Mood Lamp With Arduino
112,581
220
65
Hi! In this tutorial you will learn to make a mood lamp with arduino.
I know that you may have seen a lot of mood lamp projects with arduino, but I wasn't very satisfied with them because they all change the color very abruptly. So, I decided to make a smooth mood lamp and I also made it to turn on only when the room is dark.
This project is good for those who are beginners in the arduino's world.
Supplies:
Step 1: Material
For this instructable you are gonna need:
- Arduino
- Jumper wires
- 1 RGB LED or 1 red LED, 1 green LED and 1 blue LED
- LDR (Light Dependent Resistor)
- Protoboard
- Sheet of paper
Step 2: Time to Code!
Write the code above on the Arduino program.
Darker the ambient light is, the higher is the value read from the LDR.
I used PWM to change led's brightness.
// Smooth RGB mood lamp
// Changes an RGB LED's color smoothly that only turns on
// when it's dark around it.
// Author: Ricardo Ouvina
// Date: 19/07/2012
// Version: 2.0
// The brightness of the leds follows these equations:
// Red = sin(x)
// Green = sin(x + PI/3)
// Blue = sin(x + 2PI/3)
// for x from 0 to PI
float RGB[3];
int ldrPin = 0;     // LDR in Analog Input 0 to read the ambient light
int ambientLight;   // variable to store the value of the ambient light
int redLed   = 11;  // red LED in Digital Pin 11 (PWM)
int greenLed = 10;  // green LED in Digital Pin 10 (PWM)
int blueLed  = 9;   // blue LED in Digital Pin 9 (PWM)
void setup(){
  pinMode(redLed,OUTPUT);  // tell arduino it's an output
  pinMode(greenLed,OUTPUT);// tell arduino it's an output
  pinMode(blueLed,OUTPUT); // tell arduino it's an output
  // set all the outputs to low
  digitalWrite(redLed,LOW);
  digitalWrite(greenLed,LOW);
  digitalWrite(blueLed,LOW);
void loop(){
  for (float x=0;x<PI;x=x+0.00001){
    RGB[0]=255*abs(sin(x*(180/PI)));           // calculate the brightness for the red led
    RGB[1]=255*abs(sin((x+PI/3)*(180/PI)));    // calculate the brightness for the green led
    RGB[2]=255*abs(sin((x+(2*PI)/3)*(180/PI)));// calculate the brightness for the blue led
    ambientLight=analogRead(ldrPin); // read an store the ambient light
    if(ambientLight>600){ // start only if the ambient light is very low
      //  write the brightness on the leds
      analogWrite(redLed,RGB[0]);
      analogWrite(greenLed,RGB[1]);
      analogWrite(blueLed,RGB[2]);
    else{
    for(int i=0;i<3;i++){
      if(RGB[i]<1){
        delay(100);
      if(RGB[i]<5){
        delay(50);
      if(RGB[i]<10){
        delay(10);
      if(RGB[i]<100){
        delay(5);
    delay(1);
Step 3: Connect It!
Connect as it is on the image.
Step 4: Upload and It's Done!
Upload the code to the arduino and it's done.
Try to add a sheet of paper around it to see it more smoothly, the paper acts as a diffuser.
Feel free to modify this project to your way, and tell me your progress. Comments are welcome.
Have a look at  the video I've made.
9 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Classroom Science Contest
65 Discussions
RonaldM10
1 year ago
Don't you need to limit the current going throught the leds????
https://learn.adafruit.com/adafruit-arduino-lesson-3-rgb-leds/overview
codeyoneill113
1 year ago
Made it for my ICT class in 2017
MichaelR287
3 years ago
quick question, how do i change the rate that it dims at, because i need to be faster
Brandon15601
3 years ago
Hey, has anyone figured out a code utilizing this concept but with a temperature sensor to change the color of the LED with body temp? Preferably adnafie's code listed below in the comments. Thanks!
silkroute
3 years ago
how to use an another led on arduino neno
AjiS10
3 years ago
No schematic ?
