My First Self Balancing Robot Diy Easy Under 25S
8,353
17
16
This is my first self balancing robot and i search on internet for other self balancing projects and i design my mine robot to be simple and cheap.
In this instructabile i whill tell you step by step how to build your robot in detail with videos ,schematics.
And now to go on first step....
Step 1: Materials
The materials i used for this projects were the cheapest i could get,I buy from Chinese online store with lots of very cheap electronic ,arduino, drivers, sensors,… and free shipping hat’s good (free is good every time).
Battery: http://www.gearbest.com/rc-quadcopter-parts/pp_184809.html?lkid=10000465
Arduino uno http://www.gearbest.com/boards-shields/pp_235013.html?wid=8&lkid=10000466
Motor driver: http://www.gearbest.com/development-boards/pp_43069.html?lkid=10000467
IMU sensor:http://www.gearbest.com/sensors/pp_226745.html?lkid=10000468
2 Dc motorhttp://www.gearbest.com/other-accessories/pp_241581.html?lkid=10000469
Price summary:
arduino uno =3.47$
battery=1.99$
motor driver =4.86$
imu sensor=8.15$
2 dc motor=4.56$
TOTAL=23.16$
I used materials as cheap if i could but you can use whatever you have,
Step 2: Phisics
The physics for this robot are simple, the robot stand in two points
lined, the wheel, and i tends to fall and lose his verticality, the movement of the wheel in the direction of the falling rises the robot for recover the vertical position.
The vehicle attempts to correct for an induced lean angle by moving
forward or backwards, and the goal is to return itself to vertical.
There is a library for arduino that implements this method.
Step 3: Electronics
The electronics we are going to use in the project are simply three, an arduino UNO,
a motor driver and a IMU.
We use a motor driver based on the chip L298.
For the IMU i used the cheapest 10DOF (10 Degrees Of Freedom) i find,
the chinese GY-80 with 3-axis accelerometer, 3-axis gyroscope, magnetometer, barometer and temperature sensors. We use only accelerometer and gyro so you can save money buying another IMU, like the MPU-6050, a 6DOF IMU for only 3.63€!!!!, or accelerometer and gyro for separate.
The IMU is connected to the arduino 2 wires for communication (SDA and SCL) and 2 wires for power, it use 3.3V so we need 3.3V wire and GND.
The motor driver take power directly form the battery so don’t have to
connect arduino’s power to it (i mean the 5V form the arduino), but we need 6 wires to control it, 3 for each motor, one for send the PWM signal for control the motor velocity, and for indicate the direction we want the motor to spin.
The schematis is in the video how to wire the robot.
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    16 Discussions
    Mikhail85
    1 year ago
    send me the code please mixailkalinin34@gmail.com
    hướngh4
    1 year ago
    Aukcje internetoweC:\Users\MINH10~1\AppData\Local\Temp\arduino_modified_sketch_280400\sketch_jul04a.ino:2:29: fatal error: Adafruit_Sensor.h: No such file or directory
    #include <Adafruit_Sensor.h>
    compilation terminated.
    exit status 1
    Error compiling for board Arduino Nano.
    thipphawan
    1 year ago
    send me the code please.
    inse05maii@gmail.com
    aoca1
    2 years ago
    Felicitaciones por tu trabajo
    Please send code arielaudenino@hotmail.com
    thanks
    anask27
    2 years ago
    pls can you sent me the code i try so much and im not god at programming
    my Email ; matrexn3@gmail.com
    scottypotty4x4
    2 years ago
    can you send the code please scottypotty4x4@comcast.net
    nattaponm
    2 years ago
    send me the code please porioy@hotmail.com
    rico22
    2 years ago
    send me the code please brekgungor@gmail.com
    rico22
    2 years ago
    send me the code please its emergency
    Serdarurgun
    2 years ago
    Bana kodu u gönderin urgunserdar@gmail.com
    RendyR5
    2 years ago
    please send me the code..this is my first project...rendy697@googlemail.com
    sonu_123
    2 years ago
    please send me the code..this is my first project.. sonu.chheda@gmail.com
    Jean-Claude GERMAIN
    2 years ago
    Congratulation for your job.
    We are looking forward to get the code
    Many thanks
    Jean-Claude from France
    hoovdan630
    2 years ago
    pleeeeeeeeese send me the code hoovdan630@gmail.com
    TaritD
    2 years ago
    PLSE SEND ME THE CODE PLSE
