Nixie Tube Clock No.2
30,706
449
25
About: I learned to take things apart before I could put them together. Reasonably handy with a screwdriver. Can count to twenty without taking my socks off. Learned a lot of things that are of no use at all. H8 tx...
In February 2015 I built a massive Steampunk Lamp with an IN-12A Nixie Tube Clock for my daughter's birthday (photograph in Electronics section and now an Instructable!) and since then I wanted to make another Nixie clock but in a totally different style.
I wanted to use end view Nixie Tubes again but this time bigger so I got a hold of some IN-1 NOS (new old stock) Nixie tubes.
What type of clock? After several designs ended up in the waste paper bin I came up with the idea of suspended digits over a wooden base and the first few ideas that I had were just not all that great looking so it was back to the drawing board, again!
I settled on the design you see here and wanted to use some white oak that I had for the parts. A trip to a scrap yard a couple of years ago to get parts for my car resulted in finding a couple of samples of white oak bannister and 4 spindles in the boot of one of the cars. These lay in my shed gathering dust until I began this project.
Step 1: Getting Started.
White oak is a very hard wood as I found out, cutting off the square sections of the spindle on my ancient mitre saw was not too bad but cutting the bannister sample to length I thought my arm was going to fall off!
I started on the part for the tube holders first by mounting the square section in my small metal lathe with a set of reverse jaws and a home made live spindle to stop it flying off. I turned it down from the square section to the maximum diameter that I could get from it, 47mm. Then it was back to the mitre saw to cut the sections to rough size.
The first one I mounted in the lathe and drilled through with the largest drill I had before using a boring tool to enlarge the hole diameter to that of the glass envelope of the Nixie tube. I reversed the section in the lathe and set the depth of the boring tool to leave an internal shoulder that would let the Nixie tube glass protrude just enough for the display.
Doing it this way was time consuming so I then marked the centre of the other three sections and used a 25mm Forstner bit in my milling machine and hand held them as I drilled the whole way through.
Not to be recommended as the oak shavings come out very hot!
Then the holes were completed to the required internal diameters on the lathe with the boring tool. Once this was done I then set up a stop on the bed of the milling machine so I could position the sections above one of the slots. I centered the head to the slot and with a succession of drills, drilled out the first set of holes to 8mm. Moving the bed to set the distance between the hole I then did the same sequence for the second hole, ensuring that it was parallel to the first.
The next step was to round off the tube end of the Nixie holder with a router rounding off cutter in the milling machine.(no photos of this as I forgot to take them!)
Step 2: The Base Section.
As I said, cutting the bannister section was hard going but the following tasks were a bit easier. Unfortunately I forgot to take more photographs of the steps involved but a verbal description should give you the idea.
I was going to keep the top curve of the bannister section but decided to take it off with an end mill on the milling machine to leave a flat surface which had the edges nicely rounded off with the existing shape of the section. Turning it over and clamping it on top of some thin plywood to protect the top I marked out and cut the recess for the electronics into the base as you can see in the photograph.
The next step was to get the holes for the copper tubing drilled from the ends to the recess. This was an exercise in ingenuity itself! My millling machine does not go high enough to use for this, my cheap benchtop pedestal drill does not have enough of a gap between the head and base plate and hand drilling was out of the question as accuracy was needed! How am I going to do this?
Sitting staring at the drill I remembered that when I assembled it, the whole head assembly had to be mounted on the support pillar and that it could be slackened off and rotated away from the base, I did this only to find that I still did not have enough height! I took the securing bolts out of the bench and raised the whole drill up on 40mm of MDF and clamped it to the bench. Height sorted! I had to secure the base section so I clamped that to a heavy machine block and set it up for being 90 degrees to the drill base and then drilled both ends of the wooden base section for the copper tubing.
To get the ends curved I first trimmed off the excess with a saw and then made two holes in the base to accept a 10mm steel pin. I had a piece of 20mm aluminium plate in which I also made a 10mm hole. This was clamped down to the bed of the machine when the drill was still in the hole to get a dead centre point for forming the end curves.
