Natural Lip Balm - 5 Ingredients
12,338
117
15
About: Hello, my name is Auroris. Every day we have the opportunity to learn new things, to rethink tired processes, and to improve the way we work.
Hi friends,
I want to share with you how to make Amazing DIY Lip Balm
Will use natural & organic ingredients, so your lips will be softer and smoother, and reused containers. Recycling your empties is free and it's one of the ways to build good karma :)
Step 1: Ingredients
  • Natural Beeswax
  • 100% Organic Coconut Oil
  • Liquid Vitamin E Softgel Capsules
  • Jojoba Oil
  • Shea Butter (Karité)
  • Essential oil (optional)
Lip Balm Containers: used or new
Step 2: Reuse Old Containers
You can buy new containers or challenge yourself to keep lip balm/lip gloss containers. You can really reuse them!
Tip: For reuse container: You have to disassemble it, clean off remaining balm, and wash the pieces in a warm or boiling water.
Step 3: Beeswax 100% Pure and Organic
Step 4: Recipe
Take a bowl and add:
15g Beeswax
15g (2 full teaspoons) Solid Coconut Oil
10g (4 teaspoons) Liquid Jojoba Oil
5g (1 teaspoon) Shea Butter
2 Capsules Vitamin E (puncture the capsules and squeeze)
Tip 1: Keep 1:1:1 proportion beeswax, coconut oil & other oils
Tip 2: Add a chunk of your favorite lipstick and you will obtain Tinted Lip Balm
Step 5:
Take a pot, add 1 cup water and bring to a boil. Reduce heat to low, put the bowl inside (be careful that no water gets inside the bowl) and slowly melt the beeswax & oils, stir it slightly to let the heat melt it naturally.
This prevents you from overheating your base.
Tip: Add essential oils after removing from heat.
Step 6: Pour the Mixture Into the Upright Tubes.
If you have upright tube container, pour the lip balm mixture carefully into it using a teaspoon.
If you are using the container of same type (EOS, like an egg). Join the upper and the middle parts. You will have an upside-down container, ready to fill. Pour the lip balm mixture into the lid, filling it just past the grating.
Step 7: And There You Have It!
Allow the lip balm until solid (about 20 minutes in the fridge)
Pocket Sized Contest
This is an entry in the
    • Jewelry Challenge
      Jewelry Challenge
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    15 Discussions
    Hackobo
    5 days ago
    Is there any way to make a lip balm that protects the lips from the UV light?
    AurorisHackobo
    Reply 5 days ago
    Thanks for the question. I looked up about this topic and I found the next information:
    Shea Butter – approx. SPF 5-6
    Coconut Oil – approx. SPF 6-10
    Avocado Oil – approx. SPF 4-8
    Beeswax – approx. SPF 15
    Carrot Seed Essential Oil – approx. SPF 28-40
    I can't say that is true and verified information, but our recipe has a pretty good SPF combination ;)
    chuckr44
    7 days ago on Step 7
    Where do I get the containers to make that egg-shaped lip balm? Do the containers have a special name?
    Aurorischuckr44
    Reply 7 days ago
    I used old lip balm containers from EOS brand.
    You can find a lot of models & colors on aliexpress.com. There's a whole category of Refillable Bottles. Search by ball, sphere or egg balm container.
    I don't know if you are familiar with this site, but I ordered a lot of crafting supplies from there.
    I hope I have helped you.
    Italiankiwiblog
    20 days ago
    This is such a great idea! When the lip-balm sets in the tube, does it wind out easily once it sets, or can it get a bit stuck to the sides of the tube?
    AurorisItaliankiwiblog
    Reply 19 days ago
    You will be surprised, it will be looking exactly like new!
    I suppose that lip balm in tubes are manufactured using the same method. Just twist to the end and fill to the top with balm.
    Good luck :)
    Daisytikityke
    20 days ago on Step 4
    I believe 15 gm of coconut oil should be 6 teaspoons or 2 tablespoons, not two teaspoons.
    AurorisDaisytikityke
    Reply 19 days ago
    I took 2 teaspoons full of solid coconut oil (Step 4, 2nd photo) But if your coconut oil is already melted, you should use 6 teaspoons.
    bakichmg
    21 days ago
    Do you know if this would melt in a pants pocket?? I bought an all natural lip balm and it ended up melting in my pocket. Just curious if your recipe would be better. Thanks for sharing!!
    macshoutbakichmg
    Reply 20 days ago
    In summer you could increase the wax content, and in winter, if you keep one in the car, make it with less wax.
    If you don't like the consistency you end up with, you can always melt it again, and add more wax or oil.
    Aurorisbakichmg
    Reply 21 days ago
    Oh, thanks! Such a clever remark. I will make a test and i will share my conclusions.
    AurorisAuroris
    Reply 21 days ago
    Melting test
    I cut a chunk of lip balm and held it in my hand
    for 20 min. After, I squashed the balm and hold for another 10 minutes.
    Looks like it past that test very well, just moisturized the palm of
    your hand.
    May be some organic balms can melt in contact to your
    body because it is not used wax in their composition. There are some
    recipes with only oils or fat. They a also good, but I think you have to
    keep/to sell your balm in a a small lip balm jars/pots. It gives a
    chance not to melt in your pocket or bag :)
    bakichmg
    21 days ago
    Thanks for taking the time to do that. I am going to try this out. Thanks again for sharing!!
