Miter Blocks - Cutting Straight Without a Miter Saw
12,470
99
7
About: I'm an Engineer. I like hiking, flea markets, and electronics.
In this instructable I will show you how to cut straight without a miter box. This is useful when cutting a wide piece of wood, especially without access to a table saw.
Step 1: Cut Blocks
In this step make "rough" version of the blocks:
  1. Take two square cubes.
  2. Saw them in half.
Step 2: Prepare Blocks (Optional)
Although you can use the blocks as-is from the previous step, you may want to prepare them for further re-use. It's easy to mistake them for one-time-use wood scraps otherwise.
  1. Label the top of the blocks to identify where they will go when cutting.
  2. Put tape around the blocks.
  3. Put rubber cement on the bottom of the blocks to create more grip.
  4. Finish the blocks. I used a mixture of bees wax, mineral oil, and walnut oil in equal parts.
Step 3: Position and Cut
In this step, position the blocks and cut. They act as guides for the saw.
  1. Draw a straight line.
  2. Clamp down left-side blocks.
  3. Position saw.
  4. Clamp down right-side blocks.
  5. Cut.
Leave some wiggle room for the saw or it will be difficult to cut.
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    7 Discussions
    vreinkymovcmharris90
    Reply 5 years ago on Introduction
    No, I think this would only work well for a hand saw. You might be able to use a circular saw by clamping down a thick/straight edge that you can use as a guide.