Replacing the 10mm drill with a 12mm milling cutter I move the bed away from it and fitted the oak base to the aluminium plate. With the cutter running and the wood angled away from it I slowly brought it into contact with the cutter by rotating it about the pin and formed the curves in several careful passes as there is a tendency to splinter the rear of the curve as the cutter is always turning into it.
Step 3: The Copper Tubing.
I originally wanted to use 10mm copper tubing but the local DIY superstore did not have any in stock and I wasn't going to go traipsing about looking for 10mm so I bought the 8mm tubing that they had there. Luckily, the 8mm proved to be more pleasing looking that 10mm would have been.
How to bend copper tubing and fail first time around!
I made a round disc of MDF and created a groove in it to accept the tubing - Great!
I cut a section of the tubing and then proceeded to bend it around the disc. When I removed it, the tubing had flattened out in the bend and was more oval than round - FAIL!
I knew that to bend copper tubing you really need a former that holds the tubing against the disk to shape it as you bend it or you need a bending spring that you put inside of the tubing before bending it. I had neither and then I remembered that in an RC Forum that I belong to that one of the guys was bending aluminium tubing and getting the same results as I have here until another member told him to pack it with sand first.
8mm tubing does not lend itself to being packed with builders sand! What next? Fine grain sand? Then the light bulb appeared above my head, SALT!
Less than a Euro later and I was bending the tubing like a Jedi Master! I had sealed one end with duct tape and then filled the tube with the salt making sure that it was packed as tightly as possible by tamping down with the end of a tight fitting drill and then covered it with duct tape too.
I formed all 4 of the curved sections and adjusted each until I had a matching set of 4 curves and then trimmed to length with a dinky little tubing cutter I use for plastic tubing.
I set out the holders and cut 6 short pieces for the interconnecting sections, removed all of the internal burrs with a round file and emery paper. When you uncoil this type of tubing it is very hard to get straight so I put the shank of a close fitting drill in the short sections and rolled them between two thick plates of MDF to get them a bit straighter.
Time to dry assemble the parts!
Pushing the short sections into the tube holders first and spacing them equally I fitted one set of curves to the base, so far so good. With a bit of effort I fitted the other set of curves and made adjustments for alignment of the tubes to the base. The resulting look was exactly what I had hoped to achieve.
Step 4: Preparation, Polishing and Putting Together.
White oak when raw has a nice grain and figure to it and this is enhanced with finishing, the better the finish, the better that the wood shows its figure.
I was not wanting to stain the oak nor was I just going to varnish it as this detracts from the natural look. When wood is first cut it has moisture in it and the drying process changes how it looks, trying to get this look back is best done with oils.
The first task was to get all of the parts as smooth as possible and try and remove any imperfections from the construction of them. The tube holders were easily done in the lathe but the base section still had varnish on most of it but this was removed by working up from medium to extra fine grit aluminium oxide sand papers and finishing with a very fine Scotch Brite pad by sanding with the grain.
There are many finishing oils on the market and one that lends itself well to white oak is Danish Oil. The one shown in the photograph is a good enough version and is very easy to use as per the instructions on the can. The only issue is that the wood feels tacky and damp after applying but there is a cure for this. Apply the oil to the wood as per the instructions and allow to soak in / dry for at least 24 hours.
Once dry gently rub the wood along the grain with an extremely fine sand paper / emery paper to even it out. I used 800 then 1400 grit emery paper for this step.
The Cure.
Mix equal amounts of Danish Oil, White Spirit and a proper varnish! Do NOT use polyurethane based varnishes as these will not mix with the oil and white spirit, use a varnish such as Yacht Varnish and apply with a soft brush in the direction of the grain and make sure that the end grain is well covered. This combination will get pulled into the pre-oiled wood as the white spirit acts as a solvent carrier and draw the solution into the wood. Allow to dry for at least 48 hours and rub down again with the finest of abrasive papers again. This takes out any raised imperfections. Apply another coating of the mixture to the wood and this should then start to give a depth to the look of the grain. Allow this to dry completely and rub down again if required. If you want you can finish with a thin coat of varnish (thin it down with white spirit), I used satin finish as I did not want it to be too shiny in comparison to the glass of the Nixie tubes.
