Modular Sandpaper Organizer Cabinet
5,539
164
13
About: I make all sorts of stuff. You can watch my YouTube Channel or Follow me on other Social media!
In this Instructable, I'll show you how I made this Modular Sandpaper Organizer Cabinet. Hope you find some inspiration to make your own!
Be sure to watch the Video above that goes side by side with this article and Subscribe to my YouTube Channel for upcoming projects!
I build this storage cabinet to organize the sandpaper and different things that I use for sanding. It also holds the random orbit sander on the top. Its made from 12mm birch plywood with rabbet and dado joinery. no screws, dowels or nails needed to build this.
Supplies:
Step 1: Materials and Tools
Tools Used:
  • Circular saw Table saw ( this is the one I used: http://amzn.to/2jL1PnX )
  • Orbital sander ( or anything that you can sand with)
  • Forster Bit
Materials/Supplies:
  • 12mm Plywood 3mm hardboard ( for the pull out shelves)
  • Tape measure
  • Sandpaper
  • Wood Glue
  • Clamps
  • Water-based poly
Step 2: Cut Your Pieces to Size
I have started to lay out the stuff I wanted to put in the organizer to get a better understanding what the height, depth, and width is for each sanding related item to get the maximum use out of the cabinet. I include a removable middle divider.
I cut all the pieces for the cabinet from 12mm plywood including the back piece. I left the two side pieces in one larger piece so the slots and the joinery would come out exactly the same in both pieces.
Although I used a table saw for most of the build but, you surely can make this with just a circular saw and a straight guide to cut the pieces, cut the rabbets and slots for the shelves.
Step 3: Joinery and Shelve Slides
Now that every plywood piece is cut to size, you can go on with the joinery. Cut the Dado's and rabbets on the side piece for the top, bottom, and the back with several passes thru the blade, always test with a scrap piece of the same plywood for a tight joint.
I decided to place the Sandpaper sheats on the lower half of the cabinet so I cut 4 slots for the shelves in 12mm spaces. The rest of the cabinet is divided into 25mm spaces.
After all the cuts were made you can cut apart the two sides.
The top and the middle shelf also get a dado to receive the removable divider. this slot is 24mm wide you see the reason for that in the next step.
Step 4: The Removable Divider
The groves for the sliding shelves are 6mm deep, and when I realized that I can't cut 6mm from both sides on a 12mm thick material ( duh) I decided to glue 2 pieces of 12mm thick panels together.
After gluing and trimming all the sides of the divider I cut the grooves for the shelves with a distance from 25mm to each other like I did on the sides.
Step 5: Assembling the Cabinet
Use some wood glue on all the dado's and rabbets of the side pieces and put in the top, bottom, and the middle shelf. Make sure you don't put any glue on the top and middle shelf where you cut the 25mm dado for the removable divider so it can be that what its name is!
Glue on the back piece of the cabinet but be careful when you apply the glue that it doesn't get in the small grooves where the hardboard shelves go.
I didn't use any screws or nails to hold this cabinet together just wood glue and some clamps.
You surely can use only screws and Glue for the joinery to avoid the dados and rabbets.
After the glue has dried I sanded the box to p180 grit with my random orbit sander and applied two coats of Water-based poly.
Step 6: Making the Pull Out Shelves
After the cabinet has been assembled you can measure the exact dimensions of the hardboard shelves and cut them to size.
My sanding discs for the random orbit sander are 125mm wide so I glued on some stops with CA Glue (superglue) to ensure the discs don't slide all the way to the back.
For the sanding sheet shelves (say that 3x fast), i used a Forster bit to bore a half hole that makes it easier to pull out the shelve.
Step 7: Enjoy Your Organized Shop!
I hope you enjoyed this article and found some inspiration to make your own and if you want to see more great projects you can subscribe my YouTube Channel too! If you liked this project please Vote for it! Thank you very much!
Please make sure you watched the video build to get a better
understanding the entire process, and it also helps me out to make more of these projects!
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    13 Discussions
    jeanniel1
    1 year ago
    Pull out shelves! You got me there! Voted for this project!
    SteveH284
    1 year ago
    what brand of table saw do you have? Looks like it is easy to keep the cuts square.
    OllarisSteveH284
    Reply 1 year ago
    It's a Scheppach brand. You can micro adjust almost everything on it so you can tune it up pretty nice! you can find an Amazon link in Step1 at tools and materials
    mariosk8s
    1 year ago
    Cool project. I still have all that abrasive junk in a box. Not so useful. Where did you get that yellow push block?
    Ollarismariosk8s
    Reply 1 year ago
    Thank you very much! You can buy it on Amazon, here is my affiliate link where you find it : http://amzn.to/2zfbgz0
    Gadget Man 656
    1 year ago
    Very nice project. Something I've been wanting to find. But a word of caution from experience, stand to the left of the saw when using a rip fence. If you have ever had a kick back in the gut it is no fun for days. Also try a small stop block on the side of your rip fence then you will not get a bind and possibly prevent a kick back. Keep cutting you do great work
    Lovetra
    1 year ago
    Love your humor Duh in step 4 and step 5 Removable created a piece of fire wood for me yesterday. It only took about 20 minutes too and I couldn't get the glue to let go so I could salvage my shelf. I think I'll try your design and attach french cleats cuz my sand paper is a disastrous mess.
    OllarisLovetra
    Reply 1 year ago
    Haha! Thank you very much!
    jpmarth
    1 year ago
    Nicely done! I may give this a try and add some sections for saw blades.
