron cores like the toroid or the transformer core. Most of all, the graphite mold gave a strong reaction and it has no metal in it.
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    10 Discussions
    julianop55
    Question 6 months ago on Introduction
    I'm interested in that component tester; would you tell me where to find out more about it?
    Thanks!
    Josehf Murchisonjulianop55
    Answer 6 months ago
    I like it more than the ones in my multi meters.
    Make sure the component is well seated and press the button. It automaticaly detects NPN and PNP transistors, N -channel and P-channel MOSFET, diodes, dual diodes, thyristors, triacs, resistors and capacitors, inductors and their values. It shows you the pins and the symbol. After a minute it will automatically turn off.
    With 3 pin; voltage regulators, voltage detectors, and shunt regulators, it will show (4 damaged or unknown part), 1 or 2 resistors or diodes.
    I got mine here:
    https://www.banggood.com/LCR-T4-Mega328-Transistor...
    And here is how to assemble it:
    https://www.instructables.com/id/Assembling-the-LC...
    senatutor
    Sirve para detectar cables electricos tras una pared? Lo ha probado? que resultados obtuvo?
    1 answer
    Josehf Murchisonsenatutor
    Answer 6 months ago
    No había intentado detectar cables o tuberías en las paredes antes de que me lo pidieras. Sonaba como una prueba divertida, sin embargo, cuando lo trino, los clavos y tornillos en la pared arruinaron los resultados. Se hizo un mejor buscador de estudios.
    technovative
    6 months ago
    Intriguingly, I recently recieved that same kit, but haven't yet assembled it. Your article contains information sure to be useful in building, and using the device. Thanks for sharing.