Put aside to a safe place to avoid damage and let dry thoroughly.
Polishing the copper is the easy part and there are many brands of polish on the market. I tested those that I had on a couple of offcuts of the tubing and the best result came from an Aluminium Polish followed by a polish with Brasso liquid. The aluminium polish has very fine abrasive particles and mine is so old now that it has become a paste which works well, the Brasso just gives that extra depth to the shine afterward and removes any fine scratching from the paste. Wipe down and polish with a soft cloth before coating with a protective coating of clear polyurethane spray. I just knocked some small panel pins into a bit of MDF to support the parts as I sprayed them.
Spray the parts in a warm environment as if it is cold the polyurethane spray will be milky and do not get too enthusiastic with the spraying, several light coats are better than one heavy one - ask me how I know this!
Step 5: The Electronics for the Clock.
When I built the Steampunk clock for my daughter I used a FunKlock kit from PV Electronics with IN-12A Nixie tubes. I was going to use the same tubes again but I wanted to have round displays of the numerals this time as the IN-12A are rounded oblongs so I contacted Pete, the owner of PV Electronics, to find out if the same kit was capable of powering the IN-1 Nixie tubes. As it happens, it can with no need to alter the kit.
Dealing with PV Electronics is simplified with the online live chat and Pete is only too willing to offer advice and sources for parts he does not carry. He put me on to an Ebayer who sells crimp push on connections that are suitable for using with the IN-1 Nixie tube base pins. Pete's customer service is second to none and I would recommend his kits for projects such as this.
Building a PV FunKlock is an easy exercise if you can identify components, solder and use a pair of small wire cutters with confidence. The kit is designed in two parts - the main controller and the tube board, these connect together with board headers to form a compact unit. The downloadable instructions from PV Electronics are excellent and it is just a case of following them to the letter for a problem free build.
The images of the two boards show how compact this clock module is. Even with its case and with the IN-12A Nixies it is a very small unit. In the other image the LEDs are on the left and the AM/PM Neons to the right
As I was not mounting the Nixie tubes directly to the tube board but using remote wiring instead I had to make a direct connection to one of the tube bases on the tube circuit board as well as the 4 Anodes. As you can see, the pins are easily identified on the IN-1 tubes and with a multimeter I was able to confirm the positions of the cathodes of the tube base to the circuit board.
Step 6: Wiring Up the Nixie Tubes
I created enough depth in the recess of the base in order to contain the wiring from the Nixie tube section along with the circuit boards. It will also allow the installation of the SET and ADJ switches which I removed from the main board and will be activated from the rear of the base unit.
Once the Nixie tubes are in place and secured connecting the Nixie tubes up is done by the use of Molex type sockets which are covered by heatshrink. It is a slow task making up the wiring as it has to be installed to the Nixie Tube holders in sections as each tube holder is linked to the adjacent one and you cannot get all of the wires through with the connections in place. Note:- I used 22AWG wire for this project.
I cut all of the wires required to length and fitted the connection sockets to a pair of wires for each pin. Heat shrink covered the exposed ends and they were numbered for connection to the pins on the Nixie tubes. The sockets are connected to the pins and the free ends of the wires are fed through the tubes on either side and then the sockets are fitted, heat shrunk and numbered before connecting to the next Nixie tube.
The LHS connecting copper tube only has 11 wires coming from it, the next one has 12, the next one has 13 wires in it and finally, the RHS copper tube that feeds down to the circuit boards has only 14 wires (4 Anodes & 10 Cathodes) due to daisy chainng the cathodes and utilising the PV Electronics multipexing circuit. It is just a case of starting from one tube and connecting the wires to the selected pins of each Nixie tube then feed down to the tube board. The 10 cathode wires that come down the copper tube to the recess are then soldered to one of the existing Nixie tube connection pad sections.
The Anode wires are then connected to the relevant opto isolator for each Nixie tube. Easy as pie!
NOT!
On power up I found that several of the digits in the Nixie tubes did not scroll through as they should have done. I checked the circuit boards for any defect but found none so it was down to a wiring issue.