Gemm87
3 years ago
I made it but I'd love to know if there are any good resources out there to help me understand the code - I have learned a couple of basics but some of the terms still confuse me. Thanks for the project it's a great early confidence builder when it comes to the circuit!
jinstruct
3 years ago on Introduction
Very good idea! Pls. find my modification of the code that is also smooth and shows all colors in the spectrum with higher intensity:
float RGB[3];
int delaymood = 100; // delay for mood light
void setup(){
digitalWrite(redLed,HIGH);
void loop(){
for (int y=0; y<=3; y++) {
if (y=1){
for (int x=0;x<=255;x++){
RGB[0]=255-x;
RGB[1]=0;
RGB[2]=0+x;
delay(delaymood);
if (y=2){
RGB[0]=0;
RGB[1]=0+x;
RGB[2]=255-x;
delay(delaymood);
if (y=3){
RGB[0]=0+x;
RGB[1]=255-x;
RGB[2]=0;
delay(delaymood);
justinrains
Awesome project! Now wanting to add more LEDs to make it look even more awesome!
geekrex
4 years ago
i made it too .i quite modified the project having more mode of operation plz say me hows it
agrady1995
5 years ago
I MADE IT! too bad that button isn't on the iPhone app-- where I'm actually able to upload pics
14, 11:46 PM.jpg14, 11:46 PM.jpg14, 11:46 PM.jpg14, 11:46 PM.jpg
agrady1995
5 years ago on Step 3
--Made it in 10 minutes of opening the instructable. It was cool, but it would turn itself off with the LDR as soon as the light came on (I followed the breadboard exactally, and it was close to the LED).
So, about to move it, I took out the LDR, and it worked.... I'll just run it without it. Thank you!
agrady1995
5 years ago on Step 2
hi there! I just got my arduino the other day, but i'm kind of quick to learning programming. can you explain the parts of your (equation) that made the lights change the way they did, and how it worked? Thanks!
-- Student and future Biomedical Engineer
adnafie
5 years ago on Introduction
Hi! thank you for the tutorial. But, i'm have a little problem here. See, i tired to combine this circuit with lm35 temperature sensor so that the circuit can sense temperature and light at the same time. I use different led for different sensor. Now the problem is, when i combine the 2 source code, the mood lamp seems not working well. It lighted up but it dont changing colors. Can you help me with this? Here is my source code:
float RGB[3];
float tempC;
int analog_tempPin1 = 1;
int ledPin1 = 11; // red LED in Digital Pin 11 (PWM)
int ledPin2 = 10; // green LED in Digital Pin 10 (PWM)
int ledPin3 = 9; // blue LED in Digital Pin 9 (PWM)
int ledPin4 = 7; // LED connected to digital pin 7
int ledPin5 = 6;
void setup(){
pinMode(ledPin1,OUTPUT); // tell arduino it's an output
pinMode(ledPin2,OUTPUT);// tell arduino it's an output
pinMode(ledPin3,OUTPUT); // tell arduino it's an output
digitalWrite(ledPin1,LOW);
digitalWrite(ledPin2,LOW);
digitalWrite(ledPin3,LOW);
pinMode(ledPin4, OUTPUT);
pinMode(ledPin5, OUTPUT);
Serial.begin(9600);
void loop(){
analogWrite(ledPin1,RGB[0]);
analogWrite(ledPin2,RGB[1]);
analogWrite(ledPin3,RGB[2]);
else{
if(RGB[i]<1){
delay(100);
if(RGB[i]<5){
delay(50);
if(RGB[i]<10){
delay(10);
if(RGB[i]<100){
delay(5);
delay(1);
tempC = analogRead(analog_tempPin1); //read the value from the sensor
tempC = (5.0 * tempC * 100.0)/1024.0; //convert the analog data to temperature
Serial.print("analog ");
Serial.print(analog_tempPin1);
Serial.print(" ");
Serial.println(tempC); //send the data to the computer
if (tempC < 40){
digitalWrite(ledPin4, HIGH); // set the LED on
digitalWrite(ledPin5, LOW); // set the LED off
delay(1000); // wait for a second
digitalWrite(ledPin4, LOW); // set the LED off
digitalWrite(ledPin5, HIGH); // set the LED on
if (tempC > 40){
delay(100); // wait for 0.1second
bsüataç
Great instructions! I have a problem tough. I managed to make it change lights and everything. However , When it comes to certain colors it flickers with different frequencies. How can I solve this problem? (I have an Arduino UNO and I use a RGB LED)
XxsonicxX
While I was buying supplies at radioshack, I accidentally bought the wrong resistors, I bought 1/4 watt 220 ohm resistors instead of the 120k ohm resistors needed... Arduino FAIL
eliara
Oi , montei esse projeto , mas o meu só fica piscando em azul os leds o que faço?
ricardouvinaeliara
Reply 5 years ago on Introduction
Olá, verifique se todos os caminhos que você montou estão como no esquemático e para garantir baixe o arquivo ZIP ao invés de copiar direto da página. Se ainda não funcionar me avise, ficarei feliz em ajudar. Ah, e você é a primeira brasileira a comentar aqui! =)
d4ng
Great Instructable! My first "real" Arduino project.
I am attempting to change/add the colors the my RGB LED cycles through.
I have attempted several things but am hitting a dead end..any ideas?
