Object Interaction With Touchscreens
11,619
52
9
About: Experiential design studio creating artistic projects and installations utilising innovative technology.
We were interested in finding ways to get our flat screens to interact with physical 3d objects and surfaces.
Touchscreens are omnipresent, a multitude of devices and screen formats exist with thousands of apps however we only found a few options that enable object interaction.
We can imagine a lot of creative opportunities to bridge these two worlds - objects and materials you can touch with digital applications able to display rich interactive content.
Our tutorial suggests ways to create the object tracking with capacitive touchscreen using an openFrameworks application. The application can run on Windows or iOS. You will need coding experience with openFrameworks to run the object detection application and to create your own interactive content.
Please note this tutorial is at an experimental level and there is room for improvement. We hope you will have suggestions and questions!
Technology Background
To understand where we come from we need to go back to infrared acrylic projection touchscreen using camera, there are systems able to detect touch as well fiducial markers and objects.
( How to make one :
https://www.instructables.com/id/Multi-touch-Table
https://www.instructables.com/id/How-to-build-a-Multi-Touch-surface/
http://ccv.nuigroup.com/#home
In 2012 we created one using ccv )
As this system is using a camera for touch tracking it was fairly simple and natural to track objects or fiducial markers.
Now the technology is used less and capacitive touchscreens (same as used in our smartphone touchscreens) are widespread. Capacitive touchscreens are very accurate, cheap to get and simple to use. However unlike infrared acrylic projection there are no common ways to create interaction with an object. The only instance of such technology we have seen is from the company Volumique, we believe they are using a similar technology as what we are showing in this tutorial.
Step 1: Material
For our demo, we used the following materials (affiliate links)
Note you must choose a touchscreen or device with capacitive touch and more than 3 points of touch (you need 3 points of touch per object interacting on the screen, usually recent capacitive touch screen support 10 point touch, so potentially 3 objects detected at the same time + 1 finger )
Note we first tried using plastic pads http://amzn.to/2ctzgEp , however it was not sliding nicely on the screen so unless you want the object to stick on your screen use softer materials like felt pads
Step 2: How It Works
We are creating three touch points forming a triangle on the touchscreen.
The software is detecting all touch points and looking for isosceles triangle patterns.
We chose to detect isosceles triangles with different apex angles so we can detect different objects. Also, knowing the apex of the triangle we can find out the orientation/rotation angle of the object.
The center of the object is estimated at the center of the triangle.
Step 3: Print and Modify Marker Template
We suggest using 1 to 13 different objects. If you want to use as many as 13 different objects or more you will need to create very accurate markers. You might need to experiment with different triangles that feature different angles before getting satisfying results.
You can create different size of triangles, what is important for the small software we provide is to keep the same apex angle.
Step 4: Create/find Objects
The object needs to have at least one flat surface, that can rest on the screen.
In our demo, we created geometric shapes using mold making techniques. We worked with alginate to create the molds as it sets really quickly and works with most materials such as ceramic powder, which we mixed with pigments to make our objects. We look forward to seeing what kind of objects you will use!
Step 5: Create the Markers
  • Following as accurately as possible the printed triangle template, stick the 3 raised pads onto the flat surface of your object
  • Using the conductive ink, paint the pads surface
  • Connect the 3 pads and the object with conductive ink
If you are not using a conductive object you will need to create a connection point you can reach with your hand at the top or sides of the object. This point will also need to be connected to the pads.
When the conductive ink is dry, you are ready for the next part.
Step 6: Prepare the Software
  • You need to have openFrameworks setup and running on your system.
  • Download the touch application from:
https://github.com/paul-ferragut/oscTouchObject (windows and openFrameworks, relies on external add-ons https://github.com/nneonneo/ofxWin8Touch )
https://github.com/paul-ferragut/iOSoscTouchObject (iOS and openFrameworks, unfortunately, you will need to be a licensed Apple developer in order to compile the app on iOS)
  • Before you run the app you will need to modify the file bin/data/settings.xml. Write the apex angle of the isosceles triangle marker you are using in the settings.xml file and save the file (eg: on the example image we use 4 objects with apex angles of 38 , 91 , 150 and 165 )
  • Optionally you can use OSC protocol to communicate with another application, you will need to change the localhost address and port in the settings.xml file. Additionally, there is flag called #USE_OSC in the file touchObject.h, you will need to keep the flag uncommented. If you don't need OSC you can comment #USE_OSC
  • When the app launch you will see a dark screen with a GUI. Depending on your screen resolution and the width of your triangle markers you will need to adjust the slider "distanceTriangle". This variable changes the minimum distance for a triangle to be detected. You can simulate a marker using 3 fingers on the screen and form a triangle (see gif).
  • After you were able to test your objects and the markers detection you can start to create your own interactive content!
In our demo we had some fun with the following openFrameworks addons:
https://github.com/vanderlin/ofxBox2d
https://github.com/bakercp/ofxLight2D
https://github.com/tado/ofxLiquidFun
https://github.com/jacres/of-DeferredRendering
  • Gardening Contest
    Gardening Contest
  • IoT Challenge
    IoT Challenge
  • Classroom Science Contest
9 Discussions
yucca34
4 months ago
Thank you very much for this tutorial. I can not make your code work for windows. I am totally new to openframeworks and I have a lot of LK2019 errors.
all of the type:
Error LNK2019 unresolved external symbol "public: class ofxColorPicker_ * __thiscall ofxColorPicker_ :: setup (class ofParameter >, float, float)" (? Setup @? $ OfxColorPicker_ @ M @@ QAEPAV1 @ V? $ OfParameter @ V? $ OfColor_ @ M @@@@ MM @ Z) referenced in function "public: class ofxColorSlider_ * __thiscall ofxColorSlider_ :: setup (class ofParameter >, float, float) "(? setup @? $ ofxColorSlider_ @ M @@ QAEPAV1 @ V? $ ofParameter @ V? $ ofColor_ @ M @@@@ MM @ Z) oscTouchObject C: \ Users \ User \ Documents \ CODES \ openFrameworks \ of_v0.10.1_vs2017_release \ apps \ myapps \ oscTouchObject \ ofxSliderGroup.obj 1.
it is certainly not much to correct but I can not do it. Do you have an idea. Merry Christmas !
QuanhuaH
7 months ago
Transparent background window in OpenFrameworks?
I am trying to create an invisible overlay that captures touch events (which will be responsible with sending packets using oscpack). Therefore, I need to create a transparent fullscreen window. (EDIT: win32 would be just fine if cross compatibility is a problem)
JugalR1
1 year ago
Hi! how does it still detect even when the hands are not touching?
QuanhuaHJugalR1
Reply 7 months ago
When I allow osctouch software, it blocks other software. How can I use this software?
QuanhuaH
7 months ago
MartinC156
Question 1 year ago
Hi guys. Great tutorial. I'd love to try this out, but have only an Ipad and no "Apple developer" license. Does this mean I will not be able to run it at all? Thanks :)
1 answer
convivialstudioMartinC156
Answer 10 months ago
Hi Martin
You won't be able to develop on iPad without the apple developer account unfortunately. With knowledge in openFrameworks it would be possible and free to port the iOS code to android if you have an android device
The best alternative is to get a touchscreen and windows system, this one is cheap and good https://www.amazon.com/Hannspree-Hanns-G-HT225HPB-...
MartinC156
1 year ago
Bare Conductive
2 years ago
Thumbs up! Great project and tutorial!