Testing out the wiring I located several open circuits that were caused by the insulation crimp part of the connectors severing the conductor of the wire. Pull off every connector and test for opens - ARGH!
Several hours later......................................
I had to remake 5 of the connections and as I installed the wiring this time I tested the continuity for every section. Powering up I found that one of the 'tested' Nixie tubes was faulty. Tube tester purchase on the wish list.now!
After replacing the faulty tube the clock powered up and gave a satisfying red glow and I set the parameters I wanted for the display. This is covered very well in the FunKlock assembly instructions.
Step 7: The Completed Clock.
Finally Clock No.2 is complete and working!
Remember those 10mm holes I made for forming the end curves? They came in handy for mounting the Set & Adjust buttons as I wanted to remove them from the circuit board along with the power inlet. Some hot glue secures them to the base and the power inlet to the rear of the base making for a tidy installation.
I will be fitting orange/red LEDs to the circuit board and a diffuser plate to give a glow emanating from the underside of the base. Did this but a poor photo of the effect, folks! I used brass dome nuts to make the feet to allow the glow out.
Despite all of the little setbacks this has been an enjoyable build and the end result is worth the effort.
Step 8: Resources, Tools, Etc.
Resources
PV Electronics for the FunKlock kit.
EBay for the IN-1 Nixie tubes
EBay for the 22 AWG connecting wire
Ebay for the crimp connectors
B&Q for the 8mm copper tubing
Scrap yard for the white oak parts!
Tools
Hobby lathe, Milling machine, Pedestal drill, Soldering Iron, Electronic snips, Hot glue gun, Screwdrivers, Craft knife, Drills, Forstner bit
Sundries
Danish oil, White spirit, Yacht varnish, Sandpaper,
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    25 Discussions
    Jonbouy
    Question 3 months ago on Step 6
    I am not sure if you still get notices from this project, but what molex connectors did you use? Can you post a picture of it from farnel element 14 for me.
    i am trying to do a 6 digit one using a similar design, but am finding connecting the wire to the nixie difficult. I have tried 4 different sorts so far!!
    thanks
    jon
    Roddy ScottJonbouy
    Answer 3 months ago
    Hello Jon,
    I got the sockets I used from Ebay but cannot remember the part number. I have asked a fellow clock maker for a reference for them as he does a lot more building than me so I should have an answer for you soon.
    IN-1s are prone to early failure when compared to the likes of ZM1020s. I replaced the IN-1s in my clock with GN-4s which are a similar dome size but use B13B sockets as do the ZM1020s.
    The Facebook page Nixie Clock Fan Page is where most of us Nixie lovers hang out and there is a wealth of information and readily available help there.
    As soon as I get a reply I will let you know the details.
    It will be interesting to see what you come up with in your design.
    Rgds,
    Roddy
    JonbouyRoddy Scott
    Reply 3 months ago
    Thanks for all that. I stumbled across nixie’s about 2 years ago and they just stayed in the back of my mind. Then about a year later I saw your design and thought that it looked good.
    When researching I really liked the IN-18’s but who wouldn’t. So I brought 6 of the zm1020 after seeing they had longer life spans than the small IN-1.
    My design will be quite similar to yours, unless I get fed up with making 6 holders and threading wire though copper tube!! but will post pictures on Facebook when I finish.
    thanks for your help.
    Roddy ScottJonbouy
    Reply 3 months ago
    Jon,
    you can get ceramic B13B sockets from Ebay from a Chinese supplier and simplify the wiring. Also, you can go as low as 28 AWG for the wiring as the currents are negligible. The thinner the wire the easier it is to do but the connections are a bit more fragile and require heat shrink for sure. Ideally you need 11 colours to wire it up to prevent cross connections - I had those with the single colour and it is a pain to trace it all out! If you are building a 6 tube clock then I recommend the PV Electronics DINK kit as this is ideal for what you have in mind. To secure the sockets into the wooden holders, hot glue is ideal as it allows you to align them before it sets.
    Any problems just drop me a message.
    PS - take a look at the Atomium clock in regards to holders, the back plates in brass are better than wooden ones which I used in this clock.
