Metal Man Pencil Holder
14,795
185
17
This looks cool and makes a pretty generic gift (most people have pencils, right?)
Supplies:
Step 1: What You Need:
- Hacksaw
- Coping saw
- Bench grinder, file, or DREMEL with grinding bit
- Sheet metal
- Vice grips (one pair the needle nose type)
- Protractor
- Blowtorch (if you want to heat treat the steel)
Step 2:
- Download the PDF below and print it off
- Cut out the metal man and attach it to your piece of steel ( I like using magnets to attach the paper)
Step 3:
- Use the hacksaw to cut out the body and the coping saw to cut out the head
Step 4:
- Use the bench grinder, file or DREMEL to round the head and shoulders, and touch up any rough cuts
- If you want the pencil holder to be shiny or want to heat colour it use the bench grinder, file or DREMEL to remove the scale (if there is any; the scale is usually dark grey)
Step 5:
- Use the vice grips to bend the arms and leg to the angles specified in the template (you may need some leverage)
- The "wrists" are indicated by the black rectangles on the template
- You may need to grind or file the feet to make the pencil holder stand without wobbling
- Use a file to remove any marks left on the pencil holder by the vice grips
Step 6: Heat Colouring; Optional
- To heat colour the pencil holder take the blowtorch and "paint" the pencil holder with heat, pausing for about a minute after every few "strokes" to let the colour sink in
- Here's a list of the approximate temperatures (Fahrenheit) at which colours form:
Pale yellow 400 – 420
Light Yellow 430 – 440
Yellow 450 – 460
Straw 470 – 480
Dark Straw 490
Bronze 500
Dark Brown 541 – 520
Light Purple 530
Purple 540
Dark Purple 550 – 560
Blue 570 – 580
Dark Blue 590 – 600
Light Blue 610 – 620
Blue Green 630 – 640
Grey 650
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    17 Discussions
    M3GMartinD30
    Reply 1 year ago
    Awesome, great work!
    squared59
    1 year ago
    Quick easy project. I added feet to mine. It makes it a little more stable
    M3Gsquared59
    Reply 1 year ago
    Looks great, thanks for sharing!
    pclarke2
    4 years ago
    Great little idea, shall have a collection of little men all round my workshop soon.
    M3Gpclarke2
    Reply 4 years ago
    Thanks, I'd love to see pictures!
    Tinworm
    5 years ago on Introduction
    first off...I think this is a terrific project, very nicely presented!
    But can I say a word on safety. Never hold a file by the tang (as in your generic picture of a file). Always have the tang firmly slotted in a wooden handle. It is so easy to jam the tang through your hand. I liked the way you used gloves when handling the steel.
    M3Glsaerens
    Reply 5 years ago on Introduction
    You could use any thickness around 1mm, but I used 16 gauge, which is 1.5mm thick.
