Mosquito Repeller
4,718
37
20
About: iam a B.E Electronics and Communication Engineer. I have great interest on electronics.I love my college life.Even though there are many sadness in my life.I find joy in making instructables.
We usually get irritated when mosquito bite.When mosquito bites we also get fever at sometimes.We cannot do our work with concentration ,in a place where mosquito are present.This mosquito repeller will make your home and work place mosquito free environment.
Supplies:
Step 1: Components Required
IC
  • IC 555
Resistor
  • 820Ω
  • 1.5KΩ
IC BASE
  • 8 Pin IC Base
Capacitor
  • 0.01μF
  • 0.1μF
BUZZER
  • Buzzer
PCB
  • General Purpose PCB
Connectors
  • 2 Pin screw terminal---------2
Power Supply
  • 5V Charger Board from MOBILE Charger and you can use any type of charger board
Step 2: Materials Required
Calling Bell Box
I had taken my home calling bell box which was not in working condition.So,i choose to enclose the Mosquito Repeller circuit with this calling bell box.
Step 3: Principle Behind Mosquito Repellent Circuit
Human beings can hear sound in the range of 20 Hz to 20 kHz. Sound of any frequency above 20 kHz is termed as ultrasonic sound. Several animals like cats, dogs, insects, mosquitoes have the feature of being able to hear this ultrasonic sound. In mosquitoes, this feature is attributed to the presence of sensory structures in their antennae. Usually ultrasound is transmitted by male mosquitoes and received by female mosquitoes. However after breeding, female mosquitoes generally avoid the ultrasound and this fact can be used to produce ultrasound in a range similar to that produced by male mosquitoes and repel away the mosquitoes. The ultrasound produces a stress on the antennae of the mosquitoes and repels them away.
In other words, a simple circuit is designed which can produce ultrasound in the frequency range of 36 kHz, which can scare away mosquitoes.
Step 4: Schematic Diagram
Step 5: Designing the 555 Oscillator
The basic idea behind developing the circuit is to use a buzzer to produce ultrasound. The buzzer is driven by an oscillator circuit. Here, we are using a 555 Timer based astable multivibrator circuit as the oscillator circuit.
Designing the circuit involves designing an astable multivibrator circuit. Generally, frequency of output signal produced by a 555 astable multivibrator is given by:
F = 1.44((Ra+Rb*2)*C)
Here Ra is the value of resistor between pin 7 and Vcc, Rb is value of resistor between pins 7 and 6 and C is value of capacitor between pin 6 and ground.
Let C = 0.01 microFarad
F = 36 kHz
Let Duty Cycle, D = 60% (It is not possible to get 555 timers to produce signal with 50% duty cycle.
Formula to Calculate Ra and Rb Resistors
Ra = 1.44(2D-1)/(F*C)
And Rb=1.44(1-D)/(F*C)
Substituting values of C, F and D, we get
Ra = 0.818 K Ohms, i.e. 818Ohms and Rb=1.52KOhms
Thus, we can use a resistor of 820Ohms and another resistor of 1.5 K.
The another capacitor at 5th terminal of IC555 is used to terminate the 5th terminal.Because in order to avoid any noise in frequency and also we need not use 5th terminal of IC555 so,we generally connect this terminal to ground with 0.1uF capacitor.
Step 6: Frequency Testing
Testing the output frequency of IC555.The Frequency is 36 KHz,you can see in the above picture.
Step 7: Assembling the Oscillator Circuit in a PCB
I had soldered the Mosquito Repeller circuit in a General Purpose PCB according to the schematic diagram
Step 8: Assembling the Mosquito Repeller
Step 9: And Finally
I had finished assembling the mosquito repeller and i plug into 230V AC socket.Now it is ready to work.Enjoy the mosquito free environment.
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    20 Discussions
    sanjumajisujay1998
    5 months ago
    Please tell me the voltage of the capacitor...........
    Rajkumar2506annpalaya
    Reply 1 year ago
    Probably you don't need it.If you wish to protect the circuit from high voltage you can add it.But the fuse need to have a proper rating.
    Rajkumar2506igggy17
    Reply 1 year ago
    You can't hear that sound of mosquito repeller because the sound is in ultrasonic range.But you can test the output.To test it disconnect the buzzer,take a multimeter.Turn it in AC voltage measurement.Keep the probes of multimeter at the output that is,the two point terminals where the buzzer is connected.If it shows the reading of AC voltage,your circuit is working.You can also test it in another way.Take a frequency meter.Connect the probes of frequency meter in the output of circuit.If the frequency is above than 20Khz.Your mosquito repeller will work.It will take some days to show its effect on mosquito.You can notice the difference in day by day.
    igggy17Rajkumar2506
    Reply 1 year ago
    I know that I can't hear this sound :-)
    Have very small AC output 0,1. Is it OK?
    Rajkumar2506igggy17
    Reply 1 year ago
    Yes it is ok.Since the IC555 is generating AC signal.The AC signal generated will be a square wave.So the square wave is a digital signal.The digital signal will have amplitude 1's and 0's.It is to be taken as,1 is equal to 5V and 0 is equal to Ground, that is 0V.If you want to extend the effect of mosquito repeller till some coverage distance.You can increase the output voltage of IC555.It can be done by as follows
    IC 555 has maximum supply voltage till 15V.You can use 12V power supply instead of 5V supply.By doing this,will increase the output voltage of IC 555.
    igggy17Rajkumar2506
    Reply 1 year ago
    I found a mistake. 3th pin of ic555 was not connect. I fixed it, but now I can hear it. Strong sound. Even neighbors can hear it :)))
    Not good frequency.
    Rajkumar2506igggy17
    Reply 1 year ago
    You might have used incorrect resistor and capacitor values.See the schematic diagram for values of components used.you should use buzzer.Did you opened up digital watch ever.You will find a buzzer if you opened it.The buzzer will be like a round plate.This type of buzzer you should use.
    Rajkumar2506igggy17
    Reply 1 year ago
    You had used 5 Band resistor.Use 4 band resistor.
    igggy17Rajkumar2506
    Reply 1 year ago
    4 or 5 band
    what is the difference?
    value are 1.5 kohm and 820 ohm
    Rajkumar2506igggy17
    Reply 1 year ago
    Did you used 0.01μF capacitor at 2nd terminal?
    Rajkumar2506igggy17
    Reply 2 years ago
    This jumper wire connects 8th and 4th pin of IC 555
    rafununu
    2 years ago
    This is supposed to imit males flying noise and reppels females already gravid (pregnant) that got what they wanted and that's enough, too much is too much.
    Rajkumar2506rafununu
    Reply 2 years ago
    What do you mean by too much is too much.I can't understand what you are saying.Can you say it again clearly.
    dzehner2
    2 years ago
    So does this work only on female mosquitoes or does it work on males too? Very intriguing!
    Rajkumar2506dzehner2
    Reply 2 years ago
    you need not care about male mosquito,because female mosquito only bites.
    nemob
    2 years ago
    too bad this doesn't work