    Roddy
    JonbouyRoddy Scott
    Reply 3 months ago
    Well now you said I can ask questions........
    i have mocked up something in copper heating oil pipe, but you keep using the word brass, where are you buying brass pipe in Ireland? I have looked and can’t really find much.
    I was thinking of using copper, polishing it, and then apply a coat of lacquer to keep the tarnish away.
    thoughts??
    Roddy ScottJonbouy
    Reply 3 months ago
    Hi Jon,
    the copper tube came from B&Q from the plumbing section, it is for microbore heating. The brass I was on about was the rear cover plates for the tube holders.
    Any brass tubing I buy comes from China as it is thick wall type, not that crap from K&S that costs a fortune and I use it straight as bending brass is a lot more difficult than copper.
    Rgds,
    Roddy
    Roddy ScottJonbouy
    Answer 3 months ago
    If it is any help, the pin diameter of an IN-1 is 2.36 mm.
    Jfieldcap
    3 years ago
    Wow! Up until now, all the nixie tube clocks I'd seen had the tubes sticking out the top (Which I didn't really like), and were big and bulky. I was pretty surprised this all fit into a small (And unique!) case like this! And I'll have to take a look at this kit you mention, maybe using Nixies wouldn't be so bad after all. (I think I'm still using Numitrons for my first clock though), great Job, and nice 'ible! You have my vote!
    Roddy ScottJfieldcap
    Reply 3 years ago
    Hello Jfieldcap,
    the two clocks that I have made instructables for both feature end view Nixie tubes as that was the criteria I was looking for for them. The IN-1 tube is quite squat in appearance as are the IN-12As that I have used before. These are relatively cheap tubes in comparison to the likes of IN-18s which for 6, cost around $280 to $350.
    I would advise against using Numitron tubes as their lifespan can be quite short compared to Nixies and VFD tubes. Typically an NOS Nixie will have a minimum lifespan of 5,000 hours but there are clocks that have been running for over 3 years with the same tubes and still going strong.
    PV Electronics are one of many suppliers of kits but I like the service back up that they provide and Pete is always willing to give advice on projects.
    The next clock that I have in the planning stage just now will feature IN-8s, vertical Nixies, as it has mechanical features that these tubes will enhance.
    Thank you for your kind comments.
    Roddy
    JfieldcapRoddy Scott
    Reply 3 years ago
    Thanks for the comment back and advice, Roddy! It seems like Numitrons would have a longer lifespan if the voltage and current to them was correctly regulated for their specific needs, but I don't know. I haven't read anything about their lifespan. Maybe I should. Anyways, I still think I'll go with numitrons for starters (Mainly because of the ease of using them with an arduino), but I'll definitely get into nixes later on. Best of luck in the contest!
    Roddy ScottRoddy Scott
    Reply 3 years ago
    Actually I missed out that you said you were using Arduino, I am to long in the tooth for these modern fangled things!
    Reply 3 years ago
    Heh, yes, since numitrons can be driven at voltages comparable to LEDs, they're quite a bit easier to use than Nixies. (With an arduino) ;)
    JfieldcapJfieldcap
    Reply 3 years ago
    After a bit of research, it appears that about 100,000 hours is the expected lifespan, and it raises the lower the current/voltage applied. So, according to a little math, each numitron would be expected to last about 11 years under constant use. Not bad.
    clazman
    3 years ago
    Very nice clock.
    Very nice execution!
    Thanks for using a precision boring tool as the Forstner bit.
    I get very upset when a spade bit with a poor quality hole. They are meant for fast boring for general construction.
    Roddy Scottclazman
    Reply 3 years ago
    Hello Clazman,
    thanks for your comments on the clock.
    With regards to the Forstner bit, I used to work with machines made of plastics and only Forstner bits could give a true hole compared to flat bits, holes saws etc so I have always used them for hobbying work.
    lglira
    3 years ago
    Beautiful project, I am going to replicate this as a science project for the school
    Roddy Scottlglira
    Reply 3 years ago
    Iglira,
    Let me know how you get on and if there is any advice you need on any step, just ask me and I will help you out
    Roddy
