Miniature Fairy Garden Terrarium - Enchanted Mushroom Lights
14,352
226
12
Hi, in this tutorial I made a fairy garden terrarium with mushroom lights and a fairy mushroom house. I used some extruded polystyrene (xps styrofoam), battery operated led lights, transparent sanitary silicone sealant, tin foil, copper wire, hot glue, a little bit of polymer clay, moss and acrylic paint. I also used a glass cake cover.
Step 1: Preparing the Board
I first cut the styrofoam board to fit the glass cake cover. I adjusted the corners with a cutter, then I painted it black.
Step 2: Adding the Lights
I then glued the lights to some pieces of copper wire. I made the wires in different lengths and also left more wire in the upper side (that will be helpful when making the mushroom caps). I glued the copper wires to the foam board with hot glue. I added some volume to the board using tin foil and hot glue.
Step 3: Making the Mushrooms
I mixed some red acrylic paint with silicone and made a paste. I applied the paste on the wires and leveled it using soap and water. For making the mushroom caps I used the silicone paste and wrapping foil. I applied some paste on the plastic foil, and covered it. Then I started shaping it into a mushroom cap. For making the round shapes I used the cones inside of an eggs carton. I also covered the tinfoil base using the same silicone paste in black. Using some tin foil I made a cone and covered it with polymer clay. I sculpted a little house, baked it and painted it with acrylic paint.
Step 4: Moss and Details
I placed the moss over the board, carefully mixing the patches and used toothpicks to fix it in place. I also made some cute white dots on the house using white silicone.
I love the result! The transparency of the silicone makes the mushrooms look amazing, and when the glass cover is on, it really looks like an enchanted miniature fragment of a fairy tale is in my house! :)
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    12 Discussions
    sicnarff
    Question 3 months ago on Step 4
    Hi where do you buy polymer clay
    Thank you
    Fran
    Eleish
    2 years ago
    This is absolutely awesome!!
    RobinF58
    2 years ago
    love it-how creative!
    RolanG
    2 years ago
    WOW!!!
    SirCooksalot
    2 years ago
    That's really beautiful, super cool creative idea. I have 2 questions- when you say you leveled the silicone with soap and water, how do you do that? Also- is that real moss? Thanks for the help!
    Pothuset
    2 years ago
    Nice diorama
    MarkA248
    2 years ago
    Nicely done!
    Riffifi
    2 years ago
    *O*
    this is gorgeous! i've already seen a tutorial to make silicone mushrooms lights, but i like the idea of the glass house/snow globe (plus it eases the cleaning!)
